[cgma-dev] PyTAPS Multiple Geometry Load Failure
Stuart Slattery sslattery at wisc.edu
Mon Apr 12 12:39:47 CDT 2010
Hi
I am attempting to load two different ACIS files in order to compare. I
have found that a seg fault occurs when trying to load more than one
file. I have tried both using multiple iGeom constructors for each file
as well as one iGeom constructor and loading both files with that.
Attached you will find a sample python script and an ACIS file that
demonstrates the error by attempting to load 2 ACIS files (the same file
in this case).
Thanks
Stuart Slattery
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100412/1581cd31/attachment-0001.diff>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100412/1581cd31/attachment-0001.py>
More information about the cgma-dev mailing list
