[cgma-dev] [Fwd: PyTAPS Multiple Geometry Load Failure]
Tim Tautges tautges at mcs.anl.gov
Mon Apr 12 12:46:48 CDT 2010
Rajeev,
   Could you take a look at this?  Thanks.  I know loading into 2 separate instances won't work, since cgm isn't thread
safe.  Loading twice should work, though.
- tim
-------- Original Message --------
Subject: [cgma-dev] PyTAPS Multiple Geometry Load Failure
Date: Mon, 12 Apr 2010 12:39:47 -0500
To: cgma-dev at mcs.anl.gov
Hi
I am attempting to load two different ACIS files in order to compare. I
have found that a seg fault occurs when trying to load more than one
file. I have tried both using multiple iGeom constructors for each file
as well as one iGeom constructor and loading both files with that.
Attached you will find a sample python script and an ACIS file that
demonstrates the error by attempting to load 2 ACIS files (the same file
in this case).
Thanks
Stuart Slattery
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100412/d737029d/attachment-0001.diff>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100412/d737029d/attachment-0001.py>
More information about the cgma-dev mailing list
