[cgma-dev] r3716 - cgm/trunk/itaps
jvporter at wisc.edu
Fri Mar 26 22:41:05 CDT 2010
Author: jvporter
Date: 2010-03-26 22:41:04 -0500 (Fri, 26 Mar 2010)
New Revision: 3716
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Avoid floating point exceptions in iGeom_getPntRayIntsct when direction
has at least one zero coordinate (it will probably still crash with
Cubit, though)
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2010-03-26 21:18:41 UTC (rev 3715)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2010-03-27 03:41:04 UTC (rev 3716)
@@ -6444,7 +6444,8 @@
return CUBIT_SUCCESS;
-/** Smits' algorithm */
+/** We could use Smits' algorithm here, but only if we turned of
+ floating-point exceptions */
static inline void box_min_max( double dir,
double min,
double max,
@@ -6452,7 +6453,11 @@
double& tmin,
double& tmax )
- if (dir >= 0.0) {
+ if (dir == 0) {
+ tmin = -INFINITY;
+ tmax = INFINITY;
+ else if (dir > 0.0) {
tmin = (min - pt) / dir;
tmax = (max - pt) / dir;
More information about the cgma-dev
