[cgma-dev] enable shared
Tim Tautges tautges at mcs.anl.gov
Tue Mar 23 07:59:51 CDT 2010
jain at mcs.anl.gov wrote:
> ACIS
Please distinguish here between ACIS and CUBIT-ACIS (I'm guessing cubit?)
> Failing CGM build with --enable-shared option. Please find the config.log attached. I'm using a 32bit Ubuntu, cubit10.2. On removing shared option all tests pass.
> OCC
> --enable-shared option works till make;make install, but make check fails with:*** glibc detected ***
> so, export MALLOC_CHECK_=0 then run again, make check works, with 2 tests failing: makept and test_occ
Also, please report these as tickets, and please include the configure input.
- tim
> Rajeev
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
