[cgma-dev] enable shared
jain at mcs.anl.gov jain at mcs.anl.gov
Mon Mar 22 18:05:01 CDT 2010
ACIS
Failing CGM build with --enable-shared option. Please find the config.log attached. I'm using a 32bit Ubuntu, cubit10.2. On removing shared option all tests pass.
OCC
--enable-shared option works till make;make install, but make check fails with:*** glibc detected ***
so, export MALLOC_CHECK_=0 then run again, make check works, with 2 tests failing: makept and test_occ
Rajeev
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100322/e46154f6/attachment-0001.bin>
More information about the cgma-dev mailing list
