[cgma-dev] r3461 - cgm/branches/merge-cubit12/geom
kraftche at cae.wisc.edu
Thu Jan 21 19:24:38 CST 2010
Author: kraftche
Date: 2010-01-21 19:24:38 -0600 (Thu, 21 Jan 2010)
New Revision: 3461
Modified:
cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp
Log:
restore function lost during merge
Modified: cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp
--- cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp 2010-01-22 01:24:21 UTC (rev 3460)
+++ cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp 2010-01-22 01:24:38 UTC (rev 3461)
@@ -4420,7 +4420,7 @@
//Author: Jonathan Bugman
//Sept 10, 2006
-CubitStatus GeometryModifyTool::sweep_surface_target(CubitPlane ref_plane,
+CubitStatus GeometryModifyTool::sweep_surface_target( CubitPlane ref_plane,
DLIList<RefEntity*>& ref_ent_list)
DLIList<RefFace*> surface_list;
@@ -17481,3 +17481,142 @@
+CubitStatus GeometryModifyTool::prepare_surface_sweep(
+ DLIList<BodySM*> &blank_bodies,
+ DLIList<Surface*> &surfaces,
+ const CubitVector& sweep_vector,
+ bool sweep_perp,
+ bool through_all,
+ bool outward,
+ bool up_to_next,
+ Surface *stop_surf,
+ Curve *curve_to_sweep_along,
+ BodySM* &cutting_tool_ptr ,
+ const CubitVector* point,
+ double *angle)
+ GeometryModifyEngine* gme = get_engine(blank_bodies.get());
+ if(surfaces.size() == 0 )
+ return CUBIT_FAILURE;
+ DLIList<GeometryEntity*> ref_ent_list;
+ Surface * temp_face = NULL;
+ for(int i = 0; i < surfaces.size(); i++)
+ //copy the faces before sweep
+ temp_face = gme->make_Surface(surfaces.get_and_step());
+ if (temp_face)
+ ref_ent_list.append((GeometryEntity*)temp_face);
+ BodySM* to_body = NULL;
+ CubitStatus stat = CUBIT_SUCCESS;
+ if(up_to_next && blank_bodies.size() > 1) //unite all bland_bodies
+ DLIList<BodySM*> newBodies;
+ DLIList<BodySM*> copied_bodies;
+ for(int i = 0; i < blank_bodies.size(); i++)
+ copied_bodies.append(gme->copy_body(blank_bodies.get_and_step()));
+ stat = gme->unite(copied_bodies, newBodies);
+ if(stat == CUBIT_FAILURE)
+ PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n");
+ PRINT_INFO("Try the 'stop surface <id>' option instead\n");
+ return stat;
+ to_body = newBodies.get();
+ else if(up_to_next && blank_bodies.size() == 1)
+ to_body = gme->copy_body(blank_bodies.get());
+ DLIList<BodySM*> swept_bodies;
+ if (point && angle) //sweep_surface_rotated
+ stat = gme->sweep_rotational(ref_ent_list,swept_bodies,*point,
+ sweep_vector, *angle,0, 0.0,0,false,false,
+ false,stop_surf, to_body);
+ else
+ CubitVector tmp_sweep_vector = sweep_vector;
+ //get model bbox info...will scale sweep vector by its diagonal
+ //so that we go far enough
+ if( through_all || stop_surf || up_to_next)
+ CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
+ tmp_sweep_vector.normalize();
+ tmp_sweep_vector*=(2*bounding_box.diagonal().length());
+ //see if we're sweeping along a specified curve
+ if( curve_to_sweep_along )
+ DLIList<Curve*> curves_to_sweep_along;
+ curves_to_sweep_along.append(curve_to_sweep_along);
+ stat = gme->sweep_along_curve(ref_ent_list, swept_bodies,
+ curves_to_sweep_along, 0.0,0,false,stop_surf,
+ to_body);
+ else if (sweep_perp )
+ stat = gme->sweep_perpendicular(ref_ent_list, swept_bodies,
+ tmp_sweep_vector.length(),0.0,0,!outward,false,
+ stop_surf, to_body);
+ else
+ stat = gme->sweep_translational(ref_ent_list, swept_bodies,
+ tmp_sweep_vector,0.0,0, false, false, stop_surf,
+ to_body);
+ if(stat == CUBIT_FAILURE || swept_bodies.size() == 0)
+ //delete copied faces
+ GeometryEntity * temp_entity = NULL;
+ for(int i = ref_ent_list.size();i--;)
+ temp_entity = ref_ent_list.get_and_step();
+ if (temp_entity)
+ gme->get_gqe()->delete_solid_model_entities( (Surface*)temp_entity);
+ return stat;
+ //if there are more than 1, unite them all
+ if (swept_bodies.size() > 1)
+ stat = gme->unite(swept_bodies, newBodies);
+ else
+ newBodies = swept_bodies;
+ if(stat == CUBIT_FAILURE || newBodies.size()!= 1)
+ PRINT_ERROR("webcut tool body is not created from acis.\n");
+ //delete the swept_bodies
+ BodySM* tmp_body = NULL;
+ for (int i = swept_bodies.size(); i--;)
+ tmp_body= swept_bodies.get_and_step();
+ if (tmp_body)
+ gme->get_gqe()->delete_solid_model_entities(tmp_body);
+ if (temp_entity)
+ cutting_tool_ptr = newBodies.get();
+ return stat;
Property changes on: cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp
___________________________________________________________________
Modified: svn:mergeinfo
- /cgm/branches/cubit/geom/GeometryModifyTool.cpp:1041-3427
+ /cgm/branches/cubit/geom/GeometryModifyTool.cpp:1041-3427
/cgm/trunk/geom/GeometryModifyTool.cpp:3424-3459
More information about the cgma-dev
