[cgma-dev] buildbot failure in Fathom on cgm-shared
cgma-dev at lists.mcs.anl.gov
Thu Jan 21 23:16:24 CST 2010
The Fathomatic has detected a failed build of cgm-shared on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-shared/builds/0
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The web-page 'force build' button was pressed by 'jvporter': Testing build...
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
make[1]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build'
cd . && /bin/sh ./config.status config.h
config.status: creating config.h
config.status: config.h is unchanged
make all-recursive
make[2]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build'
Making all in compat
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/compat'
make[3]: Nothing to be done for `all'.
Making all in util
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/util'
Making all in geom
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom'
Making all in .
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom'
make[4]: Nothing to be done for `all-am'.
Making all in Cholla
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom/Cholla'
make[4]: Nothing to be done for `all'.
Making all in facetbool
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom/facetbool'
Making all in facet
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom/facet'
Making all in virtual
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/geom/virtual'
Making all in init
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build/init'
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DCUBIT_CGM -I. -I.. -I../geom/parallel -I../itaps -I../geom -I../util -I../geom/ACIS -I../geom/OCC -I../geom/virtual -I../geom/facet -I../geom/cholla -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c -o InitCGMA.lo InitCGMA.cpp
mkdir .libs
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DCUBIT_CGM -I. -I.. -I../geom/parallel -I../itaps -I../geom -I../util -I../geom/ACIS -I../geom/OCC -I../geom/virtual -I../geom/facet -I../geom/cholla -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c InitCGMA.cpp -fPIC -DPIC -o .libs/InitCGMA.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DCUBIT_CGM -I. -I.. -I../geom/parallel -I../itaps -I../geom -I../util -I../geom/ACIS -I../geom/OCC -I../geom/virtual -I../geom/facet -I../geom/cholla -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c InitCGMA.cpp -o InitCGMA.o >/dev/null 2>&1
mv -f .deps/InitCGMA.Tpo .deps/InitCGMA.Plo
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcgma_init.la InitCGMA.lo -lm
ar cru .libs/libcgma_init.a .libs/InitCGMA.o
ranlib .libs/libcgma_init.a
creating libcgma_init.la
(cd .libs && rm -f libcgma_init.la && ln -s ../libcgma_init.la libcgma_init.la)
Making all in .
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-shared/build'
/bin/sh ./libtool --tag=CC --mode=link cc -Wall -pipe -pedantic -O2 -DNDEBUG -o libcgm.la -rpath /home/jvporter/buildslave1/packages/cgm-shared/lib init/libcgma_init.la -lcubiti19 /home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin/libcubiti19.so -lm
mkdir .libs
cc -shared -Wl,--whole-archive init/.libs/libcgma_init.a -Wl,--no-whole-archive -lcubiti19 -lm -Wl,-soname -Wl,libcgm.so.0 -o .libs/libcgm.so.0.0.0
/usr/bin/ld: cannot find -lcubiti19
collect2: ld returned 1 exit status
sincerely,
-The Fathomatic
More information about the cgma-dev
