[cgma-dev] r3460 - cgm/branches/merge-cubit12/test
kraftche at cae.wisc.edu
Thu Jan 21 19:24:21 CST 2010
Author: kraftche
Date: 2010-01-21 19:24:21 -0600 (Thu, 21 Jan 2010)
New Revision: 3460
Modified:
cgm/branches/merge-cubit12/test/webcut.cpp
Log:
merge fixes from trunk
Modified: cgm/branches/merge-cubit12/test/webcut.cpp
--- cgm/branches/merge-cubit12/test/webcut.cpp 2010-01-22 00:26:49 UTC (rev 3459)
+++ cgm/branches/merge-cubit12/test/webcut.cpp 2010-01-22 01:24:21 UTC (rev 3460)
@@ -34,7 +34,8 @@
#define XSTRINGIFY(S) #S
// forward declare some functions used and defined later
-CubitStatus read_geometry(int, char **);
+void read_geometry(int, char **);
+void read_model6( Body*& brick, Body*& sheet );
CubitStatus evaluate_overlaps();
CubitStatus imprint_bodies();
CubitStatus print_unmerged_surfaces();
@@ -51,7 +52,7 @@
CubitStatus webcut_with_sweep_surfaces_along_curve();
CubitStatus webcut_with_sweep_surfaces_perp();
// macro for printing a separator line
-#define PRINT_SEPARATOR PRINT_INFO("=======================================\n");
+#define PRINT_SEPARATOR PRINT_INFO("===================%s:%d===================\n",__FILE__,__LINE__);
// main program - initialize, then send to proper function
@@ -91,7 +92,7 @@
/// Arguments: file name(s) of geometry files in which to look
-CubitStatus read_geometry(int num_files, const char **argv)
+void read_geometry(int num_files, const char **argv)
CubitStatus status = CUBIT_SUCCESS;
GeometryQueryTool *gti = GeometryQueryTool::instance();
@@ -99,19 +100,52 @@
int i;
// For each file, open and read the geometry
- PRINT_SEPARATOR;
for (i = 0; i < num_files; i++) {
status = gti->import_solid_model(argv[i], "ACIS_SAT");
if (status != CUBIT_SUCCESS) {
PRINT_ERROR("Problems reading geometry file %s.\n", argv[i]);
+ abort();
- PRINT_SEPARATOR;
- return CUBIT_SUCCESS;
+ if (gti->num_bodies() == 0) {
+ PRINT_ERROR("No bodies read; aborting.\n");
+ abort();
+void read_model6( Body*& volume, Body*& sheet )
+ const char *filename = STRINGIFY(SRCDIR) "/model6.sat";
+ read_geometry( 1, &filename );
+ DLIList<Body*> bodies;
+ GeometryQueryTool::instance()->bodies(bodies);
+ volume = sheet = 0;
+ for (int i = 0; i < bodies.size(); ++i, bodies.step()) {
+ DLIList<RefVolume*> vols;
+ bodies.get()->ref_volumes( vols );
+ if (vols.size() != 1) {
+ PRINT_ERROR("Unexpected number of volumes in body read from file: %s\n", filename);
+ abort();
+ if (vols.get()->is_sheet()) {
+ if (sheet) {
+ PRINT_ERROR("Unexpected number of sheet bodies read from file: %s\n",filename);
+ abort();
+ sheet = bodies.get();
+ else {
+ if (volume) {
+ PRINT_ERROR("Unexpected number of non-sheet bodies read from file: %s\n",filename);
+ abort();
+ volume = bodies.get();
CubitStatus webcut_with_brick()
@@ -119,14 +153,8 @@
// Read in the geometry from files specified on the command line
const char *argv = STRINGIFY(SRCDIR) "/model2.sat";
- CubitStatus status = read_geometry(1, &argv);
- if (status == CUBIT_FAILURE) exit(1);
- else if (gti->num_bodies() == 0) {
- PRINT_WARNING("No bodies read; exiting.\n");
- int ret_val = ( CubitMessage::instance()->error_count() );
- exit(ret_val);
+ PRINT_SEPARATOR;
+ read_geometry(1, &argv);
//int num_bodies = gti->num_bodies();
DLIList<Body*> old_bodies, new_bodies,junk;
@@ -151,18 +179,7 @@
rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
num_ents_exported, cubit_version);
- //delete all entities
- DLIList<Body*> bodies;
- gti->bodies(bodies);
- DLIList<RefEntity*> free_entities;
- gti->get_free_ref_entities(free_entities);
- gti->delete_Body(bodies);
- for (int j = free_entities.size(); j--;)
- gti->delete_RefEntity( free_entities.get_and_step());
+ gti->delete_geometry();
return rsl;
@@ -174,14 +191,8 @@
- exit(ret_val);
+ PRINT_SEPARATOR;
DLIList<Body*> old_bodies, new_bodies, junk;
gti->bodies(old_bodies);
@@ -202,18 +213,7 @@
return rsl;
@@ -225,15 +225,9 @@
+ PRINT_SEPARATOR;
- exit(ret_val);
old_bodies.reset();
@@ -255,18 +249,7 @@
return rsl;
@@ -279,14 +262,8 @@
const char *argv = STRINGIFY(SRCDIR) "/huge.sat";
- exit(ret_val);
+ PRINT_SEPARATOR;
@@ -323,18 +300,7 @@
- free_entities.clean_out();
return rsl;
@@ -345,15 +311,9 @@
const char *argv = STRINGIFY(SRCDIR) "/model3.sat";
+ PRINT_SEPARATOR;
- exit(ret_val);
@@ -383,18 +343,7 @@
return rsl;
@@ -405,14 +354,8 @@
- exit(ret_val);
+ PRINT_SEPARATOR;
@@ -454,18 +397,7 @@
return rsl;
@@ -476,14 +408,8 @@
const char *argv = STRINGIFY(SRCDIR) "/model4.sat";
- exit(ret_val);
+ PRINT_SEPARATOR;
@@ -511,18 +437,7 @@
return rsl;
@@ -533,15 +448,9 @@
const char *argv = STRINGIFY(SRCDIR) "/model5.sat";
+ PRINT_SEPARATOR;
- exit(ret_val);
@@ -555,8 +464,10 @@
ref_faces.append(refface);
int num_cut = 0;
CubitStatus rsl= gmti->webcut_with_extended_sheet(old_bodies,ref_faces,new_bodies, junk, num_cut);
- if (rsl== CUBIT_FAILURE)
+ if (rsl== CUBIT_FAILURE) {
return rsl;
DLIList<RefEntity*> ref_entity_list;
int num_ents_exported=0;
@@ -566,12 +477,7 @@
return rsl;
@@ -582,14 +488,8 @@
const char *argv = STRINGIFY(SRCDIR) "/model7.sat";
- exit(ret_val);
+ PRINT_SEPARATOR;
@@ -616,12 +516,7 @@
return rsl;
@@ -630,29 +525,17 @@
GeometryModifyTool *gmti = GeometryModifyTool::instance();
- // Read in the geometry from files specified on the command line
- const char *argv = STRINGIFY(SRCDIR) "/model6.sat";
- exit(ret_val);
+ // Read file containing one block and one sheet body
+ PRINT_SEPARATOR;
+ Body *vol, *sheet;
+ read_model6( vol, sheet );
- gti->bodies(old_bodies);
- old_bodies.reset();
- old_bodies.step();
+ old_bodies.append( vol );
DLIList<RefFace*> faces;
- old_bodies.remove()->ref_faces(faces);
+ sheet->ref_faces( faces );
- CubitVector axis;
- axis.set(1.,0.,0.);
+ CubitVector axis(1.,0.,0.);
CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,false,true,false, false,NULL,NULL,new_bodies, junk);
@@ -666,12 +549,7 @@
return rsl;
@@ -680,25 +558,15 @@
- exit(ret_val);
+ PRINT_SEPARATOR;
//use curve 2 as the sweep along curve
DLIList<RefEdge*> temp_curves;
@@ -710,8 +578,7 @@
edge_to_sweep_along = temp_curves.get_and_step();
- CubitVector axis;
CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,false, true,false,false,NULL,
edge_to_sweep_along,new_bodies, junk);
@@ -726,12 +593,7 @@
return rsl;
@@ -740,31 +602,19 @@
- exit(ret_val);
+ PRINT_SEPARATOR;
- CubitVector axis;
- CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,true,true,true, false,NULL,NULL,new_bodies,junk);
+ CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,true,true,false, false,NULL,NULL,new_bodies,junk);
return rsl;
@@ -776,12 +626,7 @@
return rsl;
More information about the cgma-dev
