[cgma-dev] Issues with multiple instances of iGeom
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Wed Sep 23 14:49:30 CDT 2009
James Porter wrote:
> I'm using a more-or-less nightly build of CGM as the backend for the
> Python iGeom stuff, and I ran across some issues with unit-testing.
> Specifically, it seems impossible to have multiple instances of iGeom
> without things getting confused, even if you only have one instance at a
> time.
This is a known issue and not easily correctable w/out a lot of cleanups
within CGM.
> While it's probably not the only issue, it seems that entity sets are
> stored statically and don't go away when you destroy an iGeom instance.
> My (very brief) reading of the CGM code suggests that this isn't going
> to be an easy thing to fix, but it seems like a pretty significant
> problem to me.
The entire model is probably stored "statically".
- jason
More information about the cgma-dev
