[cgma-dev] build issues, libtool
    Steve Jackson
    sjackson at cae.wisc.edu
    Fri Sep 18 09:52:23 CDT 2009
Hi Jed,
On Thu, Sep 17, 2009 at 11:35:41PM -0500, Jed Brown wrote:
> After working around the broken libtool, CGM seems to be built, but I
> had to kill the test suite after it was demanding more than 5GB of
> memory.  Make check gives the output below (I killed it from elsewhere).
> Is this a memory leak, or is it actually doing a stress test that I just
> don't have enough memory for?  I'll get you a stack trace if that would
> be helpful.
An iGeom test that was recently added to the test suite throws testgeom_occ
into infinite recursion, causing the enormous memory demand you observed.
I've alerted one of the lead developers of the issue.
~S
More information about the cgma-dev
