[cgma-dev] build issues, libtool
    tautges at mcs.anl.gov
    Fri Sep 18 10:27:30 CDT 2009
Jed is about to get on a long flight (said lead developer just dropped
him off...). :)
- tim
On Sep 18, 2009, at 11:00 AM, Steve Jackson <sjackson at cae.wisc.edu>
wrote:
> Hi Jed,
> On Thu, Sep 17, 2009 at 11:35:41PM -0500, Jed Brown wrote:
>> After working around the broken libtool, CGM seems to be built, but I
>> had to kill the test suite after it was demanding more than 5GB of
>> memory.  Make check gives the output below (I killed it from
>> elsewhere).
>> Is this a memory leak, or is it actually doing a stress test that I
>> just
>> don't have enough memory for?  I'll get you a stack trace if that
>> would
>> be helpful.
> An iGeom test that was recently added to the test suite throws
> testgeom_occ
> into infinite recursion, causing the enormous memory demand you
> observed.
> I've alerted one of the lead developers of the issue.
> ~S
More information about the cgma-dev
