[cgma-dev] CAEntityId::CAEntityId(RefEntity*,	CubitSimpleAttrib*): Assertion `i_list && i_list->size() > 0' failed
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Wed Apr  8 11:45:49 CDT 2009
BTW, I've changed the format of brep file with attributes to be able to port the file to other brep reading softwares. So if you have old version of brep file with attributes that are generated last month, you need to run through your code again, re-write the brep file adding attributes, then re-read in. Don't know if it solves the problem.
Jane
--- On Wed, 4/8/09, Jed Brown <jed at 59A2.org> wrote:
> From: Jed Brown <jed at 59A2.org>
> Subject: [cgma-dev] CAEntityId::CAEntityId(RefEntity*, CubitSimpleAttrib*): Assertion `i_list && i_list->size() > 0' failed
> To: cgma-dev at mcs.anl.gov
> Date: Wednesday, April 8, 2009, 7:23 AM
> With latest CGMA (rev 2805), my `cube' test case
> demonstrates it.  Trace below.
> Jed
> $ gdb --args ./cube -read
> (gdb) r
> Starting program: /home/jed/iMesh/cube/cube -read
> [Thread debugging using libthread_db enabled]
> cube: ../../geom/CAEntityId.cpp:49:
> failed.
> [New Thread 0x7f51fb59b700 (LWP 18215)]
> Program received signal SIGABRT, Aborted.
> [Switching to Thread 0x7f51fb59b700 (LWP 18215)]
> 0x00007f51f377e0c5 in raise () from /lib/libc.so.6
> (gdb) bt
> #0  0x00007f51f377e0c5 in raise () from /lib/libc.so.6
> #1  0x00007f51f377f5e3 in abort () from /lib/libc.so.6
> #2  0x00007f51f37770e9 in __assert_fail () from
> /lib/libc.so.6
> #3  0x00007f51fa86176a in CAEntityId (this=0x1589f40,
> new_attrib_owner=0x15c40f8, csa_ptr=0x15c3fc0) at
> #4  0x00007f51fa8619e2 in CAEntityId_creator
> (entity=0x15c40f8, p_csa=0x15c3fc0) at
> ../../geom/CAEntityId.cpp:32
> #5  0x00007f51fa87115d in
> CubitAttribManager::create_cubit_attrib (this=0x1551f48,
> attrib_type=3, attrib_user=0x15c40f8, p_csa=0x15c3fc0)
>     at ../../geom/CubitAttribManager.cpp:156
> #6  0x00007f51fa876ce9 in
> CubitAttribUser::auto_read_cubit_attrib (this=0x15c4128) at
> ../../geom/CubitAttribUser.cpp:854
> #7  0x00007f51fa926f72 in RefEdge::initialize
> (this=0x15c40c0) at ../../geom/RefEdge.cpp:1308
> #8  0x00007f51fa92849f in RefEdge (this=0x15c40c0,
> curvePtr=0x15bff30) at ../../geom/RefEdge.cpp:71
> #9  0x00007f51fa92ff92 in
> RefEntityFactory::construct_RefEdge (this=0x1552490,
> curve=0x15bff30) at ../../geom/RefEntityFactory.cpp:59
> #10 0x00007f51fa8be210 in GeometryQueryTool::make_RefEdge
> (this=0x1552420, curve_ptr=0x15bff30) at
> ../../geom/GeometryQueryTool.cpp:1764
> #11 0x00007f51fa8c0366 in GeometryQueryTool::make_RefFace
> (this=0x1552420, surface_ptr=0x15bfc70) at
> ../../geom/GeometryQueryTool.cpp:1324
> #12 0x00007f51fa8c162b in GeometryQueryTool::make_Shell
> (this=0x1552420, shellsm_ptr=0x158bde0,
> shell_modified=@0x7fff035e6b7f)
>     at ../../geom/GeometryQueryTool.cpp:1094
> #13 0x00007f51fa8c1ca8 in GeometryQueryTool::make_RefVolume
> (this=0x1552420, lump_ptr=0x15899c0,
> volume_modified=@0x7fff035e6d2f)
>     at ../../geom/GeometryQueryTool.cpp:1024
> #14 0x00007f51fa8c2157 in GeometryQueryTool::make_Body
> (this=0x1552420, bodysm_ptr=0x15593d0) at
> ../../geom/GeometryQueryTool.cpp:930
> #15 0x00007f51fa8c2ac6 in
> GeometryQueryTool::construct_refentities (this=0x1552420,
> bridge_list=@0x7fff035e72e0, imported_entities=0x0)
>     at ../../geom/GeometryQueryTool.cpp:682
> #16 0x00007f51fa8c40ad in
> GeometryQueryTool::import_solid_model (this=0x1552420,
> file_name=0x159f4f0 "cube.brep",
> file_type=0x7f51fad2d0e5 "OCC",
>     logfile_name=0x0, heal_step=true, import_bodies=true,
> import_surfaces=true, import_curves=true,
> import_vertices=true, free_surfaces=true,
>     imported_entities=0x0) at
> ../../geom/GeometryQueryTool.cpp:636
> #17 0x00007f51fa8c54a0 in
> GeometryQueryTool::read_geometry_file (this=0x1552420,
> fileName=0x1559588 "cube.brep", includePath=0x0,
> type=0x7f51fad2d0e5 "OCC")
>     at ../../geom/GeometryQueryTool.cpp:213
> #18 0x00007f51fad2621a in igeom_load_
> (instance=0x7f51faf38da0, name=0x1559588
> "cube.brep", options=0x405eb7
> ";TYPE=OCC;", err=0x7fff035e75ac, name_len=10,
>     options_size=11) at ../../itaps/iGeom_CGMA.cc:362
> #19 0x000000000040558f in main (argc=2,
> argv=0x7fff035e76d8) at cube.c:354
> (gdb) quit
More information about the cgma-dev
