[cgma-dev] CAEntityId::CAEntityId(RefEntity*,	CubitSimpleAttrib*): Assertion `i_list && i_list->size() > 0' failed
    Jed Brown
    jed at 59A2.org
    Wed Apr  8 11:38:22 CDT 2009
On Wed 2009-04-08 09:28, Jiangtao Hu wrote:
> Hi, Jed
> I just restored OCCCoEdge.?pp files since they don't really contribute to the fix of the memory errors in 2805's check in.
> I don't see OCCLoop.cpp's change will affect the entityId crash you saw. can you first update the source and check if your error has gone away; if not, can you provide the code on how to reproduce the problem?
Updated, but it's still there.  Test attached (same as before, but the
Makefile is updated to explicitly link IGEOM_LIBS and IMESH_LIBS).
Jed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090408/43a9fed4/attachment.obj>
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090408/43a9fed4/attachment.pgp>
More information about the cgma-dev
