[cgma-dev] r2688 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Mar 6 12:26:16 CST 2009
Author: janehu
Date: 2009-03-06 12:26:16 -0600 (Fri, 06 Mar 2009)
New Revision: 2688
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added function create_offset_surface.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 17:52:24 UTC (rev 2687)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 18:26:16 UTC (rev 2688)
@@ -6413,9 +6413,31 @@
BodySM*& new_body,
double offset ) const
- PRINT_ERROR("Function not implemented because offset_distance \n"
- "doesn't show offset direction.\n");
- return CUBIT_FAILURE;
+ //create offset surface from its center along center normal of distance
+ //"offset"
+ OCCSurface *occ_surface = CAST_TO(face_ptr, OCCSurface);
+ if (occ_surface == NULL)
+ PRINT_ERROR("Option not supported for non-occ based geometry.\n");
+ return CUBIT_FAILURE;
+ Surface* c_surface = NULL;
+ c_surface = make_Surface(occ_surface);
+ if (c_surface == NULL)
+ PRINT_ERROR("Cannot copy surface in sweep_translational.\n");
+ occ_surface = CAST_TO(c_surface, OCCSurface);
+ CubitVector center = occ_surface->center_point();
+ CubitVector normal;
+ occ_surface->closest_point(center,NULL,&normal);
+ CubitVector v = normal * offset;
+ OCCQueryEngine::instance()->translate(occ_surface, v);
+ new_body = occ_surface->my_body();
+ return CUBIT_SUCCESS;
More information about the cgma-dev
