[cgma-dev] r2687 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Mar 6 11:52:24 CST 2009
Author: janehu
Date: 2009-03-06 11:52:24 -0600 (Fri, 06 Mar 2009)
New Revision: 2687
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added surface_intersection function.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 16:48:55 UTC (rev 2686)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 17:52:24 UTC (rev 2687)
@@ -5533,50 +5533,89 @@
// Function : get_offset_intersections
// Member Type: PUBLIC
// Description:
-// Author : John Fowler
-// Date : 10/02
+// Author : Jane Hu
+// Date : 03/09
-CubitStatus OCCModifyEngine::get_offset_intersections( Curve* /*ref_edge1*/,
- Curve* /*ref_edge2*/,
- DLIList<CubitVector*>& /*intersection_list*/,
- double /*offset*/,
- CubitBoolean /*ext_first*/ )
+CubitStatus OCCModifyEngine::get_offset_intersections( Curve* curve1,
+ Curve* curve2,
+ DLIList<CubitVector*>& out_list,
+ double offset,
+ CubitBoolean ext_first )
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ return CUBIT_SUCCESS;
// Description:
-// Date : 10/02
+// Date : 03/09
-CubitStatus OCCModifyEngine::get_offset_intersections( Curve* /*ref_edge_ptr*/,
- Surface* /*ref_face_ptr*/,
- DLIList<CubitVector*> & /*intersection_list*/,
- CubitBoolean /*ext_surf*/ )
+ Surface* face_ptr,
+ DLIList<CubitVector*> & out_list,
+ double offset,
+ CubitBoolean ext_surf )
// Function : surface_intersection
// Description:
-// Date : 10/02
+// Date : 03/09
-CubitStatus OCCModifyEngine::surface_intersection( Surface * /*surface1_ptr*/,
- Surface * /*surface2_ptr*/,
- DLIList<Curve*> &/*inter_graph*/,
- const double /*tol*/) const
+CubitStatus OCCModifyEngine::surface_intersection( Surface * surface1,
+ Surface * surface2,
+ DLIList<Curve*> &intscts,
+ const double tol) const
+ OCCSurface *occ_surface1 = CAST_TO(surface1, OCCSurface);
+ if (occ_surface1 == NULL)
+ PRINT_ERROR("Option not supported for non-occ based geometry.\n");
+ return CUBIT_FAILURE;
+ OCCSurface *occ_surface2 = CAST_TO(surface2, OCCSurface);
+ if (occ_surface2 == NULL)
+ //currently, there's no effect on 'closest' argument or bounded.
+ BRepExtrema_DistShapeShape distShapeShape(*(occ_surface1->get_TopoDS_Face()),
+ *(occ_surface2->get_TopoDS_Face()));
+ //distShapeShape.Perform();
+ if (!distShapeShape.IsDone())
+ PRINT_ERROR("Cannot calculate the intersection points for the input curve and surface.\n");
+ if (distShapeShape.Value() < tol) //intersect
+ int numSol = distShapeShape.NbSolution();
+ for (int i = 1; i <= numSol; i++)
+ TopoDS_Shape shape = distShapeShape.SupportOnShape1(i);
+ if(shape.ShapeType() != TopAbs_EDGE)
+ continue;
+ TopoDS_Edge* edge = new TopoDS_Edge(TopoDS::Edge(shape));
+ OCCCurve* cv = new OCCCurve(edge);
+ intscts.append(cv);
@@ -6370,9 +6409,9 @@
// Author : Jane Hu
// Date : 01/09
-CubitStatus OCCModifyEngine::create_offset_surface( Surface* /*ref_face_ptr*/,
- BodySM*& /*new_body*/,
- double /*offset_distance*/ ) const
+CubitStatus OCCModifyEngine::create_offset_surface( Surface* face_ptr,
+ BodySM*& new_body,
+ double offset ) const
PRINT_ERROR("Function not implemented because offset_distance \n"
"doesn't show offset direction.\n");
More information about the cgma-dev
