[cgma-dev] r2689 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Mar 6 13:08:41 CST 2009
Author: janehu
Date: 2009-03-06 13:08:39 -0600 (Fri, 06 Mar 2009)
New Revision: 2689
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added create_offset_intersection funtion for curve surface intersection.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 18:26:16 UTC (rev 2688)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-06 19:08:39 UTC (rev 2689)
@@ -5542,7 +5542,9 @@
double offset,
CubitBoolean ext_first )
+ //offset the curve1 in both directions of normal direction of two curves at
+ //center points.
return CUBIT_SUCCESS;
@@ -5559,8 +5561,41 @@
double offset,
CubitBoolean ext_surf )
+ Surface* new_surface = face_ptr;
+ if(ext_surf)
+ new_surface = make_Surface(face_ptr, CUBIT_TRUE);
+ BodySM* bodysm = NULL;
+ CubitStatus status = CUBIT_SUCCESS;
+ status = create_offset_surface(new_surface, bodysm, offset);
+ if(status == CUBIT_FAILURE)
+ PRINT_ERROR("Can't offset surface. \n");
+ return status;
+ OCCSurface* surface = CAST_TO(bodysm, OCCBody)->my_sheet_surface();
+ status = OCCQueryEngine::instance()->get_intersections(curve1, surface, out_list);
- return CUBIT_SUCCESS;
+ if(ext_surf || offset)
+ OCCQueryEngine::instance()->delete_solid_model_entities(surface);
+ //offset surface in opposite direction
+ if(!offset)
+ return status;
+ status = create_offset_surface(new_surface, bodysm, -offset);
+ return status;
+ surface = CAST_TO(bodysm, OCCBody)->my_sheet_surface();
+ if(ext_surf)
+ OCCQueryEngine::instance()->delete_solid_model_entities(new_surface);
+ return status;
More information about the cgma-dev
