[cgma-dev] r2677 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Tue Mar 3 11:08:39 CST 2009
Author: janehu
Date: 2009-03-03 11:08:38 -0600 (Tue, 03 Mar 2009)
New Revision: 2677
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Added bounding-box check for generated prism and pyramid, the key of them is that the x coordinates of the same sides prism or pyramid have the cooresponding values. Fixed the build problem.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-03 17:08:28 UTC (rev 2676)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-03 17:08:38 UTC (rev 2677)
@@ -1339,6 +1339,7 @@
TopoDS_Face base = BRepBuilderAPI_MakeFace(wire, Standard_True);
gp_Dir main_dir(0.0, 0.0, 1.0);
gp_Vec norm(main_dir);
+ norm *= height;
BRepSweep_Prism swept(base, norm);
TopoDS_Shape new_shape = swept.Shape();
DLIList<TopologyBridge*> tbs;
@@ -1406,41 +1407,34 @@
double minor, double top) const
TopoDS_Solid S;
- if (sides == 4)
- S = BRepPrimAPI_MakeWedge( 2 * major, 2* minor, height, 2 * top);
+ //build the top and bottom shapes.
+ TopoDS_Wire wire_bottom ;
+ make_base_for_prim_pyramid(major, minor, height, sides, wire_bottom);
+ double top_minor = top * minor / major;
+ TopoDS_Wire wire_top ;
+ BRepOffsetAPI_ThruSections builder(CUBIT_TRUE, CUBIT_TRUE);
+ builder.AddWire(wire_bottom);
+ if(top > TOL)
+ make_base_for_prim_pyramid(top, top_minor, -height, sides, wire_top);
+ builder.AddWire(wire_top);
else
- //build the top and bottom shapes.
- TopoDS_Wire wire_bottom ;
- make_base_for_prim_pyramid(major, minor, height, sides, wire_bottom);
- double top_minor = top * minor / major;
- TopoDS_Wire wire_top ;
- BRepOffsetAPI_ThruSections builder(CUBIT_TRUE, CUBIT_TRUE);
- builder.AddWire(wire_bottom);
- if(top > TOL)
- make_base_for_prim_pyramid(top, top_minor, -height, sides, wire_top);
- builder.AddWire(wire_top);
- else
- gp_Pnt pt = gp_Pnt( 0.0, 0.0, height/2.0);
- TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(pt);
- builder.AddVertex(theVertex);
- builder.Build() ;
- S = TopoDS::Solid(builder.Shape());
+ gp_Pnt pt = gp_Pnt( 0.0, 0.0, height/2.0);
+ TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(pt);
+ builder.AddVertex(theVertex);
+ builder.Build() ;
+ S = TopoDS::Solid(builder.Shape());
Lump* lump = OCCQueryEngine::instance()->populate_topology_bridge(S,
CUBIT_TRUE);
if (lump == NULL)
return (BodySM*)NULL;
BodySM* body = CAST_TO(lump, OCCLump)->get_body();
- if(body && sides == 4)
- CAST_TO(body, OCCBody)->move(-major, -minor, -height/2.0);
return body;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2009-03-03 17:08:28 UTC (rev 2676)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2009-03-03 17:08:38 UTC (rev 2677)
@@ -26,6 +26,7 @@
class OCCCurve;
class TopoDS_Shape;
class TopoDS_Edge;
+class TopoDS_Wire;
class TopoDS_Face;
class CubitBox;
class BRepAlgoAPI_BooleanOperation;
More information about the cgma-dev
