[cgma-dev] r2676 - cgm/trunk/test
jiangtao_ma at yahoo.com
Tue Mar 3 11:08:28 CST 2009
Author: janehu
Date: 2009-03-03 11:08:28 -0600 (Tue, 03 Mar 2009)
New Revision: 2676
Modified:
cgm/trunk/test/makept.cpp
Log:
Added bounding-box check for generated prism and pyramid, the key of them is that the x coordinates of the same sides prism or pyramid have the cooresponding value.
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2009-03-03 15:54:05 UTC (rev 2675)
+++ cgm/trunk/test/makept.cpp 2009-03-03 17:08:28 UTC (rev 2676)
@@ -130,6 +130,17 @@
rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
num_ents_exported, cubit_version);
+ CubitBox box1 = prism1->bounding_box();
+ //(-5.0, -1.949, -5.0) to (4.504, 1.949, 5.0)
+ box1 = prism2->bounding_box();
+ //(-5.0, -4.874, -5.0) to (4.504, 4.874, 5.0)
+ box1 = prism3->bounding_box();
+ //(-4.619, -1.847, -5.0) to (4.619, 1.847, 5.0)
+ box1 = prism4->bounding_box();
+ // (-4.619, -4.619, -5.0) to (4.619, 4.619, 5.0)
DLIList<Body*> bodies;
gti->bodies(bodies);
gti->delete_Body(bodies);
@@ -139,8 +150,8 @@
Body* pyramid2 = gmti->pyramid(10, 7, 5, 5, 2);
Body* pyramid3 = gmti->pyramid(10, 8, 5, 2, 2);
Body* pyramid4 = gmti->pyramid(10, 8, 5, 5, 2);
- Body* pyramid5 = gmti->pyramid(10, 8, 5, 2, 0);
- Body* pyramid6 = gmti->pyramid(10, 8, 5, 5, 0);
+ Body* pyramid5 = gmti->pyramid(10, 4, 5, 2, 0);
+ Body* pyramid6 = gmti->pyramid(10, 4, 5, 5, 0);
ref_entity_list.clean_out();
num_ents_exported=0;
filename = "pyramid.brep";
@@ -148,6 +159,24 @@
+ box1 = pyramid1->bounding_box();
+ box1 = pyramid2->bounding_box();
+ box1 = pyramid3->bounding_box();
+ //(-4.619, -1.847, -5.0) to (4.619, 1.847, 5.0);
+ box1 = pyramid4->bounding_box();
+ //(-4.619, -4.619, -5.0) to (4.619, 4.619, 5.0)
+ box1 = pyramid5->bounding_box();
+ //(-3.535, -1.414, -5.0) to (3.535, 1.414, 5.0)
+ box1 = pyramid6->bounding_box();
+ //(-3.535, -3.535, -5.0) to (3.535, 3.535, 5.0)
bodies.clean_out();
More information about the cgma-dev
