[cgma-dev] r2678 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Tue Mar 3 15:08:46 CST 2009
Author: janehu
Date: 2009-03-03 15:08:46 -0600 (Tue, 03 Mar 2009)
New Revision: 2678
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added reverse_body function.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-03 17:08:38 UTC (rev 2677)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-03 21:08:46 UTC (rev 2678)
@@ -1613,7 +1613,8 @@
return (BodySM *)NULL;
- return CAST_TO(surface,OCCSurface)->my_body();
+ OCCSurface* occ_surf = CAST_TO(surface, OCCSurface);
+ return occ_surf->my_body();
if(OCCQueryEngine::instance()->OCCMap->IsBound(*theCS))
@@ -4757,11 +4758,153 @@
// Function : reverse_body
// Member Type: PUBLIC
// Description: Turn body inside-out
-// Author : Jason Kraftcheck
-// Date : 05/25/04
+// Author : Jane Hu
+// Date : 03/03/09
CubitStatus OCCModifyEngine::reverse_body( BodySM* body_ptr )
+ OCCBody* occ_body = CAST_TO(body_ptr, OCCBody);
+ if (!occ_body)
+ PRINT_ERROR("Cannot reverse a non-OCC bodySM .\n"
+ "Possible incompatible geometry engines.\n");
+ return CUBIT_FAILURE;
+ TopoDS_Shape* orig_S;
+ orig_S = occ_body->get_TopoDS_Shape();
+ TopoDS_Shape S;
+ BRep_Builder B;
+ if (orig_S->IsNull() ) //sheet body
+ OCCShell* occ_shell = occ_body->shell();
+ OCCSurface* occ_face = occ_body->my_sheet_surface();
+ if (occ_shell != NULL)
+ orig_S = occ_shell->get_TopoDS_Shell();
+ else
+ if (occ_face == NULL)
+ PRINT_ERROR("Cannot create an OCC sheet bodySM from the given bodySM.\n");
+ orig_S = occ_face->get_TopoDS_Face();
+ S = orig_S->EmptyCopied();
+ TopoDS_Iterator it(*orig_S);
+ while (it.More()) {
+ B.Add(S,it.Value().Reversed());
+ it.Next();
+ else
+ it.Next();
+ occ_body->set_TopoDS_Shape(TopoDS::CompSolid(S));
+ //Bind the new shape and its underlining sub-shapes.
+ TopExp_Explorer Ex_orig, Ex;
+ int k = -1;
+ Ex.Init(S, TopAbs_COMPSOLID);
+ Ex_orig.Init(*orig_S, TopAbs_COMPSOLID);
+ for (; Ex_orig.More(), Ex.More(); Ex_orig.Next(), Ex.Next())
+ if(OCCQueryEngine::instance()->OCCMap->IsBound(Ex.Current()))
+ k = OCCQueryEngine::instance()->OCCMap->Find(Ex_orig.Current());
+ OCCQueryEngine::instance()->OCCMap->UnBind(Ex_orig.Current());
+ OCCQueryEngine::instance()->OCCMap->Bind(Ex.Current(), k);
+ TopExp_Explorer Ex_old_solid, Ex_solid;
+ Ex_old_solid.Init(*orig_S,TopAbs_SOLID);
+ Ex_solid.Init(S, TopAbs_SOLID);
+ DLIList<Lump*> lumps = occ_body->lumps();
+ for (; Ex_old_solid.More(), Ex_solid.More(); Ex_old_solid.Next(), Ex_solid.Next())
+ k = OCCQueryEngine::instance()->OCCMap->Find(Ex_old_solid.Current());
+ OCCQueryEngine::instance()->OCCMap->UnBind(Ex_old_solid.Current());
+ OCCQueryEngine::instance()->OCCMap->Bind(Ex_solid.Current(), k);
+ OCCLump* occ_lump = CAST_TO(lumps.get_and_step(), OCCLump);
+ occ_lump->set_TopoDS_Solid(TopoDS::Solid(Ex_solid.Current()));
+ else
+ Lump *lump = occ_body->lumps().get();
+ OCCLump* occ_lump = CAST_TO(lump, OCCLump);
+ TopoDS_Solid solid = *(occ_lump->get_TopoDS_Solid());
+ k = OCCQueryEngine::instance()->OCCMap->Find(solid);
+ OCCQueryEngine::instance()->OCCMap->UnBind(solid);
+ TopExp_Explorer Ex_local;
+ Ex_local.Init(S, TopAbs_SOLID);
+ OCCQueryEngine::instance()->OCCMap->Bind(Ex_local.Current(), k);
+ occ_lump->set_TopoDS_Solid(TopoDS::Solid(Ex_local.Current()));
+ Ex.Init(S, TopAbs_SHELL);
+ Ex_orig.Init(*orig_S, TopAbs_SHELL);
+ OCCShell *shell = (OCCShell*)(OCCQueryEngine::instance()->OccToCGM->find(k))->second;
+ shell->set_TopoDS_Shell(TopoDS::Shell(Ex.Current()));
+ Ex.Init(S, TopAbs_FACE);
+ Ex_orig.Init(*orig_S, TopAbs_FACE);
+ OCCSurface *surface = (OCCSurface *)(OCCQueryEngine::instance()->OccToCGM->find(k))->second;
+ TopoDS_Face face = TopoDS::Face(Ex.Current());
+ surface->set_TopoDS_Face(face);
+ Ex.Init(S, TopAbs_WIRE);
+ Ex_orig.Init(*orig_S, TopAbs_WIRE);
+ OCCLoop* wire = (OCCLoop*)(OCCQueryEngine::instance()->OccToCGM->find(k))->second;
+ wire->set_TopoDS_Wire(TopoDS::Wire(Ex.Current()));
+ Ex.Init(S, TopAbs_EDGE);
+ Ex_orig.Init(*orig_S, TopAbs_EDGE);
+ OCCCurve* edge = (OCCCurve*)(OCCQueryEngine::instance()->OccToCGM->find(k))->second;
+ edge->set_TopoDS_Edge(TopoDS::Edge(Ex.Current()));
+ Ex.Init(S, TopAbs_VERTEX);
+ Ex_orig.Init(*orig_S, TopAbs_VERTEX);
+ OCCPoint* point = (OCCPoint*)(OCCQueryEngine::instance()->OccToCGM->find(k))->second;
+ point->set_TopoDS_Vertex(TopoDS::Vertex(Ex.Current()));
return CUBIT_SUCCESS;
More information about the cgma-dev
