[cgma-dev] Trouble building CGMA against 64-bit Cubit
    Paul Wilson
    wilsonp at engr.wisc.edu
    Tue Feb  3 11:37:21 CST 2009
Tim, Jason,
I added the following:
    * added <cubit_dir>/bin to LD_LIBRARY_PATH
    * added LFLAGS=.... as in email below (also tried LDFLAGS=....)
Attached is the config.log
I can't remember whether or not I saw this on the 32-bit build, but it
may have been preempted by an LD_LIBRARY_PATH or other fix?  I am pretty
sure that configure worked without any additional info.
Paul
Tim Tautges wrote:
> You need to add "LFLAGS=-R<cubit_dir>/bin" to the configure line, I
> think.  Jason, I'm assuming the link tests use parameters passed in
> this way.  Paul, I suspect this would be a problem on 32-bit as well;
> have you not seen that behavior there, or just not tried?
> There's a warning about this at the end of the configure run, but
> maybe that isn't finishing?
> - tim
> Paul Wilson wrote:
>> Hi,
>> I am trying to build CGMA and link against a 64-bit version of Cubit
>> 10.2:
>> configure --enable-optimize --disable-debug
>> --prefix=/opt/ecco/fusion-n/packages/cgm/builds/opt-cubit
>> --with-cubit=/opt/ecco/fusion-n/apps/cubit
>> and it fails with:
>> checking for AcisQueryEngine::instance_ in
>> /opt/ecco/fusion-n/apps/cubit/bin/libcubiti19.so... no
>> configure: error: "Cubit library not found in
>> /opt/ecco/fusion-n/apps/cubit/bin"
>> I am using:
>>    gcc v4.2.2
>>    libtool 1.5.26
>> Paul
Paul P H Wilson                  UW-Madison Engineering Physics
Associate Professor               419 Engineering Research Bldg
wilsonp at engr.wisc.edu                       1500 Engineering Dr
608/263-0807 fax:608/263-4499                 Madison, WI 53706
http://www.cae.wisc.edu/~wilsonp    http://www.engr.wisc.edu/ep
                       My calendar
http://www.google.com/calendar/embed?src=paul@nagus-wilson.net
          Contributing to the joy and improvement
                  of all those around me
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090203/829433e6/attachment-0001.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090203/829433e6/attachment-0001.diff>
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090203/829433e6/attachment-0001.bin>
More information about the cgma-dev
