[cgma-dev] Trouble building CGMA against 64-bit Cubit
Tim Tautges
tautges at mcs.anl.gov
Tue Feb 3 11:05:52 CST 2009
You need to add "LFLAGS=-R<cubit_dir>/bin" to the configure line, I
think. Jason, I'm assuming the link tests use parameters passed in this
way. Paul, I suspect this would be a problem on 32-bit as well; have
you not seen that behavior there, or just not tried?
There's a warning about this at the end of the configure run, but maybe
that isn't finishing?
- tim
Paul Wilson wrote:
> Hi,
> I am trying to build CGMA and link against a 64-bit version of Cubit 10.2:
> configure --enable-optimize --disable-debug
> --prefix=/opt/ecco/fusion-n/packages/cgm/builds/opt-cubit
> --with-cubit=/opt/ecco/fusion-n/apps/cubit
> and it fails with:
> checking for AcisQueryEngine::instance_ in
> /opt/ecco/fusion-n/apps/cubit/bin/libcubiti19.so... no
> configure: error: "Cubit library not found in
> /opt/ecco/fusion-n/apps/cubit/bin"
> I am using:
> gcc v4.2.2
> libtool 1.5.26
> Paul
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
