[cgma-dev] Trouble building CGMA against 64-bit Cubit
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Feb  3 10:59:06 CST 2009
Paul Wilson wrote:
> Hi,
> I am trying to build CGMA and link against a 64-bit version of Cubit 10.2:
> configure --enable-optimize --disable-debug
> --prefix=/opt/ecco/fusion-n/packages/cgm/builds/opt-cubit
> --with-cubit=/opt/ecco/fusion-n/apps/cubit
> and it fails with:
> checking for AcisQueryEngine::instance_ in
> /opt/ecco/fusion-n/apps/cubit/bin/libcubiti19.so... no
> configure: error: "Cubit library not found in
> /opt/ecco/fusion-n/apps/cubit/bin"
> I am using:
>    gcc v4.2.2
>    libtool 1.5.26
Could you please send the config.log file.  Also, please verify that cubit
is 64 bit (if your not certain) by doing:
  file /opt/ecco/fusion-n/apps/cubit/bin/libcubiti19.so
thanks,
- jason
More information about the cgma-dev
