[cgma-dev] r2094 - in cgm/trunk: geom geom/OCC test
janehu at mcs.anl.gov
Thu Sep 25 12:45:09 CDT 2008
Author: janehu
Date: 2008-09-25 12:45:08 -0500 (Thu, 25 Sep 2008)
New Revision: 2094
Modified:
cgm/trunk/geom/GeometryModifyTool.cpp
cgm/trunk/geom/OCC/OCCAttribSet.hpp
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCCoEdge.cpp
cgm/trunk/geom/OCC/OCCCoFace.cpp
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCCurve.hpp
cgm/trunk/geom/OCC/OCCDrawTool.cpp
cgm/trunk/geom/OCC/OCCLoop.cpp
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
cgm/trunk/geom/OCC/OCCParamTool.cpp
cgm/trunk/geom/OCC/OCCPoint.cpp
cgm/trunk/geom/OCC/OCCPoint.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/OCC/OCCSurface.hpp
cgm/trunk/test/modify.cpp
Log:
Changes for upgrading system to OpenCascade 6.3.
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -2906,6 +2906,7 @@
if (!sweep_finish("translational", body_list, result_list, change_newids))
status = CUBIT_FAILURE;
+ CAST_LIST( body_list, ref_ent_list, RefEntity);
return status;
Modified: cgm/trunk/geom/OCC/OCCAttribSet.hpp
--- cgm/trunk/geom/OCC/OCCAttribSet.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCAttribSet.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -12,7 +12,6 @@
#ifndef FACET_BRIDGE_HPP
#define FACET_BRIDGE_HPP
-#include "config.h"
#include <DLIList.hpp>
#include "TDF_Label.hxx"
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -14,7 +14,6 @@
// ********** BEGIN STANDARD INCLUDES **********
#include <assert.h>
// ********** END STANDARD INCLUDES **********
// ********** BEGIN CUBIT INCLUDES **********
#include "CubitDefines.h"
Modified: cgm/trunk/geom/OCC/OCCCoEdge.cpp
--- cgm/trunk/geom/OCC/OCCCoEdge.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCCoEdge.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -14,7 +14,6 @@
#include "CastTo.hpp"
Modified: cgm/trunk/geom/OCC/OCCCoFace.cpp
--- cgm/trunk/geom/OCC/OCCCoFace.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCCoFace.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -13,7 +13,6 @@
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -15,7 +15,6 @@
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -17,7 +17,6 @@
#include "Curve.hpp"
Modified: cgm/trunk/geom/OCC/OCCDrawTool.cpp
--- cgm/trunk/geom/OCC/OCCDrawTool.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCDrawTool.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -5,7 +5,6 @@
//- Author: Jane Hu
// ********** BEGIN OCC INCLUDES **********
#include "gp_Pnt.hxx"
#include "TopoDS.hxx"
#include "TopoDS_Face.hxx"
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -11,7 +11,6 @@
// Owner : Steven J. Owen
#include "OCCLoop.hpp"
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -12,7 +12,6 @@
#include <assert.h>
#include "OCCQueryEngine.hpp"
#include "OCCLump.hpp"
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -15,7 +15,6 @@
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -12,7 +12,6 @@
// Creation Date : 1/08
#include "gp_Ax2.hxx"
#include "gp_Dir.hxx"
@@ -26,6 +25,8 @@
#include "gp_Torus.hxx"
#include "BRepBuilderAPI_MakeShell.hxx"
#include "BRepBuilderAPI_MakeSolid.hxx"
+#include "BRepOffsetAPI_MakeDraft.hxx"
+#include "BRepBuilderAPI_TransitionMode.hxx"
#include "BRepBuilderAPI_MakeWire.hxx"
#include "TopoDS_Shape.hxx"
#include "TopAbs_Orientation.hxx"
@@ -1072,13 +1073,40 @@
//check to make sure the aShell is closed.
int num_edges = 0;
int pairs = 0;
+ //sometimes there's duplicate TopoDS_Edges in the shell.
+ DLIList<TopoDS_Edge*> edge_list;
for (Ex.Init(aShell, TopAbs_EDGE); Ex.More()&& stat; Ex.Next())
TopoDS_Edge edge1 = TopoDS::Edge(Ex.Current());
- num_edges++;
- for (Ex2.Init(aShell, TopAbs_EDGE); Ex2.More(); Ex2.Next())
+ edge_list.append(&edge1);
+ int size = edge_list.size();
+ for (int i = 0; i < size; i++)
+ TopoDS_Edge edge1 = *edge_list[i];
+ int same = 0;
+ for (int j = i+1; j < edge_list.size(); j++)
- TopoDS_Edge edge2 = TopoDS::Edge(Ex2.Current());
+ TopoDS_Edge edge2 = *edge_list[j];
+ if(edge1.IsEqual(edge2))
+ same ++;
+ edge_list.remove(&edge1);
+ i--;
+ size--;
+ break;
+ if(same > 0)
+ continue;
+ else
+ num_edges++;
+ for (int j = 0; j < size; j++)
if (!edge1.IsEqual(edge2)&& edge1.IsSame(edge2))
pairs++;
@@ -1086,7 +1114,7 @@
- if (num_edges == pairs)
+ if (num_edges == pairs )
aShell.Closed(CUBIT_TRUE);
else
@@ -1749,7 +1777,7 @@
//compare to see if the from_shape has gotten cut.
CubitBoolean has_changed;
- check_operation(cut_shape, from_shape, is_volume[i], has_changed, &cutter);
+ check_operation(cut_shape, from_shape, is_volume[i], has_changed, &cutter, keep_old);
CubitStatus stat;
if(!has_changed && !from_shape->IsNull())
@@ -3324,7 +3352,7 @@
BRepAlgoAPI_Common intersector(*from_shape, *tool_shape);
TopoDS_Shape common_shape = intersector.Shape();
check_operation(common_shape, from_shape, is_volume[i], has_changed,
- &intersector);
+ &intersector, keep_old);
if(from_shape->IsNull())
@@ -3376,7 +3404,8 @@
TopoDS_Shape*& from_shape, //output
CubitBoolean is_volume,
CubitBoolean& has_changed, //output
- BRepAlgoAPI_BooleanOperation* op) const
+ BRepAlgoAPI_BooleanOperation* op,
+ CubitBoolean keep_old) const
double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
@@ -3429,7 +3458,8 @@
OCCSurface::update_OCC_entity(old_face,cut_shape, op);
- delete from_shape;
+ if(keep_old)
+ delete from_shape;
from_shape = new TopoDS_Shape(cut_shape);
@@ -3455,15 +3485,16 @@
leftoversBody = 0;
//there's no effect of nonreg. keep_old mean if to keep the tool_body
- if(bodies.size() < 2)
+ if(bodies.size() != 2)
- PRINT_WARNING("There is only one volume in the list. Nothing modified\n");
+ PRINT_WARNING("Chop operation works only on two bodies. Nothing modified\n");
return CUBIT_FAILURE;
//outsideBodies keeps the surface, curve ids if keep_old is false.
BodySM* blank_body = bodies.get();
+ //copy blank_body for intersect operation, because it will get changed.
DLIList<BodySM*> tool_bodies, from_bodies;
from_bodies.append(blank_body);
BodySM* tool_body = bodies.step_and_get();
@@ -3544,9 +3575,9 @@
TopoDS_Shape new_shape = fuser.Shape();
- check_operation(new_shape, first_shape, first_is_volume, has_changed, &fuser);
+ check_operation(new_shape, first_shape, first_is_volume, has_changed, &fuser, keep_old);
- check_operation(new_shape,second_shape, is_volume[i], has_changed, &fuser);
+ check_operation(new_shape,second_shape, is_volume[i], has_changed, &fuser, keep_old);
//ok, we're done with all unites, construct new Body'
@@ -3681,6 +3712,7 @@
CubitStatus OCCModifyEngine :: flip_normals( DLIList<Surface*>& face_list ) const
+ DLIList<Surface*> surface_list;
while (face_list.size())
OCCSurface* occ_surface = CAST_TO(face_list.pop(), OCCSurface);
@@ -3689,11 +3721,14 @@
surfaces.append(occ_surface);
if(occ_shell) //find all surfaces in face_list that belong to this shell
- while ( face_list.size())
+ int size = face_list.size();
+ for ( int i = 0; i < size; i++)
occ_surface = CAST_TO(face_list.get(), OCCSurface);
if(occ_shell == occ_surface->my_shell())
surfaces.append(CAST_TO(face_list.remove(),OCCSurface));
+ else
+ face_list.step();
if (!occ_shell->is_sheet())
@@ -3713,6 +3748,7 @@
occ_surface->set_TopoDS_Face(*topoface);
coface->set_sense(coface->sense() == CUBIT_FORWARD ?
CUBIT_REVERSED : CUBIT_FORWARD);
+ surface_list.append(occ_surface);
@@ -3723,12 +3759,14 @@
topoface->Orientation(ori == TopAbs_FORWARD ? TopAbs_REVERSED :
TopAbs_FORWARD);
PRINT_INFO( "Modified volume\n" );
else
PRINT_WARNING( "Volume was not modified\n" );
+ face_list = surface_list;
return CUBIT_SUCCESS;
@@ -3738,25 +3776,128 @@
// Member Type: PUBLIC
// Description:
// Author : Jane Hu
-// Date : 06/08
+// Date : 09/08
CubitStatus OCCModifyEngine:: sweep_translational(
- DLIList<GeometryEntity*>& /*ref_ent_list*/,
- DLIList<BodySM*>& /*result_body_list*/,
- const CubitVector& /*sweep_vector*/,
- double /*draft_angle*/,
- int /*draft_type*/,
- bool /*switchside*/,
- bool /*rigid*/,
+ DLIList<GeometryEntity*>& ref_ent_list,
+ DLIList<BodySM*>& result_body_list,
+ const CubitVector& sweep_vector,
+ double draft_angle, //in Radius
+ int draft_type, //RightCorner=1 or RoundCorner =2
+ bool switchside,//not used, shell and surfaces are one sided, not like Acis
+ bool rigid, //not used here, in Acis, it means whether the end surface is
+ // parallel to the starting surface, or perpendicular to the path
Surface* stop_surf,
BodySM* to_body) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ //in OCC, there's no sweep surface with draft option, this can be done by
+ //creating draft shell then make solid to achieve.
+ TopoDS_Shape *stop_shape = NULL;
+ if(stop_surf)
+ OCCSurface* occ_surface = CAST_TO(stop_surf, OCCSurface);
+ stop_shape = occ_surface->get_TopoDS_Face();
+ else if(to_body)
+ OCCBody* occ_body = CAST_TO(to_body, OCCBody);
+ if(occ_body->is_sheet_body())
+ stop_shape = occ_body->my_sheet_surface()->get_TopoDS_Face();
+ else if(occ_body->shell())
+ stop_shape = occ_body->shell()->get_TopoDS_Shell();
+ else
+ stop_shape = occ_body->get_TopoDS_Shape();
+ gp_Dir adir(sweep_vector.x(), sweep_vector.y(), sweep_vector.z());
+ for (int i = ref_ent_list.size(); i > 0; i--)
+ GeometryEntity *ref_ent = ref_ent_list.get_and_step();
+ TopoDS_Shape* toposhape =
+ OCCQueryEngine::instance()->get_TopoDS_Shape_of_entity(ref_ent);
+ TopoDS_Wire wire;
+ if(!toposhape)
+ PRINT_WARNING("GeometryEntity without TopoDS_Shape found.\n");
+ continue;
+ OCCCurve* curve = CAST_TO(ref_ent, OCCCurve);
+ if(curve != NULL)
+ DLIList<OCCLoop*> loops;
+ loops = curve->loops();
+ if( loops.size())
+ continue; //not a free curve
+ TopoDS_Edge edge = TopoDS::Edge(*toposhape);
+ wire = BRepBuilderAPI_MakeWire(edge);
+ toposhape = &wire;
+ //check if the ref_ent has free boundary, if not, bail out
+ OCCSurface* surface = CAST_TO(ref_ent, OCCSurface);
+ if(surface != NULL)
+ if(surface->my_body() == NULL)
+ continue;
+ //create the draft
+ BRepOffsetAPI_MakeDraft draft(*toposhape, adir, draft_angle);
+ BRepBuilderAPI_TransitionMode Cornertype;
+ if(draft_type == 1)
+ Cornertype = BRepBuilderAPI_RightCorner;
+ else if(draft_type == 2)
+ Cornertype = BRepBuilderAPI_RoundCorner;
+ draft.SetOptions(Cornertype);
+ if(stop_shape)
+ draft.Perform(*stop_shape);
+ else
+ draft.Perform(sweep_vector.length());
+ TopoDS_Shape new_shape = draft.Shape();
+ DLIList<TopologyBridge*> tbs;
+ tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
+ assert(tbs.size() == 1);
+ BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
+ if(surface != NULL) //only gets swept side and top surfaces
+ //get surfaces from the shell body and add the original surface to
+ //make a swept solid.
+ OCCShell* occ_shell = CAST_TO(bodysm, OCCBody)->shell();
+ if(!occ_shell)
+ PRINT_WARNING("Sweep surface failed inside OCC engine.\n");
+ return CUBIT_FAILURE;
+ DLIList<OCCCoFace*> cofaces = occ_shell->cofaces();
+ surface_list.append(surface);
+ for(int i = 0; i < cofaces.size(); i++)
+ surface_list.append(cofaces.get_and_step()->surface());
+ flip_normals(surface_list);
+ DLIList<BodySM*> bodies;
+ create_solid_bodies_from_surfs(surface_list, bodies);
+ if(bodies.size() == 1)
+ bodysm = bodies.get();
+ else
+ PRINT_WARNING("Sweep surface failed in creating solid.\n");
+ if (bodysm)
+ result_body_list.append(bodysm);
+ return CUBIT_SUCCESS;
-// Function : sweep_perpendicular
// Description:
// Author : John Fowler
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -698,7 +698,8 @@
- BRepAlgoAPI_BooleanOperation* op) const;
+ CubitBoolean keep_old) const;
Modified: cgm/trunk/geom/OCC/OCCParamTool.cpp
--- cgm/trunk/geom/OCC/OCCParamTool.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCParamTool.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -6,8 +6,6 @@
#include "OCCParamTool.hpp"
#include "Surface.hpp"
Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
--- cgm/trunk/geom/OCC/OCCPoint.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCPoint.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -17,7 +17,6 @@
#include "OCCPoint.hpp"
#include "OCCCurve.hpp"
Modified: cgm/trunk/geom/OCC/OCCPoint.hpp
--- cgm/trunk/geom/OCC/OCCPoint.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCPoint.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -17,7 +17,6 @@
#include "Point.hpp"
#include <stdio.h>
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -13,7 +13,6 @@
// Creation Date : 7/17/00
#include <Standard_Stream.hxx>
#include "BRep_Tool.hxx"
@@ -1650,6 +1649,7 @@
if(occ_surface)
delete occ_surface->my_body();
+ occ_surface->set_body((OCCBody*)NULL);
delete occ_surface->my_shell();
delete occ_surface->my_lump();
return delete_solid_model_entities(occ_surface);
@@ -1659,6 +1659,7 @@
if(occ_shell)
delete occ_shell->my_body();
+ occ_shell->set_body((OCCBody*)NULL);
delete occ_shell->my_lump();
DLIList<TopologyBridge*> tb_surfaces;
occ_shell->get_children_virt(tb_surfaces);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -28,7 +28,6 @@
#include "CubitFileIOWrapper.hpp"
#include "GeometryQueryEngine.hpp"
#include "Handle_TDocStd_Document.hxx"
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -14,7 +14,6 @@
#include <stddef.h>
#include "CubitUtil.hpp"
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -13,7 +13,6 @@
#include "OCCSurface.hpp"
#include "RefFace.hpp"
@@ -738,7 +737,7 @@
-void OCCSurface::get_loops( DLIList<OCCLoop*>& result_list )
+int OCCSurface::get_loops( DLIList<OCCLoop*>& result_list )
TopTools_IndexedMapOfShape M;
TopExp::MapShapes(*myTopoDSFace, TopAbs_WIRE, M);
@@ -747,18 +746,22 @@
TopologyBridge *loop = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
result_list.append_unique(dynamic_cast<OCCLoop*>(loop));
+ return result_list.size();
-void OCCSurface::get_coedges( DLIList<OCCCoEdge*>& result_list )
+int OCCSurface::get_coedges( DLIList<OCCCoEdge*>& result_list )
DLIList<OCCLoop*> loop_list;
get_loops( loop_list );
loop_list.reset();
for ( int i = 0; i < loop_list.size(); i++ )
result_list += loop_list.next(i)->coedges( );
-void OCCSurface::get_curves( DLIList<OCCCurve*>& result_list )
+int OCCSurface::get_curves( DLIList<OCCCurve*>& result_list )
DLIList<OCCCoEdge*> coedge_list;
get_coedges( coedge_list );
@@ -770,6 +773,7 @@
if (curve)
result_list.append_unique(curve);
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -310,11 +310,11 @@
TopoDS_Face *get_TopoDS_Face(){return myTopoDSFace;}
void set_TopoDS_Face(TopoDS_Face& face);
- void get_loops(DLIList<OCCLoop*>&);
+ int get_loops(DLIList<OCCLoop*>&);
- void get_coedges(DLIList<OCCCoEdge*>&);
+ int get_coedges(DLIList<OCCCoEdge*>&);
- void get_curves(DLIList<OCCCurve*>&);
+ int get_curves(DLIList<OCCCurve*>&);
void set_shell(OCCShell* shell)
{ myShell = shell;}
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-09-25 17:22:33 UTC (rev 2093)
+++ cgm/trunk/test/modify.cpp 2008-09-25 17:45:08 UTC (rev 2094)
@@ -723,5 +723,12 @@
//stat = gmti->make_thick_solid(from_bodies, faces_to_remove, new_bodies, -.2);
//n = new_bodies.get()->num_ref_faces(); //n = 10
//d = new_bodies.get()->measure(); //d = 72.3618
+ RefFace* sweep_face = gmti->make_RefFace(ref_faces.get());
+ DLIList<RefEntity*> refentities;
+ refentities.append(sweep_face);
+// gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
+// body = CAST_TO(refentities.get(), Body);
+// d = body->measure();
More information about the cgma-dev
