[cgma-dev] r2067 - cgm/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Sep 18 11:41:08 CDT 2008
Author: kraftche
Date: 2008-09-18 11:41:07 -0500 (Thu, 18 Sep 2008)
New Revision: 2067
Modified:
   cgm/trunk/configure.in
Log:
Update configure script for OpenCascade 6.3:
 - OCC now has a working "make install" that is almost standard
   (still installs headers in ${prefix}/inc rather than the
   standard ${prefix}/include).  Support both the old 'ros'
   subdir and a true installed OCC build.  Also check for
   'include' in case that gets corrected in some future version
   or the user forced the standard value with --includedir=...
 - Work around libTKernel.so not knowing about its dependency on libdl.so
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in	2008-09-16 18:39:36 UTC (rev 2066)
+++ cgm/trunk/configure.in	2008-09-18 16:41:07 UTC (rev 2067)
@@ -268,10 +268,43 @@
     OCC_LIB_DIR=
     OCC_LIB_FLAG=
   else
-    uname=`uname`
-    OCC_INC_FLAG="-I${occ_DIR}/ros/inc"
-    OCC_LIB_DIR="${occ_DIR}/ros/${uname}/lib"
-    OCC_LIB_FLAG='-L$(OCC_LIB_DIR)'
+    AC_CACHE_CHECK( [for 'include' subdir of $occ_DIR],
+                    [ac_cv_occ_include_dir],
+                    [ac_cv_occ_include_dir=NONE
+                     for subdir in inc ros/inc include; do
+                       if test -f "${occ_DIR}/${subdir}/Standard_Version.hxx"; then
+                         ac_cv_occ_include_dir="$subdir"
+                         break
+                       elif test -d "${occ_DIR}/${subdir}"; then
+                         ac_cv_occ_include_dir="$subdir";
+                       fi
+                     done] )
+    if test "xNONE" = "x$ac_cv_occ_include_dir"; then
+      AC_MSG_ERROR([Count not find include dir in: $occ_DIR])
+    else
+      OCC_INC_FLAG="-I${occ_DIR}/$ac_cv_occ_include_dir"
+    fi
+    AC_CACHE_CHECK( [for 'lib' subdir of $occ_DIR],
+                    [ac_cv_occ_lib_dir],
+                    [ac_cv_occ_lib_dir=NONE
+                     uname=`uname`
+                     for subdir in lib ros/lib ros/${uname}/lib ros/$uname ; do
+                       if test -d "${occ_DIR}/${subdir}"; then
+                         ac_cv_occ_lib_dir="$subdir"
+                         for file in ${occ_DIR}/${subdir}/libTKernel.* ; do
+                           if test -f $file; then
+                             break 2
+                           fi
+                         done
+                       fi
+                     done] )
+    if test "xNONE" = "x$ac_cv_occ_lib_dir"; then
+      AC_MSG_ERROR([Count not find lib dir in: $occ_DIR])
+    else
+      OCC_LIB_DIR="$occ_DIR/$ac_cv_occ_lib_dir"
+      OCC_LIB_FLAG='-L$(OCC_LIB_DIR)'
+    fi
   fi
   # Check of OCC is present and working
@@ -297,15 +330,21 @@
   AC_CHECK_HEADER([fstream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM_H"])
   AC_CHECK_HEADER([limits.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_LIMITS_H"])
-  # Check for CCC headers Stadard_Version.hxx
+  # Check for OCC headers Stadard_Version.hxx
   AC_CHECK_HEADER( [Standard_Version.hxx], [],
                  [AC_MSG_ERROR([OpenCascade config error:Standard_Version.hxx not found])] )
   # Check if libTKernel.so contains function 'create_mailbox'
-  old_LIBS="$LIBS"
+  # OCC 6.3 has build error where libTKernel.so requires libdl.so,
+  #   but does not list that in the shared library dependencies.
+  #   Try to work around this bug by detecting the need for -ldl.
   AC_CHECK_LIB( [TKernel], [create_mailbox],,
-                [AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])])
-  LIBS="$old_LIBS"
+                [unset ac_cv_lib_TKernel_create_mailbox
+                 AC_CHECK_LIB( [TKernel], [create_mailbox],
+                               [OCC_LIBS="$OCC_LIBS -ldl"],
+                               [AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])],
+                               [-ldl] )
   AC_LANG_POP(C++)
   # Restore original values of variables
More information about the cgma-dev mailing list
