[cgma-dev] r2099 - in cgm/trunk: geom geom/ACIS_SRC geom/OCC test
janehu at mcs.anl.gov
Mon Sep 29 13:24:11 CDT 2008
Author: janehu
Date: 2008-09-29 13:24:07 -0500 (Mon, 29 Sep 2008)
New Revision: 2099
Modified:
cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
cgm/trunk/geom/GeometryModifyTool.cpp
cgm/trunk/geom/GeometryModifyTool.hpp
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCLoop.cpp
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCPoint.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/test/modify.cpp
Log:
Added hollow interface for OCC in GeometryModifyTool, updated test cases, Acis part hasn't change yet.
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -5924,11 +5924,11 @@
CubitStatus AcisModifyEngine::hollow( DLIList<BodySM*>& bodies,
- DLIList<Surface*>& surfs_to_remove,
- DLIList<BodySM*>& new_body_list,
- double depth) const
+ DLIList<Surface*>& surfs_to_remove,
+ DLIList<BodySM*>& new_body_list,
+ double depth) const
- PRINT_ERROR( "This function is not available in ACIS engine.\n");
return CUBIT_FAILURE;
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -4155,7 +4155,91 @@
do_attribute_cleanup();
return CUBIT_SUCCESS;
+CubitStatus GeometryModifyTool::hollow( DLIList<Body*>& bodies,
+ DLIList<RefFace*> faces_to_remove,
+ DLIList<Body*>& new_bodies,
+ double depth)
+ if (bodies.size() <= 0 || faces_to_remove.size() <= 0)
+ PRINT_WARNING("Needs at least one body and one face. Nothing modified\n");
+ return CUBIT_FAILURE;
+ if (!okay_to_modify( bodies, "HOLLOW" ))
+ // Get the GeometryEngine for each Body of the list to check
+ // if they are the same and if they are GeometryModifyEngine
+ const int count = bodies.size();
+ DLIList<TopologyEntity*> entity_list(count);
+ DLIList<TopologyBridge*> bridge_list(count);
+ CAST_LIST_TO_PARENT(bodies, entity_list);
+ GeometryModifyEngine* gme = common_modify_engine( entity_list, bridge_list );
+ if (!gme)
+ PRINT_ERROR("Performing THICKEN with volumes containing geometry\n"
+ " from different modeling engines is not allowed.\n"
+ "Delete uncommon geometry on these volumes before operation.\n\n");
+ DLIList<BodySM*> new_sms(count);
+ DLIList<BodySM*> body_sms(count);
+ CAST_LIST(bridge_list, body_sms, BodySM);
+ DLIList <Surface*> surfs_to_remove;
+ for(int i = 0 ; i < faces_to_remove.size(); i++)
+ Surface* surf = faces_to_remove.get_and_step()->get_surface_ptr();
+ if(surf)
+ surfs_to_remove.append(surf);
+ CubitStatus result = gme->hollow( body_sms, surfs_to_remove, new_sms, depth);
+ // check for resued entities, they have been moved and we need to notify observers
+ DLIList<RefEntity*> entities_to_update;
+ int i;
+ for(i=0; i<new_sms.size(); i++)
+ BodySM* bodysm = new_sms.get_and_step();
+ DLIList<TopologyBridge*> to_check;
+ DLIList<TopologyBridge*> tmp;
+ DLIList<Surface*> surfs;
+ bodysm->surfaces(surfs);
+ DLIList<Curve*> curves;
+ bodysm->curves(curves);
+ DLIList<Point*> points;
+ bodysm->points(points);
+ to_check.append(bodysm);
+ to_check.append(bodysm->lump());
+ CAST_LIST_TO_PARENT(surfs, tmp);
+ to_check += tmp;
+ CAST_LIST_TO_PARENT(curves, tmp);
+ to_check += tmp;
+ CAST_LIST_TO_PARENT(points, tmp);
+ to_check += tmp;
+ int k;
+ for(k=0; k<to_check.size(); k++)
+ if(BridgeManager* m = to_check.get_and_step()->bridge_manager())
+ if(TopologyEntity* t = m->topology_entity())
+ entities_to_update.append(CAST_TO(t, RefEntity));
+ if (!finish_sm_op(bodies, new_sms, new_bodies))
+ result = CUBIT_FAILURE;
+ // Update graphics
+ while (entities_to_update.size())
+ entities_to_update.pop()->notify_all_observers( GEOMETRY_MODIFIED );
+ return result;
CubitStatus GeometryModifyTool::thicken( DLIList<Body*>& bodies,
double depth,
Modified: cgm/trunk/geom/GeometryModifyTool.hpp
--- cgm/trunk/geom/GeometryModifyTool.hpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/GeometryModifyTool.hpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -37,7 +37,6 @@
class RefVolume;
class RefVertex;
class RefEdge;
-class RefFace;
class RefVolume;
template <class X> class DLIList;
class Loop;
@@ -225,6 +224,11 @@
bool keep_old = false,
bool nonreg = false );
+ CubitStatus hollow( DLIList<Body*>& bodies,
+ double depth);
CubitStatus thicken( DLIList<Body*>& bodies,
double depth,
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -461,7 +461,11 @@
TopTools_ListOfShape shapes;
if(op)
shapes.Assign(op->Modified(solid));
+ if(shapes.Extent() == 0)
+ shapes.Assign(op->Generated(solid));
else if(sp)
shapes.Assign(sp->DescendantShapes(solid));
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -924,6 +924,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Edge()));
+ shapes.Assign(op->Generated(*get_TopoDS_Edge()));
if(shapes.Extent() == 1)
shape = shapes.First();
else if(shapes.Extent() > 1)
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -233,6 +233,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Wire()));
+ shapes.Assign(op->Generated(*get_TopoDS_Wire()));
if(shapes.Extent())
else if (op->IsDeleted(*get_TopoDS_Wire()))
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -361,6 +361,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Solid()));
+ shapes.Assign(op->Generated(*get_TopoDS_Solid()));
//update all attributes first.
@@ -435,7 +437,11 @@
if (op)
shapes.Assign(op->Modified(shell));
+ shapes.Assign(op->Generated(shell));
else if(sp)
shapes.Assign(sp->DescendantShapes(shell));
Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
--- cgm/trunk/geom/OCC/OCCPoint.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCPoint.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -273,6 +273,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Vertex()));
+ shapes.Assign(op->Generated(*get_TopoDS_Vertex()));
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -1419,7 +1419,7 @@
for(int i = 0; i < size; i++)
coedge = coedges_old.get_and_step();
- if(coedge->curve() == curve)
+ if(coedge->curve() == curve && coedge->sense() == sense)
coedge->set_mark(1);
exist = CUBIT_TRUE;
@@ -1451,6 +1451,18 @@
delete loop;
+ //for the cylinder side face, there are 4 coedges, 2 of them are seam
+ //edges and should have opposite sense.
+ for(int i = 0; i < coedges_new.size(); i++)
+ coedge = coedges_new.get_and_step();
+ Curve* test_c = coedge->curve();
+ if(test_c == curve)
+ sense = (sense == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
+ break;
coedge = new OCCCoEdge( curve, loop, sense);
coedges_new.append(coedge);
occ_curve->add_loop(loop);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -1,7 +1,7 @@
// Filename : OCCQueryEngine.hpp
-// Purpose : Facet geometry engine.
+// Purpose : OCC geometry engine.
// This class is implemented as a Singleton pattern. Only
// one instance is created and it is accessed through the
@@ -9,9 +9,9 @@
// Special Notes :
-// Creator : David R. White
+// Creator : Jane Hu
-// Creation Date : 6/29/00
+// Creation Date : 10/07
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -220,6 +220,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Shell()));
+ shapes.Assign(op->Generated(*get_TopoDS_Shell()));
if (shapes.Extent())
@@ -286,7 +288,11 @@
TopoDS_Face face = TopoDS::Face(M(ii));
if (op)
shapes.Assign(op->Modified(face));
+ shapes.Assign(op->Generated(face));
else if(sp)
shapes.Assign(sp->DescendantShapes(face));
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -793,6 +793,8 @@
shapes.Assign(op->Modified(*get_TopoDS_Face()));
+ shapes.Assign(op->Generated(*get_TopoDS_Face()));
if (shapes.Extent() == 1)
@@ -858,7 +860,11 @@
TopoDS_Wire wire = TopoDS::Wire(M(ii));
if(op)
shapes.Assign(op->Modified(wire));
+ shapes.Assign(op->Generated(wire));
else if(sp)
shapes.Assign(sp->DescendantShapes(wire));
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-09-28 16:56:46 UTC (rev 2098)
+++ cgm/trunk/test/modify.cpp 2008-09-29 18:24:07 UTC (rev 2099)
@@ -720,9 +720,9 @@
faces_to_remove.append(ref_faces.get());
from_bodies = new_bodies;
new_bodies.clean_out();
- //stat = gmti->make_thick_solid(from_bodies, faces_to_remove, new_bodies, -.2);
- //n = new_bodies.get()->num_ref_faces(); //n = 10
- //d = new_bodies.get()->measure(); //d = 72.3618
+ stat = gmti->hollow(from_bodies, faces_to_remove, new_bodies, -.2);
+ n = new_bodies.get()->num_ref_faces(); //n = 10
+ d = new_bodies.get()->measure(); //d = 72.3618
RefFace* sweep_face = gmti->make_RefFace(ref_faces.get());
DLIList<RefEntity*> refentities;
More information about the cgma-dev
