[cgma-dev] r2289 - cgm/trunk/geom/OCC
kraftche at mcs.anl.gov
Wed Nov 26 13:22:03 CST 2008
Author: kraftche
Date: 2008-11-26 13:22:03 -0600 (Wed, 26 Nov 2008)
New Revision: 2289
Modified:
cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
Log:
Fix a few more buffer overflow vulnerabilities. Specifically, when doing
"input_stream >> buffer" delcare buffer as std::string rather than
char[255].
Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
--- cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-11-26 18:02:34 UTC (rev 2288)
+++ cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-11-26 19:22:03 UTC (rev 2289)
@@ -209,7 +209,7 @@
static TopAbs_ShapeEnum ReadShapeEnum(Standard_IStream& IS)
- char buffer[255];
+ std::string buffer;
IS >> buffer;
switch (buffer[0]) {
@@ -249,7 +249,7 @@
static GeomAbs_Shape ReadRegularity(Standard_IStream& IS)
- char buffer[255];
IS >> buffer;
@@ -1478,13 +1478,14 @@
// BUC60769
- char string[260];
- IS.getline ( string, 256, '\n' );
+ std::string line;
+ std::getline( IS, line );
+ std::istringstream str( line );
- if (string[0] == '2') {
+ if (str.get() == '2') {
// cas triangulation
- s = atoi ( &string[2] );
+ str >> s;
myBuilder.UpdateFace(TopoDS::Face(S),
Handle(Poly_Triangulation)::DownCast(myTriangulations(s)));
@@ -1541,9 +1542,11 @@
void OCCShapeAttributeSet::ReadPolygonOnTriangulation(Standard_IStream& IS)
- char buffer[255];
- IS >> buffer;
- if (strstr(buffer,"PolygonOnTriangulations") == NULL) return;
+ IS >> buffer;
+ if (buffer.find("PolygonOnTriangulations") == std::string::npos)
+ return;
Standard_Integer i, j, val, nbpol = 0, nbnodes =0;
Standard_Integer hasparameters;
Standard_Real par;
@@ -1582,12 +1585,14 @@
void OCCShapeAttributeSet::ReadPolygon3D(Standard_IStream& IS)
- char buffer[255];
- // Standard_Integer i, j, p, val, nbpol, nbnodes, hasparameters;
- Standard_Integer i, j, p, nbpol=0, nbnodes =0, hasparameters = Standard_False; Standard_Real d, x, y, z;
+ // Standard_Integer i, j, p, val, nbpol, nbnodes, hasparameters;
+ Standard_Integer i, j, p, nbpol=0, nbnodes =0, hasparameters = Standard_False; Standard_Real d, x, y, z;
- IS >> buffer;
- if (strstr(buffer,"Polygon3D") == NULL) return;
+ IS >> buffer;
+ if (buffer.find("Polygon3D") == std::string::npos)
+ return;
Handle(Poly_Polygon3D) P;
IS >> nbpol;
for (i=1; i<=nbpol; i++) {
@@ -1619,7 +1624,7 @@
void OCCShapeAttributeSet::ReadTriangulation(Standard_IStream& IS)
- char buffer[255];
// Standard_Integer i, j, val, nbtri;
Standard_Integer i, j, nbtri =0;
@@ -1629,7 +1634,7 @@
Handle(Poly_Triangulation) T;
IS >> buffer;
- if (strstr(buffer,"Triangulations") != NULL) {
+ if (buffer.find("Triangulations") != std::string::npos) {
IS >> nbtri;
for (i=1; i<=nbtri; i++) {
IS >> nbNodes >> nbTriangles >> hasUV;
@@ -1696,13 +1701,17 @@
Standard_IStream& IS,
const int nbshapes)const
- char buffer[255];
IS >> buffer;
if (buffer[0] == '*')
S = TopoDS_Shape();
else {
- S = myShapes(nbshapes - atoi(buffer+1) + 1);
- switch (buffer[0]) {
+ char type;
+ int num;
+ std::istringstream buffstr(buffer);
+ buffstr >> type >> num;
+ S = myShapes(nbshapes - num + 1);
+ switch (type) {
case '+' :
S.Orientation(TopAbs_FORWARD);
More information about the cgma-dev
