[cgma-dev] r2290 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Nov 26 17:36:07 CST 2008
Author: janehu
Date: 2008-11-26 17:36:07 -0600 (Wed, 26 Nov 2008)
New Revision: 2290
Modified:
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Partitially fixed the hollow operation to left free-entities after deletion problem, now there's still one coedge extra there.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-11-26 19:22:03 UTC (rev 2289)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-11-26 23:36:07 UTC (rev 2290)
@@ -412,7 +412,7 @@
//set the Shells
TopTools_IndexedMapOfShape M;
- TopoDS_Shape shape;
+ TopoDS_Shape shape, shape2;
TopExp::MapShapes(new_shape, TopAbs_SOLID,M);
TopoDS_Solid new_solid;
if(M.Extent() > 1)
@@ -436,17 +436,29 @@
TopoDS_Shell shell = TopoDS::Shell(M(ii));
TopTools_ListOfShape shapes;
+ TopTools_IndexedMapOfShape M2;
if (op)
shapes.Assign(op->Modified(shell));
if(shapes.Extent() == 0)
shapes.Assign(op->Generated(shell));
+ // bug fix for hollow operation, in which a new shell is genearted
+ // but the shapes we get from old_shell->Generated() is still old_shell
+ // not the new one.
+ if(!new_solid.IsNull())
+ TopExp::MapShapes(new_solid, TopAbs_SHELL, M2);
else if(sp)
shapes.Assign(sp->DescendantShapes(shell));
if (shapes.Extent() == 1)
- shape = shapes.First();
+ shape = shapes.First();
+ if(M2.Extent() > 0)
+ shape2 = TopoDS::Shell(M2(1));
+ if(M2.Extent() == 1 && !shape.IsSame(shape2))
+ shape = shape2;
else if(shapes.Extent() > 1)
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-11-26 19:22:03 UTC (rev 2289)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-11-26 23:36:07 UTC (rev 2290)
@@ -849,8 +849,8 @@
LocOpe_SplitShape* sp)
//set the Wires
- TopTools_IndexedMapOfShape M;
- TopoDS_Shape shape, shape_edge, shape_vertex;
+ TopTools_IndexedMapOfShape M, M2;
+ TopoDS_Shape shape, shape2, shape_edge, shape_vertex;
TopExp::MapShapes(old_surface, TopAbs_WIRE, M);
@@ -864,12 +864,22 @@
shapes.Assign(op->Modified(wire));
shapes.Assign(op->Generated(wire));
+ if(!new_surface.IsNull())
+ TopExp::MapShapes(new_surface,TopAbs_WIRE, M2);
else if(sp)
shapes.Assign(sp->DescendantShapes(wire));
+ if(M2.Extent() == 1)
+ shape2 = TopoDS::Wire(M2(1));
+ if(!shape.IsSame(shape2))
+ shape = shape2;
shape.Nullify();
else if(op->IsDeleted(wire))
More information about the cgma-dev
