[cgma-dev] r2288 - in cgm/trunk/geom: . OCC
kraftche at mcs.anl.gov
Wed Nov 26 12:02:34 CST 2008
Author: kraftche
Date: 2008-11-26 12:02:34 -0600 (Wed, 26 Nov 2008)
New Revision: 2288
Modified:
cgm/trunk/geom/GeometryQueryEngine.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp
Log:
o 'print_results' argument to GeometryQueryEngine::import_solid_model is for
disabling error output when doing things like trying every engine until
one succeeds in importing a file. Add comment to GeometryQueryEngine.hpp
specifying this.
o Remove OCC code that printed rather verbose debugging output if the
'print_results' argument is true (so I can see why tests are failing
w/out having to redirect output to a file.)
o Disable a couple of OCC error messages on file import if 'print_results'
is false.
o Fix buffer overflow vulnerability in OCC file import code.
o Change OCC file import to use std::ifstream instead of constructing
a std::istream from a std::filebuf (functionally the same, but
more concise.)
Modified: cgm/trunk/geom/GeometryQueryEngine.hpp
--- cgm/trunk/geom/GeometryQueryEngine.hpp 2008-11-26 16:57:18 UTC (rev 2287)
+++ cgm/trunk/geom/GeometryQueryEngine.hpp 2008-11-26 18:02:34 UTC (rev 2288)
@@ -114,6 +114,10 @@
//- "ACIS_SAB" -- ACIS BINARY (SAB) file format
//- "IGES" -- IGES file
//- "STEP" -- STEP file
+ //O imported_entities
+ //O- List of top-level entities read from file
+ //I print_results
+ //I- If false, fail silently (don't write error messages to stdout or stderr)
//I heal_step - auto-healing of step bodies on import. This is recommended
// because they always need it.
//I import_bodies (etc...)
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-26 16:57:18 UTC (rev 2287)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-26 18:02:34 UTC (rev 2288)
@@ -128,7 +128,6 @@
typedef std::map<int, TopologyBridge*>::value_type valType;
int OCCQueryEngine::iTotalTBCreated = 0;
int OCCQueryEngine::total_coedges = 0;
-CubitBoolean OCCQueryEngine::PRINT_RESULT = CUBIT_FALSE;
// Description:
// Author :
@@ -1080,15 +1079,18 @@
CubitBoolean OCCQueryEngine::Read(TopoDS_Shape& Sh,
const Standard_CString File,
- TDF_Label label)
+ TDF_Label label,
+ CubitBoolean print_results)
- filebuf fic;
- istream in(&fic);
- // if (!fic.open(File,input)) return Standard_False;
- if (!fic.open(File, ios::in)) return Standard_False;
+ ifstream in( File );
+ if (!in) {
+ if (print_results)
+ PRINT_INFO("%s: Cannot open file", File );
+ return CUBIT_FAILURE;
OCCShapeAttributeSet SS;
- SS.Read(in, label);
+ SS.Read(in, label, print_results);
int nbshapes = SS.NbShapes();
if(!nbshapes) return CUBIT_FALSE;
SS.Read(Sh,in,nbshapes);
@@ -1131,14 +1133,10 @@
TopoDS_Shape *aShape = new TopoDS_Shape;
BRep_Builder aBuilder;
- Standard_Boolean result = Read(*aShape, (char*) file_name, mainLabel);
+ Standard_Boolean result = Read(*aShape, (char*) file_name, mainLabel, print_results);
if (result==0) return CUBIT_FAILURE;
- CubitBoolean prev_global_val = PRINT_RESULT;
- PRINT_RESULT = print_results;
imported_entities = populate_topology_bridge(*aShape);
- PRINT_RESULT = prev_global_val;
return CUBIT_SUCCESS;
@@ -1197,8 +1195,6 @@
OCCBody *body;
if (!OCCMap->IsBound(aShape))
- if(PRINT_RESULT)
- PRINT_INFO("Adding Bodies.\n");
TopoDS_CompSolid *posolid = new TopoDS_CompSolid;
*posolid = aShape;
(iTotalTBCreated)++;
@@ -1236,8 +1232,6 @@
OCCBody *body;
- if(PRINT_RESULT)
- PRINT_INFO("Adding solids.\n");
TopoDS_Solid *posolid = new TopoDS_Solid;
*posolid = aShape;
iTotalTBCreated++;
@@ -1282,8 +1276,6 @@
DLIList<OCCCoFace*> cofaces_old, cofaces_new;
- if(PRINT_RESULT)
- PRINT_INFO("Adding shells.\n");
TopoDS_Shell *poshell = new TopoDS_Shell;
*poshell = aShape;
iTotalTBCreated++;
@@ -1372,8 +1364,7 @@
delete surface;
return (Surface*) NULL;
- if(PRINT_RESULT)
- PRINT_INFO("Adding faces.\n");
iTotalTBCreated++;
OCCMap->Bind(*poface, iTotalTBCreated);
OccToCGM->insert(valType(iTotalTBCreated,
@@ -1417,8 +1408,6 @@
OCCLoop *loop ;
- if(PRINT_RESULT)
- PRINT_INFO("Adding loops.\n");
TopoDS_Wire *powire = new TopoDS_Wire;
*powire = aShape;
iTotalTBCreated++;
@@ -1528,8 +1517,6 @@
Curve *curve;
- if(PRINT_RESULT)
- PRINT_INFO("Adding edges.\n");
TopoDS_Edge *poedge = new TopoDS_Edge;
*poedge = aShape;
iTotalTBCreated++;
@@ -1563,8 +1550,6 @@
OCCPoint *point;
if (iTotalTBCreated == 0 || !OCCMap->IsBound(aShape))
- if(PRINT_RESULT)
- PRINT_INFO("Adding vertices.\n");
TopoDS_Vertex *povertex = new TopoDS_Vertex;
*povertex = aShape;
iTotalTBCreated++;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-11-26 16:57:18 UTC (rev 2287)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2008-11-26 18:02:34 UTC (rev 2288)
@@ -392,10 +392,9 @@
CubitBoolean Read(TopoDS_Shape& Sh,
- TDF_Label label);
+ TDF_Label label,
+ bool print_results);
- static CubitBoolean PRINT_RESULT;
static OCCQueryEngine* instance_;
//- static pointer to unique instance of this class
Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp
--- cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-11-26 16:57:18 UTC (rev 2287)
+++ cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-11-26 18:02:34 UTC (rev 2288)
@@ -678,7 +678,8 @@
void OCCShapeAttributeSet::Read(Standard_IStream& IS,
- TDF_Label& l_attr)
+ TDF_Label& l_attr,
// on sauvegarde l'ancien LC_NUMERIC
char *oldnum,*plocal ;
@@ -703,7 +704,8 @@
} while ( ! IS.fail() && strcmp(vers,dVersion) && strcmp(vers,dVersion2) );
if (IS.fail()) {
- cout << "File was not written with this version of the topology"<<endl;
+ cout << "File was not written with this version of the topology"<<endl;
setlocale(LC_NUMERIC, oldnum) ;
delete[] oldnum;
return;
@@ -727,10 +729,11 @@
// read the shapes
- char buffer[255];
+ std::string buffer;
IS >> buffer;
- if (strcmp(buffer,"TShapes")) {
- cout << "Not a TShape table"<<endl;
+ if (buffer != "TShapes") {
+ cout << "Not a TShape table"<<endl;
delete[] oldnum;
return;
Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp
--- cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp 2008-11-26 16:57:18 UTC (rev 2287)
+++ cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp 2008-11-26 18:02:34 UTC (rev 2288)
@@ -87,7 +87,7 @@
void Write(Standard_OStream& OS,
TDF_Label l_attr)const;
-void Read(Standard_IStream& IS, TDF_Label& l_attr);
+void Read(Standard_IStream& IS, TDF_Label& l_attr, bool print);
void Read(TopoDS_Shape& S,Standard_IStream& IS, const int nbshapes)const;
More information about the cgma-dev
