[cgma-dev] r2200 - cgm/trunk
janehu at mcs.anl.gov
Mon Nov 3 13:08:03 CST 2008
Author: janehu
Date: 2008-11-03 13:08:03 -0600 (Mon, 03 Nov 2008)
New Revision: 2200
Added:
cgm/trunk/README.OpenCascade
Log:
Added document on CGM on OCC capabilities.
Added: cgm/trunk/README.OpenCascade
--- cgm/trunk/README.OpenCascade (rev 0)
+++ cgm/trunk/README.OpenCascade 2008-11-03 19:08:03 UTC (rev 2200)
@@ -0,0 +1,39 @@
+ GM on OCC6.3 capabilities
+1. Query
+• Import/Export OpenCascade b-rep files, create CGM geometry/topology entities.
+• Import/Export OpenCascade b-rep plus CGM attribute files.
+• Delete entities build on OCC engine.
+• Translate/Rotate/Scale/Reflect objects.
+• Detect body overlap
+• Get iso-parametric points on surfaces and curves.
+• Get curve-curve, curve-surface intersection points.
+• Get distance between entities.
+• Get bounding boxes for entities.
+2. Modify
+• Create CGM geometry entities using OpenCascade engine. Top-Down method: directly create points, curves, surfaces or solid primitives.
+• Create CGM geometry entities using OpenCascade engine, Bottom-Up method: curve generates by points, surface generates by curves and solid generates by surfaces.
+• Boolean operations: subtract, unite, intersect.
+• Project curve on surface
+• Imprint object: body-body imprint, surface-body imprint, curve-surface imprint.
+• Make thick body by hollowing existing solid.
+• Sweep surface or curve along a vector, an edge, perpendicularly or revolutionarily.(alpha testing)
More information about the cgma-dev
