[cgma-dev] r2199 - in cgm/trunk: . geom init test
tautges at mcs.anl.gov
Mon Nov 3 10:25:01 CST 2008
Author: tautges
Date: 2008-11-03 10:25:01 -0600 (Mon, 03 Nov 2008)
New Revision: 2199
Modified:
cgm/trunk/Makefile.am
cgm/trunk/configure.in
cgm/trunk/geom/Makefile.am
cgm/trunk/init/Makefile.am
cgm/trunk/test/Makefile.am
Log:
- changed 'WITH_OCC' to 'build_OCC' to make consistent with ACIS
- added geom/OCC to list of include dirs in init code; also added $(OCC_INC_FLAG); this is inconsistent with ACIS handling, because OQE/OME headers include OCC headers; is this absolutely necessary?
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
+++ cgm/trunk/Makefile.am 2008-11-03 16:25:01 UTC (rev 2199)
@@ -23,7 +23,7 @@
else
CGM_ACIS_LIB =
endif
-if WITH_OCC
+if build_OCC
CGM_OCC_LIB = geom/OCC/libcubit_OCC.la
else
CGM_OCC_LIB =
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-11-03 15:57:27 UTC (rev 2198)
+++ cgm/trunk/configure.in 2008-11-03 16:25:01 UTC (rev 2199)
@@ -386,8 +386,8 @@
AC_SUBST(CGM_EXT_LTFLAGS)
AC_SUBST(CGM_EXT_INCLUDE)
-# Allow "if WITH_OCC" in Makefile.am
-AM_CONDITIONAL( WITH_OCC, [test "x$occ_DIR" != "xno"] )
+# Allow "if build_OCC" in Makefile.am
+AM_CONDITIONAL( build_OCC, [test "x$occ_DIR" != "xno"] )
Modified: cgm/trunk/geom/Makefile.am
--- cgm/trunk/geom/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
+++ cgm/trunk/geom/Makefile.am 2008-11-03 16:25:01 UTC (rev 2199)
@@ -11,7 +11,7 @@
if build_parallel
SUBDIRS += parallel
endif
-if WITH_OCC
+if build_OCC
SUBDIRS += OCC
endif
Modified: cgm/trunk/init/Makefile.am
--- cgm/trunk/init/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
+++ cgm/trunk/init/Makefile.am 2008-11-03 16:25:01 UTC (rev 2199)
@@ -7,10 +7,12 @@
INCLUDES = -I$(top_srcdir)/geom \
-I$(top_srcdir)/util \
-I$(top_srcdir)/geom/ACIS \
+ -I$(top_srcdir)/geom/OCC \
-I$(top_srcdir)/geom/virtual \
-I$(top_srcdir)/geom/facet \
-I$(top_srcdir)/geom/cholla \
- -I$(srcdir)
+ -I$(srcdir) \
+ $(OCC_INC_FLAG)
noinst_LTLIBRARIES = libcgma_init.la
libcgma_init_la_includedir = $(includedir)
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-11-03 15:57:27 UTC (rev 2198)
+++ cgm/trunk/test/Makefile.am 2008-11-03 16:25:01 UTC (rev 2199)
@@ -18,7 +18,7 @@
TESTS += webcut hollow_acis
LINK_FLAGS += -R$(ACIS_LIB_DIR)
endif
-if WITH_OCC
+if build_OCC
TESTS += modify makept r_w test_occ
LINK_FLAGS += -R$(OCC_LIB_DIR)
endif
More information about the cgma-dev
