[cgma-dev] r2201 - in cgm/trunk: geom geom/OCC test
janehu at mcs.anl.gov
Mon Nov 3 13:45:56 CST 2008
Author: janehu
Date: 2008-11-03 13:45:56 -0600 (Mon, 03 Nov 2008)
New Revision: 2201
Modified:
cgm/trunk/geom/GeometryModifyTool.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/test/modify.cpp
Log:
Added returning body for the sweep_along_curve interface in geom level and passed tests.
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp 2008-11-03 19:08:03 UTC (rev 2200)
+++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-11-03 19:45:56 UTC (rev 2201)
@@ -3568,6 +3568,14 @@
if (!sweep_finish("along_curve", body_list, result_list, changed_new_ids))
status = CUBIT_FAILURE;
+ body_list.clean_out();
+ for(int i = 0; i < result_list.size(); i++)
+ Body* body = CAST_TO(result_list.get_and_step()->topology_entity(),Body );
+ if(body)
+ body_list.append(body);
+ CAST_LIST( body_list, ref_ent_list, RefEntity);
return status;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-11-03 19:08:03 UTC (rev 2200)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-11-03 19:45:56 UTC (rev 2201)
@@ -4354,12 +4354,6 @@
BRepLib_FuseEdges fuser(wire);
fuser.SetConcatBSpl();
fuser.Perform();
- int removed_vertices = fuser.NbVertices();
- if(removed_vertices < num_edges - 1)
- PRINT_ERROR("The curve_list provided has to form a G1 continuous spline.\n");
- return CUBIT_FAILURE;
TopoDS_Shape spline = fuser.Shape();
wire = TopoDS::Wire(spline);
@@ -4386,6 +4380,11 @@
//sweep along the wire
BRepOffsetAPI_MakePipe maker(wire, toposhape);
+ if(!maker.IsDone())
+ PRINT_ERROR("Can't sweep along the provided curve(s).\n");
+ continue;
TopoDS_Shape newShape = maker.Shape();
tbs += OCCQueryEngine::instance()->populate_topology_bridge(newShape);
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-11-03 19:08:03 UTC (rev 2200)
+++ cgm/trunk/test/modify.cpp 2008-11-03 19:45:56 UTC (rev 2201)
@@ -865,5 +865,40 @@
d = body->measure();
//d = 8.07227
+ //test sweep_along_curve function
+ //sweep along a staight curve with draft
+ refentities.clean_out();
+ refentities.append(rotate_face);
+ CubitVector pt4(0,1,0);
+ RefVertex* vt4 = gmti->make_RefVertex(pt4);
+ RefEdge* edge3 = gmti->make_RefEdge(STRAIGHT_CURVE_TYPE, vt1, vt4);
+ edges.clean_out();
+ edges.append(edge3);
+ gmti->sweep_along_curve(refentities, edges, 0.087,1);
+ body = CAST_TO(refentities.get(), Body);
+ d = body->measure();
+ //d = 134.7152, theoretical calculation is 135.66363, error 0.67%
+ //sweep along two curves which make a G1 continous wire, no draft is performed
+ CubitVector pt5(0,2,7.5);
+ CubitVector pt6(0,0,-7.5);
+ CubitVector pt7(0,1,-15);
+ RefVertex* vt5 = gmti->make_RefVertex(pt7);
+ DLIList<CubitVector*> vector_list;
+ vector_list.append(&pt5);
+ RefEdge* edge4 = gmti->make_RefEdge( SPLINE_CURVE_TYPE, vt1, vt4, vector_list);
+ vector_list.clean_out();
+ vector_list.append(&pt6);
+ RefEdge* edge5 = gmti->make_RefEdge( SPLINE_CURVE_TYPE, vt4, vt5, vector_list);
+ edges.append(edge4);
+ edges.append(edge5);
+ //d = 93.697, no effect of draft angle.
return CUBIT_SUCCESS;
More information about the cgma-dev
