[cgma-dev] r1844 - cgm/trunk/test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue May 27 11:28:30 CDT 2008
Author: janehu
Date: 2008-05-27 11:28:30 -0500 (Tue, 27 May 2008)
New Revision: 1844
Modified:
   cgm/trunk/test/sheet.cpp
Log:
double checked that OCC make_planar works for the test, and changed it back as the original testing.
Modified: cgm/trunk/test/sheet.cpp
--- cgm/trunk/test/sheet.cpp	2008-05-26 15:07:55 UTC (rev 1843)
+++ cgm/trunk/test/sheet.cpp	2008-05-27 16:28:30 UTC (rev 1844)
@@ -7,6 +7,7 @@
  * and performs varies checks for bodies, surfaces, curves and vertices.
 #include "GeometryModifyTool.hpp"
+#include "GeometryModifyEngine.hpp"
 #include "GeometryQueryTool.hpp"
 #include "ModelQueryEngine.hpp"
 #include "Body.hpp"
@@ -15,6 +16,7 @@
 #include <typeinfo>
 #include <assert.h>
+#define HAVE_OCC
 #ifdef HAVE_ACIS
 #include "AcisModifyEngine.hpp"
@@ -34,6 +36,7 @@
   CubitObserver::init_static_observers();
   CGMApp::instance()->startup( argc, argv );
+#define HAVE_OCC
   GeometryQueryEngine* const gqe_list[] = {
 #ifdef HAVE_ACIS
     AcisQueryEngine::instance(),
@@ -77,44 +80,15 @@
     return 1;
-/*  This fails for OCC.  Try something else to create sheet body
   sheet = GeometryModifyTool::instance()->planar_sheet(
     CubitVector(0,0,0), CubitVector(1,0,0),
     CubitVector(1,1,0), CubitVector(0,1,0) );
-  if (!sphere) {
+  if (!sheet) {
     fprintf(stderr,"Planar sheet creation failed for engine (%s)\n",
       typeid(*engine).name());
     return 1;
-  DLIList<ModelEntity*> list;
-  rval = ModelQueryEngine::instance()->query_model( *sphere, DagType::ref_face_type(), list );
-  if (!rval || list.size() != 1) {
-    fprintf(stderr,"Failed to get face from body (%s)\n",
-      typeid(*engine).name());
-    return 1;
-  RefFace* sphere_face = dynamic_cast<RefFace*>(list.get());
-  assert(NULL != sphere_face);
-  RefFace* sheet_face = GeometryModifyTool::instance()->make_RefFace( sphere_face );
-  if (!sheet_face) {
-    fprintf(stderr,"Failed to create face from sphere face (%s)\n",
-    return 1;
-  list.clean_out();
-  rval = ModelQueryEngine::instance()->query_model( *sheet_face, DagType::body_type(), list );
-    fprintf(stderr,"Failed to get body from sheet face (%s)\n",
-    return 1;
-  sheet = dynamic_cast<Body*>(list.get());
-  assert(NULL != sheet);
   if (sphere->is_sheet_body()) {
     fprintf(stderr,"Solid sphere reported as sheet body (%s).\n",
More information about the cgma-dev mailing list
