[cgma-dev] r1842 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Fri May 23 13:57:33 CDT 2008
Author: janehu
Date: 2008-05-23 13:57:33 -0500 (Fri, 23 May 2008)
New Revision: 1842
Modified:
   cgm/trunk/geom/OCC/OCCLump.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added edge imprint on solid, not tested yet.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-23 17:37:03 UTC (rev 1841)
+++ cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-23 18:57:33 UTC (rev 1842)
@@ -285,7 +285,7 @@
   //use face tolerance at the tolerence to see if the point is on.
   TopExp_Explorer Ex;
-  Ex.Init(*solid, TopAbs_FACE, TopAbs_SOLID);
+  Ex.Init(*solid, TopAbs_FACE);
   TopoDS_Face face = TopoDS::Face(Ex.Current());
   double dtol = BRep_Tool::Tolerance(face);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-23 17:37:03 UTC (rev 1841)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-23 18:57:33 UTC (rev 1842)
@@ -1923,7 +1923,11 @@
       DLIList<TopoDS_Shape*> tool_faces_edges;
       for(; intersector.MoreIntersection(); intersector.NextIntersection())
-	  TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
+          TopoDS_Shape face1;
+          if(tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
+            face1 = intersector.ChangeFaceEdgeIntersector().Shape(1);
+          else
+	    face1 = intersector.ChangeFacesIntersector().Face(1);
           CubitBoolean has_imprinted = CUBIT_FALSE;
           for (int j = 0; j < from_faces.size(); j++)
@@ -1948,7 +1952,10 @@
           //intersection edges between face1 and edge_face
 	  TopTools_ListOfShape temp_list_of_edges;
-	  temp_list_of_edges.Assign(section.SectionEdges());
+          if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
+            temp_list_of_edges.Append(edge_face);
+          else
+	    temp_list_of_edges.Assign(section.SectionEdges());
 	  int num_edges = temp_list_of_edges.Extent();
           CubitBoolean is_same = face1.IsSame(from_face);
@@ -2081,7 +2088,12 @@
         TopoDS_Shape ashape = *(tool_faces_edges.get_and_step());
         TopoDS_Shape face;
         if(ashape.TShape()->ShapeType() == TopAbs_EDGE)
-          face = extended_from_face;
+          TopOpeBRep_FaceEdgeIntersector intersector;
+          intersector.Perform(extended_from_face, ashape);
+          if (intersector.NbPoints()< 2)
+            return CUBIT_FAILURE;
         else
           face = TopoDS::Face(ashape);
         BRepAdaptor_Surface asurface(TopoDS::Face(face));
@@ -2147,29 +2159,34 @@
 	  CubitStatus stat = sort_curves(curve_list, edge_lists);
 	  DLIList<TopoDS_Edge*>* edge_list;
-	  edge_list = edge_lists.pop();
+          int size = edge_lists.size();
+          for (int iii = 0; iii < size; iii++)
+	    edge_list = edge_lists.pop();
-          //check if the edges make a split of the surface, error out if it's
-          //just a scar on the surface
-          int count_intersection = 0;
-          if (stat == CUBIT_FAILURE) //Open wire
-            count_intersection = check_intersection(edge_list, from_face);
+            //check if the edges make a split of the surface, error out if it's
+            //just a scar on the surface
+            int count_intersection = 0;
+            if (stat == CUBIT_FAILURE) //Open wire
+              count_intersection = check_intersection(edge_list, from_face);
-            if (count_intersection < 2)
-              PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
-          if (stat || count_intersection == 2)
-	    BRepBuilderAPI_MakeWire myWire;
-            edge_list->reset();
-	    for(int i = 0; i < edge_list->size(); i++)
-	        TopoDS_Edge e = *(edge_list->get_and_step());
-	        myWire.Add(e);
-	    splitor.Add(myWire.Wire(),from_face);
-            topo_changed = CUBIT_TRUE;
+              if (count_intersection < 2)
+                PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
+            if (stat || count_intersection == 2)
+	      BRepBuilderAPI_MakeWire myWire;
+              edge_list->reset();
+	      for(int i = 0; i < edge_list->size(); i++)
+	          TopoDS_Edge e = *(edge_list->get_and_step());
+	          myWire.Add(e);
+	      splitor.Add(myWire.Wire(),from_face);
+              topo_changed = CUBIT_TRUE;
+              break;
       if(topo_changed)
@@ -2556,11 +2573,65 @@
                                            bool show_messages) const
   CubitStatus success = CUBIT_SUCCESS;
-  DLIList<TopoDS_Shape*> shape_list;
+  DLIList<TopoDS_Shape*> shape_list, tool_shapes;
   CubitStatus stat = get_the_shape_list(body_list, shape_list, keep_old);
   if (!stat)
     return stat;
+  int size = ref_edge_list.size();
+  // total number of imprints to be done
+  if( size > 2 && show_messages)
+     char message[128];
+     sprintf(message, "Imprinting %d OCC Bodies", body_list.size() );
+     AppUtil::instance()->progress_tool()->start(0, size, message);
+  for (int i = 0; i < ref_edge_list.size(); i++)
+    OCCCurve* curve = CAST_TO(ref_edge_list.get_and_step(), OCCCurve) ;
+    if (!curve)
+      continue;
+    TopoDS_Edge* edge = curve->get_TopoDS_Edge();
+    if (edge->IsNull())
+      continue;
+    if (CubitMessage::instance()->Interrupt())
+       success = CUBIT_FAILURE;
+       break;
+    for(int j = 0; j < shape_list.size(); j ++)
+      TopoDS_Shape* shape = shape_list.get();
+      stat = imprint_toposhapes(shape, (TopoDS_Shape*)edge);
+      if (stat)
+        shape_list.change_to(shape);
+      shape_list.step();
+      body_list.step();
+    if( size > 2 )
+      AppUtil::instance()->progress_tool()->step();
+    DLIList<TopologyBridge*> tbs;
+    TopoDS_Shape* shape = shape_list.get_and_step();
+    tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape);
+    new_body_list.append(CAST_TO(tbs.get(),BodySM));
+  if( size > 2 )
+    AppUtil::instance()->progress_tool()->end();
+  if( CubitMessage::instance()->Interrupt() )
+        PRINT_INFO("Imprint aborted.\n");
   return success;
More information about the cgma-dev
