[cgma-dev] r1845 - cgm/trunk/test
    janehu at mcs.anl.gov
    Tue May 27 11:32:19 CDT 2008
Author: janehu
Date: 2008-05-27 11:32:19 -0500 (Tue, 27 May 2008)
New Revision: 1845
Modified:
   cgm/trunk/test/modify.cpp
   cgm/trunk/test/sheet.cpp
Log:
don't need to define OCC yet.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2008-05-27 16:28:30 UTC (rev 1844)
+++ cgm/trunk/test/modify.cpp	2008-05-27 16:32:19 UTC (rev 1845)
@@ -292,6 +292,8 @@
   tool_body = gmti->brick(11, 1, 1);
   CubitVector v_move4(0,1,-1);
   gti->translate(from_body,v_move4);
+  Body* cp_from_body = gmti->copy_body(from_body);
+  Body* cp_tool_body = gmti->copy_body(tool_body);
   from_bodies.clean_out();
   from_bodies.append(from_body);
   new_bodies.clean_out();
@@ -302,6 +304,13 @@
   n = new_bodies.get()->num_ref_edges();
   //n = 18
+  //test edge imprint on body
+  ref_edges.clean_out();
+  cp_tool_body->ref_edges(ref_edges);
+  from_bodies.clean_out();
+  from_bodies.append(cp_from_body);
+  CubitStatus stat = gmti->imprint(from_bodies, ref_edges, new_bodies, CUBIT_FALSE, CUBIT_TRUE );
   bodies.clean_out();
   gti->bodies(bodies);
   //delete all entities
@@ -350,6 +359,7 @@
   gti->translate(tool_body,v_move3);
   BodySM* copy_bodysm = ome->copy_body(tool_body->get_body_sm_ptr());
   Body* copy_tool_body = gmti->copy_body(tool_body);
+  Body* copy_tool_body2 = gmti->copy_body(tool_body);
   //test shell body imprint
   //TopoDS_Shape* tool_shape = CAST_TO(copy_bodysm,OCCBody)->get_TopoDS_Shape();
@@ -359,8 +369,16 @@
   from_bodies.append(copy_tool_body);
   from_bodies.append(from_body2);
-  CubitStatus stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
+  stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
+  //test body imprinted by curves.
+  from_body2->ref_edges(ref_edges);
+  new_bodies.clean_out();
+  from_bodies.append(copy_tool_body2);
+  stat = gmti->imprint(from_bodies, ref_edges, new_bodies, CUBIT_FALSE, CUBIT_TRUE );
   //test body cutting a shell, one surface got cut as the result.
   CubitVector v_move6(1,-1,0);
   gti->translate(tool_body,v_move6);
Modified: cgm/trunk/test/sheet.cpp
--- cgm/trunk/test/sheet.cpp	2008-05-27 16:28:30 UTC (rev 1844)
+++ cgm/trunk/test/sheet.cpp	2008-05-27 16:32:19 UTC (rev 1845)
@@ -16,7 +16,6 @@
 #include <typeinfo>
 #include <assert.h>
-#define HAVE_OCC
 #ifdef HAVE_ACIS
 #include "AcisModifyEngine.hpp"
More information about the cgma-dev
