[cgma-dev] r1838 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu May 22 13:43:13 CDT 2008
Author: janehu
Date: 2008-05-22 13:43:12 -0500 (Thu, 22 May 2008)
New Revision: 1838
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added in imprint_toposhape an edge type as the tool, getting ready to do edge imprint on body.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-22 17:37:49 UTC (rev 1837)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-22 18:43:12 UTC (rev 1838)
@@ -1893,7 +1893,9 @@
// Function : imprint_toposhapes
// Member Type: PROTECTED
-// Description: imprint boolean operation on OCC-based bodies
+// Description: imprint boolean operation on OCC-based bodies.
+// from_shape must be TopoDS_Face or above, tool_shape can be
+// TopoDS_Edge or above.
// Author : Jane HU
// Date : 03/08
@@ -1918,7 +1920,7 @@
//find the intersecting edges and faces.
int max_edge = 0;
TopoDS_Face from_face,tool_face;
- DLIList<TopoDS_Face*> tool_faces;
+ DLIList<TopoDS_Shape*> tool_faces_edges;
for(; intersector.MoreIntersection(); intersector.NextIntersection())
TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
@@ -1936,22 +1938,27 @@
if (has_imprinted)
continue;
- TopoDS_Shape face2 = intersector.ChangeFacesIntersector().Face(2);
- BRepAlgoAPI_Section section(face1, face2);
+ TopoDS_Shape edge_face;
- //intersection edges between face1 and face2
+ if(tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
+ edge_face = intersector.ChangeFaceEdgeIntersector().Shape(2);
+ else
+ edge_face = intersector.ChangeFacesIntersector().Face(2);
+ BRepAlgoAPI_Section section(face1, edge_face);
+ //intersection edges between face1 and edge_face
TopTools_ListOfShape temp_list_of_edges;
temp_list_of_edges.Assign(section.SectionEdges());
int num_edges = temp_list_of_edges.Extent();
CubitBoolean is_same = face1.IsSame(from_face);
- CubitBoolean is_same_tool_face = CUBIT_FALSE;
- for (int j = 0; j < tool_faces.size(); j++)
+ CubitBoolean is_same_tool = CUBIT_FALSE;
+ for (int j = 0; j < tool_faces_edges.size(); j++)
- TopoDS_Face* topo_face = tool_faces.get_and_step();
- if(face2.IsSame(*topo_face))
+ TopoDS_Shape* topo_face_edge = tool_faces_edges.get_and_step();
+ if(edge_face.IsSame(*topo_face_edge))
- is_same_tool_face = CUBIT_TRUE;
+ is_same_tool = CUBIT_TRUE;
break;
@@ -1960,13 +1967,24 @@
list_of_edges.Assign(temp_list_of_edges);
max_edge = num_edges ;
from_face = TopoDS::Face(face1);
- tool_face = TopoDS::Face(face2);
- TopoDS_Face* topo_face = new TopoDS_Face(tool_face);
- tool_faces.clean_out();
+ TopoDS_Shape* topo_shape = new TopoDS_Shape(edge_face);
+ DLIList<TopoDS_Shape*> shape_list;
+ for(int iii = 0; iii < tool_faces_edges.size(); iii++)
+ int size = shape_list.size();
+ shape_list.append_unique(tool_faces_edges.get_and_step());
+ if (size < shape_list.size())
+ shape_list.last();
+ shape_list.get()->Nullify();
+ delete shape_list.get();
+ tool_faces_edges.clean_out();
for(int i = 0 ; i < num_edges; i++)
- tool_faces.append(topo_face);
+ tool_faces_edges.append(topo_shape);
- else if(num_edges == max_edge && is_same && !is_same_tool_face)
+ else if(num_edges == max_edge && is_same && !is_same_tool)
//multi tool faces cut the same face
TopTools_ListIteratorOfListOfShape Itor, temp_Itor;
@@ -1995,8 +2013,8 @@
if(!same_edge)
list_of_edges.Append(temp_edge);
- TopoDS_Face* topo_face = new TopoDS_Face(TopoDS::Face(face2));
@@ -2004,17 +2022,30 @@
if (from_face.IsNull())
more_face = CUBIT_FALSE;
continue;
TopTools_ListIteratorOfListOfShape Itor;
- //list_of_edges is the intersection edges on tool_faces
+ //list_of_edges is the intersection edges on tool_faces_edges
Itor.Initialize(list_of_edges);
int total_edges = list_of_edges.Extent();
DLIList<Curve*> curve_list;
CubitBoolean topo_changed = CUBIT_FALSE;
- tool_faces.reset();
+ tool_faces_edges.reset();
//check to see if the intersecting edge is overlapping with any
//of the edges on from_edge. It's possible that the tool_face is
@@ -2047,8 +2078,13 @@
GProp_GProps myProps1;
BRepGProp::LinearProperties(edge, myProps1);
double d1 = myProps1.Mass();
- TopoDS_Face face = *(tool_faces.get_and_step());
- BRepAdaptor_Surface asurface(face);
+ TopoDS_Shape ashape = *(tool_faces_edges.get_and_step());
+ TopoDS_Shape face;
+ if(ashape.TShape()->ShapeType() == TopAbs_EDGE)
+ face = extended_from_face;
+ else
+ face = TopoDS::Face(ashape);
+ BRepAdaptor_Surface asurface(TopoDS::Face(face));
Bnd_Box aBox1;
BndLib_AddSurface::Add(asurface, tol, aBox1);
@@ -2151,6 +2187,8 @@
TopoDS_Solid old_solid = TopoDS::Solid(M(1));
OCCLump::update_OCC_entity(old_solid, new_from_shape, &splitor);
+ from_shape->Nullify();
+ delete from_shape;
from_shape = new TopoDS_Shape(new_from_shape);
@@ -2159,35 +2197,35 @@
TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
else if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
TopoDS_Shell old_shell = TopoDS::Shell(*from_shape);
OCCShell::update_OCC_entity(old_shell,new_from_shape, &splitor);
else if(from_shape->TShape()->ShapeType() == TopAbs_FACE)
TopoDS_Face old_face = TopoDS::Face(*from_shape);
OCCSurface::update_OCC_entity(old_face,new_from_shape, &splitor);
- else //imprinting an edge
- TopoDS_Edge old_edge = TopoDS::Edge(*from_shape);
- TopTools_IndexedMapOfShape M;
- TopExp::MapShapes(new_from_shape, TopAbs_EDGE, M);
- if (M.Extent() > 1) //split successfully
- OCCQueryEngine::instance()->update_OCC_map(old_edge, M(1));
TopTools_ListOfShape shapes;
for(int i = 0; i < from_faces.size(); i++)
TopoDS_Face* topo_face = from_faces.get();
shapes.Assign(splitor.Modified(*topo_face));
topo_face = new TopoDS_Face(TopoDS::Face(shapes.First()));
+ from_faces.get()->Nullify();
+ delete from_faces.get();
from_faces.change_to(topo_face);
from_faces.step();
@@ -2507,9 +2545,9 @@
// Member Type: PUBLIC
-// Author : John Fowler
-// Date : 10/02
+// Description: imprint curves onto body_list
+// Author : Jane Hu
+// Date : 05/08
CubitStatus OCCModifyEngine::imprint( DLIList<BodySM*> &body_list,
DLIList<Curve*> &ref_edge_list,
@@ -2518,6 +2556,11 @@
bool show_messages) const
CubitStatus success = CUBIT_SUCCESS;
+ CubitStatus stat = get_the_shape_list(body_list, shape_list, keep_old);
+ if (!stat)
+ return stat;
return success;
More information about the cgma-dev
