[cgma-dev] r1833 - in cgm/trunk: geom/OCC test
    janehu at mcs.anl.gov
    Wed May 21 13:54:59 CDT 2008
Author: janehu
Date: 2008-05-21 13:54:59 -0500 (Wed, 21 May 2008)
New Revision: 1833
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/test/modify.cpp
Log:
updated testcase for body-body imprint through GeometryModifyTool interface.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-20 21:33:57 UTC (rev 1832)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-21 18:54:59 UTC (rev 1833)
@@ -2319,62 +2319,36 @@
                                          BodySM*& newBody1, BodySM*& newBody2,
                                          bool  keep_old) const
-  OCCBody* occ_body = NULL;
   newBody1 = NULL;
   newBody2 = NULL;
   DLIList<TopoDS_Shape*> shape_list;
-  for(int i = 0; i <2; i++)
-    if (i == 0)
-      occ_body = CAST_TO(BodyPtr1, OCCBody);
-    else
-      occ_body = CAST_TO(BodyPtr2, OCCBody);
-    OCCSurface* surface = occ_body->my_sheet_surface();
-    OCCShell*   shell = occ_body->shell();
-    if(surface)
-      TopoDS_Face* topo_face = surface->get_TopoDS_Face();
-      BRepBuilderAPI_Copy api_copy(*topo_face);
-      TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_face);
-      TopoDS_Shape* Shape1 = new TopoDS_Shape(newShape);
-      shape_list.append(Shape1);
-    else if(shell)
-      TopoDS_Shell* topo_shell = shell->get_TopoDS_Shell();
-      BRepBuilderAPI_Copy api_copy(*topo_shell);
-      TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_shell);
-    else
-      DLIList<Lump*> lumps = occ_body->lumps();
-      if (lumps.size() > 1)
-        PRINT_ERROR("Can't do boolean operation on CompSolid types. \n");
-        return CUBIT_FAILURE;
-      TopoDS_Solid* solid = CAST_TO(lumps.get(), OCCLump)->get_TopoDS_Solid();
-      BRepBuilderAPI_Copy api_copy(*solid);
-      TopoDS_Shape newShape = api_copy.ModifiedShape(*solid);
+  DLIList<BodySM*> bodysm_list;
+  bodysm_list.append(BodyPtr1);
+  bodysm_list.append(BodyPtr2);
+  CubitStatus stat = get_the_shape_list(bodysm_list, shape_list, keep_old);
+  if(!stat)
+    return stat;
   TopoDS_Shape* shape1 = shape_list.get();
   TopoDS_Shape* shape2 = shape_list.step_and_get();
   DLIList<TopologyBridge*> tbs;
-  CubitStatus stat = imprint_toposhapes(shape1, shape2);
+  stat = imprint_toposhapes(shape1, shape2);
   if(stat)
     tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape1);
     newBody1 = CAST_TO(tbs.get(),BodySM);
+  else if(!stat && keep_old)
+    delete shape1;
+    PRINT_INFO("There's no imprint on the first body.\n");
+    newBody1 = BodyPtr1;
   tbs.clean_out();
   stat = imprint_toposhapes(shape2, shape1);
   if(stat)
@@ -2383,65 +2357,58 @@
     newBody2 = CAST_TO(tbs.get(),BodySM);
-  if (!keep_old)
-    if (newBody1)
-      OCCQueryEngine::instance()->delete_solid_model_entities(BodyPtr1);
-    if (newBody2)
-      OCCQueryEngine::instance()->delete_solid_model_entities( BodyPtr2);
-  if (!newBody1)
-    delete shape1;
-    newBody1 = BodyPtr1;
-  if(!newBody2)
     delete shape2;
+    PRINT_INFO("There's no imprint on the second body.\n");
     newBody2 = BodyPtr2;
   return CUBIT_SUCCESS;
-// Function   : imprint multiple bodies at once
-// Member Type: PUBLIC
-// Description: imprint boolean operation on OCC-based bodies
-// Author     : Jane HU
-// Date       : 04/08
+// Function   : get_the_shape_list
+// Member Type: PRIVATE
+// Description: get the TopoDS_Shape list for imprinting use.
+// Author     : Jane Hu
+// Date       : 05/08
-CubitStatus OCCModifyEngine::imprint(DLIList<BodySM*> &from_body_list ,
-                                     DLIList<BodySM*> &new_from_body_list,
-                                     bool keep_old,
-                                     DLIList<TopologyBridge*>* new_tbs,
-                                     DLIList<TopologyBridge*>* att_tbs) const
+CubitStatus OCCModifyEngine::get_the_shape_list(DLIList<BodySM*> BodySM_list,
+                                         DLIList<TopoDS_Shape*>& shape_list,
+                                         bool  keep_old) const
-  CubitStatus success = CUBIT_SUCCESS;
-  DLIList<TopoDS_Shape*> shape_list;
-  for(int i = 0; i <from_body_list.size(); i++)
+  shape_list.clean_out();
+  for(int i = 0; i <BodySM_list.size(); i++)
-    occ_body = CAST_TO(from_body_list.get_and_step(), OCCBody);
+    occ_body = CAST_TO(BodySM_list.get_and_step(), OCCBody);
     if(surface)
+      if(keep_old)
+        BRepBuilderAPI_Copy api_copy(*topo_face);
+        TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_face);
+        TopoDS_Shape* Shape1 = new TopoDS_Shape(newShape);
+        shape_list.append(Shape1);
+      else
+        shape_list.append(topo_face);
     else if(shell)
+      if(keep_old)
+        BRepBuilderAPI_Copy api_copy(*topo_shell);
+        TopoDS_Shape newShape = api_copy.ModifiedShape(*topo_shell);
+      else
+        shape_list.append(topo_shell);
     else
@@ -2454,12 +2421,39 @@
+      if(keep_old)
+        BRepBuilderAPI_Copy api_copy(*solid);
+        TopoDS_Shape newShape = api_copy.ModifiedShape(*solid);
+      else
+        shape_list.append(solid);
+  return CUBIT_SUCCESS;
+// Function   : imprint multiple bodies at once
+// Member Type: PUBLIC
+// Description: imprint boolean operation on OCC-based bodies
+// Author     : Jane HU
+// Date       : 04/08
+CubitStatus OCCModifyEngine::imprint(DLIList<BodySM*> &from_body_list ,
+                                     DLIList<BodySM*> &new_from_body_list,
+                                     bool keep_old,
+                                     DLIList<TopologyBridge*>* new_tbs,
+                                     DLIList<TopologyBridge*>* att_tbs) const
+  CubitStatus success = CUBIT_SUCCESS;
+  DLIList<TopoDS_Shape*> shape_list;
+  CubitStatus stat = get_the_shape_list(from_body_list, shape_list, keep_old);
+  if(!stat)
+    return stat;
   int size = shape_list.size();
   // total number of imprints to be done
@@ -2468,7 +2462,8 @@
   if( size > 2 )
      char message[128];
-     sprintf(message, "Imprinting %d ACIS Bodies", from_body_list.size() );          AppUtil::instance()->progress_tool()->start(0, total_imprints, message);
+     sprintf(message, "Imprinting %d OCC Bodies", from_body_list.size() );
+     AppUtil::instance()->progress_tool()->start(0, total_imprints, message);
   for(int i = 0; i < size; i++)
@@ -2484,7 +2479,7 @@
           break;
-       TopoDS_Shape* shape2 = shape_list[j];
+       TopoDS_Shape* shape2 = shape_list[j%size];
        if(stat)
@@ -2512,7 +2507,7 @@
-// Description: imprint boolean operation on facet-based bodies
 // Author     : John Fowler
 // Date       : 10/02
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-05-20 21:33:57 UTC (rev 1832)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-05-21 18:54:59 UTC (rev 1833)
@@ -669,7 +669,9 @@
 private:
  int check_intersection(DLIList<TopoDS_Edge*>* edge_list,
                         TopoDS_Face from_face)const;
+ CubitStatus get_the_shape_list(DLIList<BodySM*> BodySM_list,
+                         bool  keep_old) const;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2008-05-20 21:33:57 UTC (rev 1832)
+++ cgm/trunk/test/modify.cpp	2008-05-21 18:54:59 UTC (rev 1833)
@@ -221,6 +221,30 @@
   d = from_body2->measure();//d = 67.02
   d = tool_body->measure(); //d = 31.41
+  // test for sphere making
+  Body* test_body = gmti->sphere(5);
+  d = test_body->measure(); //d =
+  //test for prism making
+  test_body = gmti->prism(10, 4, 4,2);
+  //test for pyramid making
+  test_body = gmti->pyramid(10, 4, 5, 2, 3);
+  //test for torus making
+  test_body =  gmti->torus(10,5);
+  //test for planar_sheet making
+  CubitVector p1(0, 0, 0);
+  CubitVector p2(0, 0, 1);
+  CubitVector p3(0, 1, 1);
+  CubitVector p4(0, 1, 0);
+  test_body =  gmti->planar_sheet(p1, p2, p3, p4);
+  d =  test_body->measure(); //d = 1
   bodies.clean_out();
   gti->bodies(bodies);
   //delete all entities
@@ -325,22 +349,24 @@
   CubitVector v_move3(0,1,0);
   gti->translate(tool_body,v_move3);
   BodySM* copy_bodysm = ome->copy_body(tool_body->get_body_sm_ptr());
+  Body* copy_tool_body = gmti->copy_body(tool_body);
+  //test shell body imprint
+  //TopoDS_Shape* tool_shape = CAST_TO(copy_bodysm,OCCBody)->get_TopoDS_Shape();
+  //TopoDS_Shape* from_shape = CAST_TO(bodysm,OCCBody)->shell()->get_TopoDS_Shell();
+  //ome->imprint_toposhapes(tool_shape, from_shape);
   from_bodies.clean_out();
+  new_bodies.clean_out();
+  from_bodies.append(copy_tool_body);
   from_bodies.append(from_body2);
-  new_bodies.clean_out();
+  CubitStatus stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
-  //test face body imprint
-  TopoDS_Shape* tool_shape = CAST_TO(copy_bodysm,OCCBody)->get_TopoDS_Shape();
-/*  TopoDS_Shape* from_shape = CAST_TO(body_list[0],OCCBody)->my_sheet_surface()->get_TopoDS_Face();
-  ome->imprint_toposhapes(tool_shape, from_shape);
-  //test shell body imprint.
-  TopoDS_Shape* from_shape = CAST_TO(bodysm,OCCBody)->shell()->get_TopoDS_Shell();
   //test body cutting a shell, one surface got cut as the result.
   CubitVector v_move6(1,-1,0);
   gti->translate(tool_body,v_move6);
+  from_bodies.clean_out();
+  from_bodies.append(from_body2);
   rsl = gmti->subtract(tool_body, from_bodies, new_bodies,
                        CUBIT_TRUE, CUBIT_TRUE);
   d = new_bodies.step_and_get()->measure();
@@ -360,10 +386,16 @@
   CubitVector v_move5(0,0.5,0);
   gti->translate(tool_body,v_move5);
   from_body = gmti->brick(1,1,1);
-  from_shape = CAST_TO(from_body->get_body_sm_ptr(), OCCBody)->get_TopoDS_Shape();
-  tool_shape = CAST_TO(tool_body->get_body_sm_ptr(),OCCBody)->get_TopoDS_Shape();
-  ome->imprint_toposhapes(from_shape, tool_shape);
+  //from_shape = CAST_TO(from_body->get_body_sm_ptr(), OCCBody)->get_TopoDS_Shape();
+  //tool_shape = CAST_TO(tool_body->get_body_sm_ptr(),OCCBody)->get_TopoDS_Shape();
+//  ome->imprint_toposhapes(tool_shape, from_shape);
+//  ome->imprint_toposhapes(from_shape, tool_shape);
+  from_bodies.append(from_body);
+  from_bodies.append(tool_body);
+  stat =  gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
More information about the cgma-dev
