[cgma-dev] r1831 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue May 20 14:20:52 CDT 2008
Author: janehu
Date: 2008-05-20 14:20:52 -0500 (Tue, 20 May 2008)
New Revision: 1831
Modified:
   cgm/trunk/geom/OCC/OCCLump.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/test/makept.cpp
Log:
Fixed the infinite loop problem, fixed a bug in making spline.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-20 15:23:47 UTC (rev 1830)
+++ cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-20 19:20:52 UTC (rev 1831)
@@ -360,8 +360,11 @@
   TopoDS_Shape shape;
   TopExp::MapShapes(new_shape, TopAbs_SOLID,M);
   CubitBoolean is_null_new_shape = CUBIT_FALSE;
+  TopoDS_Solid new_solid;
   if(M.Extent() > 1)
     is_null_new_shape = CUBIT_TRUE;
+  else if(M.Extent() == 1 )
+    new_solid = TopoDS::Solid(M(1));
   M.Clear();
   TopExp::MapShapes(old_solid, TopAbs_SHELL, M);
@@ -397,15 +400,5 @@
     if(shapes.Extent() > 0 || op->IsDeleted(shell))
       OCCShell::update_OCC_entity(shell, shape, op);
-  TopoDS_Solid new_solid;
-  if(!is_null_new_shape && !op->IsDeleted(old_solid))
-    new_solid = TopoDS::Solid(new_shape);
-  else if (op->IsDeleted(old_solid))
-    M.Clear();
-    TopExp::MapShapes(new_shape, TopAbs_SOLID, M);
-    if(M.Extent() == 1)
-      new_solid = TopoDS::Solid(M(1));
   OCCQueryEngine::instance()->update_OCC_map(old_solid, new_solid);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-20 15:23:47 UTC (rev 1830)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-20 19:20:52 UTC (rev 1831)
@@ -266,6 +266,9 @@
      return (Curve *)NULL;
+  if (curve_type == STRAIGHT_CURVE_TYPE)
+    return make_Curve(curve_type, point1_ptr, point2_ptr, NULL, CUBIT_FORWARD);
   OCCPoint* occ_point1 = CAST_TO(const_cast<Point*>(point1_ptr), OCCPoint);
   OCCPoint* occ_point2 = CAST_TO(const_cast<Point*>(point2_ptr), OCCPoint);
@@ -319,22 +322,12 @@
   if(curve_type == SPLINE_CURVE_TYPE)
     Geom_BezierCurve BezierCurve(points);
-    Handle(Geom_Curve) curve_ptr(&BezierCurve);
+    Geom_BezierCurve* curve =  new Geom_BezierCurve(BezierCurve);
+    Handle(Geom_BoundedCurve) curve_ptr(curve);
     TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
     return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
-  else if(curve_type == STRAIGHT_CURVE_TYPE)
-    TColgp_Array1OfPnt two_points(1,2);
-    two_points.SetValue(1, points.Value(1));
-    two_points.SetValue(2, points.Value(size));
-    Geom_BezierCurve BezierCurve(two_points);
-    TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
-    return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
   return (Curve*) NULL;
@@ -371,9 +364,11 @@
   assert (point1_ptr != NULL && point2_ptr != NULL);
   DLIList<CubitVector*> mid_points;
-  CubitVector mid_point = *intermediate_point_ptr;
-  if (intermediate_point_ptr != NULL )
+  if (intermediate_point_ptr)
+    CubitVector mid_point = *intermediate_point_ptr;
     mid_points.append(&mid_point);
   CubitVector v1(point1_ptr->coordinates());
   CubitVector v2(point2_ptr->coordinates());
@@ -2144,6 +2139,7 @@
       if(topo_changed)
         splitor.Build();
+        topo_changed = CUBIT_FALSE;
         if(splitor.IsDone())
           TopoDS_Shape new_from_shape = splitor.Shape();
@@ -2155,7 +2151,7 @@
               TopoDS_Solid old_solid = TopoDS::Solid(M(1));
               OCCLump::update_OCC_entity(old_solid, new_from_shape, &splitor);
-              from_shape = new TopoDS_Shape(old_solid);
+              from_shape = new TopoDS_Shape(new_from_shape);
@@ -2163,19 +2159,19 @@
             TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
           else if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
             TopoDS_Shell old_shell = TopoDS::Shell(*from_shape);
             OCCShell::update_OCC_entity(old_shell,new_from_shape, &splitor);
-            from_shape = new TopoDS_Shape(old_shell);
           else if(from_shape->TShape()->ShapeType() == TopAbs_FACE)
             TopoDS_Face old_face = TopoDS::Face(*from_shape);
             OCCSurface::update_OCC_entity(old_face,new_from_shape, &splitor);
-            from_shape = new TopoDS_Shape(old_face);
           else //imprinting an edge
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp	2008-05-20 15:23:47 UTC (rev 1830)
+++ cgm/trunk/test/makept.cpp	2008-05-20 19:20:52 UTC (rev 1831)
@@ -150,13 +150,14 @@
   // After parellel move, center point moved by x (10)
   CubitVector vector1(10,10,10);
-  CubitVector vector2(10,-10,10);
+  CubitVector vector2(-10,-10,10);
+  CubitVector vector3(10, -10, 10);
   DLIList<RefEntity*> free_entities;
   // Make two vertices.
   gmti->make_RefVertex(vector1,5);
   gmti->make_RefVertex(vector2,5);
+  gmti->make_RefVertex(vector3,5);
   gti->get_free_ref_entities(free_entities);
   CubitStatus rsl = CUBIT_SUCCESS;
@@ -166,10 +167,8 @@
   const char * filename = "point.occ";
   const char * filetype = "OCC";
   rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
                                  num_ents_exported, cubit_version);
   //check for vertex
   DLIList<Body*> bodies;
@@ -179,16 +178,15 @@
   RefVertex* vertex1 = CAST_TO(free_entities.get_and_step(),RefVertex);
-  RefVertex* vertex2 = CAST_TO(free_entities.get(),RefVertex);
+  RefVertex* vertex2 = CAST_TO(free_entities.get_and_step(),RefVertex);
+  RefVertex* vertex3 = CAST_TO(free_entities.get(),RefVertex);
   CubitBoolean is_equal = gti->
 		about_spatially_equal(vertex1,vertex2);
   //vertex1,vertex2 are not spatially equal.
   double d;
   gti->entity_entity_distance(vertex1,vertex2,vi, vii,d);
-  // distance (d) between vertex1,vertex2. vi (20, 20, 20) is vertex1
-  //translated by (10,10,10) and vii(30, 10, 30) is vertex2 translated
-  //by 2*(10,10,10).
+  // distance (d) between vertex1,vertex2.
   //check for body
   d = bodies.get()->measure();
@@ -211,9 +209,10 @@
   // After reflection, only x value should change.
   gti->scale(CompBody,2);
-  vi = bodies.get()->center_point();
+  vi = CompBody->center_point();
   // After scale, center point moved by 2 times
+  vi = bodies.get()->center_point();
   gti->translate(bodies.get(),axis);
@@ -249,6 +248,7 @@
   CubitBoolean extended_from = CUBIT_TRUE;
   RefFace* new_face = gmti->make_RefFace(ref_face, extended_from);
+  ref_entity_list.clean_out();
@@ -288,7 +288,7 @@
     volume = new_face->ref_volume();
   else
     vi = new_face->center_point();
-  //center point should moved by (40,40,40) compared with the original one below
+  //center point should moved by (20,20,20) compared with the original one below
   vi = ref_face->center_point();
   // center point
@@ -365,13 +365,16 @@
   //make all kinds of curves.
   CubitVector center_pnt(0,0,10);
   DLIList<CubitVector*> list;
-  CubitVector center_pnt1(5,6,10);
-  CubitVector center_pnt2(5,-6,10);
+  CubitVector center_pnt1(5,8,10);
+  CubitVector center_pnt2(1,2,10);
+  CubitVector center_pnt3(-2,-3.5,10);
   list.append(&center_pnt1);
+  list.append(&center_pnt2);
   list.append(&center_pnt);
-  list.append(&center_pnt2);
-  //RefEdge* new_edge_1 = gmti->make_RefEdge(SPLINE_CURVE_TYPE, vertex1,
-  //                                         vertex2, list);
+  list.append(&center_pnt3);
+  RefEdge* new_edge_1 = gmti->make_RefEdge(SPLINE_CURVE_TYPE, vertex1,
+                                          vertex2, list);
+  d = new_edge_1->measure();
   //straight line
   RefEdge* new_edge_2 = gmti->make_RefEdge(STRAIGHT_CURVE_TYPE, vertex1,
@@ -381,30 +384,30 @@
   //arc curve
   RefEdge* new_edge_3 = gmti->make_RefEdge(ARC_CURVE_TYPE, vertex1,
-                                        vertex2, &center_pnt);
+                                        vertex3, &center_pnt);
   d = new_edge_3->measure();
   new_edge_3->closest_point_trimmed(vi, c_point);
   //ellipse curve
   RefEdge* new_edge_4 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex1,
   d = new_edge_4->measure();
   new_edge_4->closest_point_trimmed(vi, c_point);
   RefEdge* new_edge_5 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex1,
-                                        vertex2, &center_pnt, CUBIT_REVERSED);
+                                        vertex3, &center_pnt, CUBIT_REVERSED);
   d = new_edge_5->measure();
   new_edge_5->closest_point_trimmed(vi, c_point);
   //PARABOLA_CURVE_TYPE
   RefEdge* new_edge_6 = gmti->make_RefEdge(PARABOLA_CURVE_TYPE, vertex1,
   d = new_edge_6->measure();
   new_edge_6->closest_point_trimmed(vi, c_point);
   //HYPERBOLA_CURVE_TYPE
   RefEdge* new_edge_7 = gmti->make_RefEdge(HYPERBOLA_CURVE_TYPE, vertex1,
   d = new_edge_7->measure();
   new_edge_7->closest_point_trimmed(vi, c_point);
More information about the cgma-dev mailing list
