[cgma-dev] r1802 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Fri May  9 15:04:58 CDT 2008
Author: janehu
Date: 2008-05-09 15:04:58 -0500 (Fri, 09 May 2008)
New Revision: 1802
Modified:
   cgm/trunk/geom/OCC/OCCBody.cpp
   cgm/trunk/geom/OCC/OCCCurve.hpp
   cgm/trunk/geom/OCC/OCCLump.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCShell.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Still working on subtracting a body which makes a surface be divided into two surfaces case. there's some memory leaks, looking for reasons.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCBody.cpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -446,7 +446,8 @@
   int ii;
   for (ii=1; ii<=M.Extent(); ii++) {
 	  TopologyBridge *lump = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
-	  lumps.append_unique(lump);
+          if (lump)
+	    lumps.append_unique(lump);
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -35,7 +35,6 @@
 class OCCShell;
 class OCCSurface;
 class OCCLoop;
-class OCCCoEdge;
 class OCCPoint;
 class BRepBuilderAPI_Transform;
 class BRepAlgoAPI_BooleanOperation;
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -259,7 +259,8 @@
   int ii;
 	  TopologyBridge *shell = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
-	  shellsms.append_unique(shell);
+          if (shell)
+	    shellsms.append_unique(shell);
@@ -349,6 +350,11 @@
   //set the Shells
   TopTools_IndexedMapOfShape M;
   TopoDS_Shape shape;
+  TopExp::MapShapes(new_shape, TopAbs_SOLID,M);
+  if(M.Extent() > 1)
+    new_shape.Nullify();
+  M.Clear();
   TopExp::MapShapes(old_solid, TopAbs_SHELL, M);
   TopTools_ListOfShape shapes;
@@ -356,18 +362,34 @@
     TopoDS_Shell shell = TopoDS::Shell(M(ii));
-    if(!new_shape.IsNull())
+    TopTools_ListOfShape shapes;
+    shapes.Assign(op->Modified(shell));
+    if (shapes.Extent() == 1)
+      shape = shapes.First();
+    else if(shapes.Extent() > 1)
+      shape.Nullify();
+    else if(op->IsDeleted(shell))
-       TopTools_ListOfShape shapes;
-       shapes.Assign(op->Modified(shell));
-       if (shapes.Extent() > 0)
-         shape = shapes.First();
+       TopTools_IndexedMapOfShape M_new;
+       TopExp::MapShapes(new_shape, TopAbs_SHELL, M_new);
+       if (M_new.Extent()== 1)
+         shape = M_new(1);
+       else
+         shape.Nullify();
+    else
+       shape = shell;
+       continue;
     if(shapes.Extent() > 0 || op->IsDeleted(shell))
       OCCShell::update_OCC_entity(shell, shape, op);
   TopoDS_Solid new_solid;
-  if(!op->IsDeleted(old_solid))
+  if(!new_shape.IsNull() && !op->IsDeleted(old_solid))
     new_solid = TopoDS::Solid(new_shape);
   OCCQueryEngine::instance()->update_OCC_map(old_solid, new_solid);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -1197,7 +1197,8 @@
     OCCMap->Bind(*poshell, iTotalTBCreated);
     OccToCGM->insert(valType(iTotalTBCreated,
 		       (TopologyBridge*)shell));
+    shell->set_body(NULL);
+    shell->set_lump(NULL);
     if(standalone)
       OCCLump* lump = new OCCLump(NULL, NULL, shell);
@@ -1243,8 +1244,8 @@
       OCCCoFace * coface = new OCCCoFace( occ_surface, shell,
         ( topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
       cofaces_new.append(coface);
+      occ_surface->add_shell(shell);
-    occ_surface->add_shell(shell);
     if(standalone)
       occ_surface->set_shell(shell);
@@ -1270,6 +1271,9 @@
                              (TopologyBridge*)surface));
     SurfaceList->append(surface);
+    surface->set_body(NULL);
+    surface->set_lump(NULL);
+    surface->set_shell(NULL);
     if(build_body)
       OCCShell* shell = new OCCShell(NULL, surface);
@@ -1349,9 +1353,8 @@
       coedge = new OCCCoEdge( curve, loop,
         (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
       coedges_new.append(coedge);
-      total_coedges++;
+      occ_curve->add_loop(loop);
-    occ_curve->add_loop(loop);
   loop->coedges(coedges_new);
@@ -2522,7 +2525,7 @@
 int OCCQueryEngine::update_OCC_map(TopoDS_Shape old_shape,
-                                    TopoDS_Shape new_shape)
+                                   TopoDS_Shape new_shape)
   if (!OCCMap->IsBound(old_shape) || old_shape.IsEqual(new_shape))
     return -1;
@@ -2552,11 +2555,40 @@
     else
       ShellSM * shell = CAST_TO(tb, ShellSM);
-      if(shell && CAST_TO(shell, OCCShell)->my_lump())
+      if(shell)
-        unhook_ShellSM_from_OCC(shell);
-        delete shell;
+        DLIList<OCCCoFace*> children;
+        children = CAST_TO(shell, OCCShell)->cofaces();
+        while(children.size())
+          OCCCoFace* coface = children.pop();
+          CAST_TO(coface->surface(),OCCSurface)->remove_shell(CAST_TO(shell, OCCShell));
+          delete coface;
+        OCCLump* lump = CAST_TO(shell, OCCShell)->my_lump();
+        if(lump)
+          delete CAST_TO(shell, OCCShell)->my_body();
+          delete lump;
+          unhook_ShellSM_from_OCC(shell);
+          delete shell;
+      LoopSM* loop = CAST_TO(tb, LoopSM);
+      if(loop)
+         DLIList<OCCCoEdge*> children;
+         children = CAST_TO(loop, OCCLoop)->coedges();
+           OCCCoEdge* coedge = children.pop();
+           CAST_TO(coedge->curve(), OCCCurve)->remove_loop(CAST_TO(loop, OCCLoop));
+           delete coedge;
+         unhook_LoopSM_from_OCC(loop);
+         delete loop;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCShell.cpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -172,7 +172,8 @@
   int ii;
 	  TopologyBridge *surface = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
-	  children.append_unique(surface);
+          if(surface)
+	    children.append_unique(surface);
@@ -268,8 +269,11 @@
     TopoDS_Face face = TopoDS::Face(M(ii));
     shapes.Assign(op->Modified(face));
-    if(shapes.Extent() > 0)
+    if(shapes.Extent() == 1)
+    else
+      shape.Nullify();
     if(shapes.Extent() > 0 || op->IsDeleted(face))
       OCCSurface::update_OCC_entity(face,shape, op);
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2008-05-09 19:38:34 UTC (rev 1801)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2008-05-09 20:04:58 UTC (rev 1802)
@@ -720,7 +720,8 @@
   int ii;
      TopologyBridge *loop = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
-     children.append_unique(loop);
+     if(loop)
+       children.append_unique(loop);
@@ -832,25 +833,27 @@
   for (int ii=1; ii<=M.Extent(); ii++)
      TopoDS_Wire wire = TopoDS::Wire(M(ii));
-     if(!new_surface.IsNull())
+     shapes.Assign(op->Modified(wire));
+       shape.Nullify();
+     else if(op->IsDeleted(wire))
-       shapes.Assign(op->Modified(wire));
-       else if(op->IsDeleted(wire))
-         TopTools_IndexedMapOfShape M_new;
-         TopExp::MapShapes(new_surface, TopAbs_WIRE, M_new);
-         if (M_new.Extent()>= ii)
-           shape = M_new(ii);
+       TopExp::MapShapes(new_surface, TopAbs_WIRE, M_new);
+         shape = M_new(1);
        else
-         shape = wire;
-         continue;
+         shape.Nullify();
+     else
+       shape = wire;
+       continue;
      //set curves
      BRepTools_WireExplorer Ex;
@@ -858,10 +861,12 @@
        TopoDS_Edge edge = Ex.Current();
        shapes.Assign(op->Modified(edge));
          shape_edge = shapes.First();
+       else if (shapes.Extent() > 1)
+         shape_edge.Nullify();
        else if (op->IsDeleted(edge))
        else
          shape_edge = edge;
@@ -874,9 +879,12 @@
        //update vertex
        TopoDS_Vertex vertex = Ex.CurrentVertex();
        shapes.Assign(op->Modified(vertex));
          shape_vertex = shapes.First();
+       else
+         shape_vertex.Nullify();
        if(shapes.Extent() > 0 || op->IsDeleted(vertex))
          OCCQueryEngine::instance()->update_OCC_map(vertex, shape_vertex);
More information about the cgma-dev
