[cgma-dev] r1799 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Wed May  7 14:18:58 CDT 2008
Author: janehu
Date: 2008-05-07 14:18:58 -0500 (Wed, 07 May 2008)
New Revision: 1799
Modified:
   cgm/trunk/geom/OCC/OCCLump.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
When subtract a body from a body, the original body is deleted and new body will be created, this part is different than ACIS; unaffacted surface will remain unchanged, this part is the same in ACIS. Now still has bugs in subtracting which makes original surface becoming two surfaces.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-06 21:49:04 UTC (rev 1798)
+++ cgm/trunk/geom/OCC/OCCLump.cpp	2008-05-07 19:18:58 UTC (rev 1799)
@@ -343,7 +343,7 @@
 // Author: Jane Hu
 CubitStatus OCCLump::update_OCC_entity(TopoDS_Solid& old_solid,
-                                       TopoDS_Shape& new_solid,
+                                       TopoDS_Shape& new_shape,
                                        BRepAlgoAPI_BooleanOperation *op)
   //set the Shells
@@ -356,7 +356,7 @@
     TopoDS_Shell shell = TopoDS::Shell(M(ii));
-    if(!new_solid.IsNull())
+    if(!new_shape.IsNull())
        TopTools_ListOfShape shapes;
        shapes.Assign(op->Modified(shell));
@@ -366,5 +366,8 @@
     if(shapes.Extent() > 0 || op->IsDeleted(shell))
       OCCShell::update_OCC_entity(shell, shape, op);
+  TopoDS_Solid new_solid;
+  if(!op->IsDeleted(old_solid))
+    new_solid = TopoDS::Solid(new_shape);
   OCCQueryEngine::instance()->update_OCC_map(old_solid, new_solid);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-06 21:49:04 UTC (rev 1798)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-05-07 19:18:58 UTC (rev 1799)
@@ -1824,7 +1824,7 @@
         //got cut. Update the entities
         if(after_mass > tol*tol*tol)
-          TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
+          TopoDS_Solid old_solid = TopoDS::Solid(cutter.Shape1());
           OCCLump::update_OCC_entity(old_solid , cut_shape, &cutter);
@@ -1902,12 +1902,6 @@
     delete tool_boxes.pop();
   while (tool_bodies_copy.size())
     delete tool_bodies_copy.pop();
-  if (!keep_old)
-    from_bodies.remove_all_with_value(NULL);
-    OCCQueryEngine::instance()->delete_solid_model_entities(from_bodies);
-    OCCQueryEngine::instance()->delete_solid_model_entities( tool_body_list);
   return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-06 21:49:04 UTC (rev 1798)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-07 19:18:58 UTC (rev 1799)
@@ -1185,6 +1185,7 @@
   OCCShell *shell ;
   CubitBoolean build_body = CUBIT_FALSE;
+  DLIList<OCCCoFace*> cofaces_old, cofaces_new;
   if (!OCCMap->IsBound(aShape))
     if(PRINT_RESULT)
@@ -1210,6 +1211,7 @@
     int k = OCCMap->Find(aShape);
     shell = (OCCShell*)(OccToCGM->find(k))->second;
+    cofaces_old =  shell->cofaces();
     shell->set_TopoDS_Shell(aShape);
@@ -1222,15 +1224,32 @@
       populate_topology_bridge(topo_face, build_body);
     OCCSurface *occ_surface = CAST_TO(face, OCCSurface);
-    OCCCoFace * coface = new OCCCoFace( occ_surface, shell,
+    CubitBoolean exist = CUBIT_FALSE;
+    OCCCoFace * coface = NULL;
+    int size = cofaces_old.size();
+    for(int i = 0; i < size; i++)
+      coface = cofaces_old.pop();
+      if(coface->surface() == occ_surface)
+        exist = CUBIT_TRUE;
+        coface->set_sense(topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
+        cofaces_new.append(coface);
+        break;
+    if(!exist)
+      OCCCoFace * coface = new OCCCoFace( occ_surface, shell,
         ( topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
-    cofaces.append(coface);
     occ_surface->add_shell(shell);
     if(standalone)
       occ_surface->set_shell(shell);
-  shell->cofaces(cofaces);
+  shell->cofaces(cofaces_new);
   return shell;
@@ -1437,11 +1456,12 @@
      if (remove_lower_entities)
        return delete_solid_model_entities(body);
+     DLIList<TopologyBridge*> children;
+       CAST_TO(lump, OCCLump)->get_children_virt(children);
      CubitStatus stat = this->unhook_BodySM_from_OCC(body);
      if(stat)
-       DLIList<TopologyBridge*> children;
-       CAST_TO(lump, OCCLump)->get_children_virt(children);
        while (children.size())
           delete children.pop();
        delete lump;
@@ -2504,7 +2524,7 @@
 int OCCQueryEngine::update_OCC_map(TopoDS_Shape old_shape,
                                     TopoDS_Shape new_shape)
-  if (!OCCMap->IsBound(old_shape))
+  if (!OCCMap->IsBound(old_shape) || old_shape.IsEqual(new_shape))
     return -1;
   int k = OCCMap->Find(old_shape);
@@ -2532,7 +2552,7 @@
     else
       ShellSM * shell = CAST_TO(tb, ShellSM);
-      if(shell)
+      if(shell && CAST_TO(shell, OCCShell)->my_lump())
         unhook_ShellSM_from_OCC(shell);
         delete shell;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2008-05-06 21:49:04 UTC (rev 1798)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2008-05-07 19:18:58 UTC (rev 1799)
@@ -863,16 +863,14 @@
        else if (op->IsDeleted(edge))
        else
          shape_edge = edge;
-         continue;
        if(wire.Orientation() == TopAbs_REVERSED && !shape_edge.IsNull())
          shape_edge.Orientation(
           shape_edge.Orientation()==TopAbs_FORWARD? TopAbs_REVERSED:TopAbs_FORWARD);
        //update vertex
        TopoDS_Vertex vertex = Ex.CurrentVertex();
        shapes.Assign(op->Modified(vertex));
More information about the cgma-dev
