[cgma-dev] r1805 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Mon May 12 13:43:28 CDT 2008
Author: janehu
Date: 2008-05-12 13:43:28 -0500 (Mon, 12 May 2008)
New Revision: 1805
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
still debugging on the testcase for subtracting making one face become two.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-11 21:49:37 UTC (rev 1804)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-05-12 18:43:28 UTC (rev 1805)
@@ -1228,21 +1228,25 @@
     CubitBoolean exist = CUBIT_FALSE;
     OCCCoFace * coface = NULL;
     int size = cofaces_old.size();
+    CubitSense sense ;
+    if( aShape.Orientation() == CUBIT_REVERSED )
+      sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
+    else
+      sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
     for(int i = 0; i < size; i++)
       coface = cofaces_old.pop();
       if(coface->surface() == occ_surface)
         exist = CUBIT_TRUE;
-        coface->set_sense(topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
+        coface->set_sense(sense);
         cofaces_new.append(coface);
         break;
     if(!exist)
-      OCCCoFace * coface = new OCCCoFace( occ_surface, shell,
-        ( topo_face.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
+      OCCCoFace * coface = new OCCCoFace( occ_surface, shell, sense);
       occ_surface->add_shell(shell);
@@ -1329,29 +1333,33 @@
   BRepTools_WireExplorer Ex;
   DLIList <OCCCoEdge*> coedges_old, coedges_new;
+  coedges_old = loop->coedges();
   for (Ex.Init(aShape); Ex.More(); Ex.Next())
     Curve* curve = populate_topology_bridge(Ex.Current());
     OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
-    coedges_old = loop->coedges();
     OCCCoEdge * coedge = NULL;
     int size = coedges_old.size();
+      sense = (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
+    else
+      sense = (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
       coedge = coedges_old.pop();
       if(coedge->curve() == curve)
         exist = CUBIT_TRUE;
-        coedge->set_sense(Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
+        coedge->set_sense(sense);
         coedges_new.append(coedge);
         break;
     if(!exist)
-      coedge = new OCCCoEdge( curve, loop,
-        (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
+      coedge = new OCCCoEdge( curve, loop, sense);
       occ_curve->add_loop(loop);
More information about the cgma-dev mailing list
