[cgma-dev] r1612 - in cgm/trunk: . geom geom/ACIS_SRC geom/Cholla geom/OCC geom/facet geom/facetbool geom/parallel geom/virtual test
kraftche at mcs.anl.gov
Thu Feb 21 13:20:44 CST 2008
Author: kraftche
Date: 2008-02-21 13:20:44 -0600 (Thu, 21 Feb 2008)
New Revision: 1612
Modified:
cgm/trunk/configure.in
cgm/trunk/geom/ACIS_SRC/Makefile.am
cgm/trunk/geom/Cholla/Makefile.am
cgm/trunk/geom/Makefile.am
cgm/trunk/geom/OCC/Makefile.am
cgm/trunk/geom/facet/Makefile.am
cgm/trunk/geom/facetbool/Makefile.am
cgm/trunk/geom/parallel/Makefile.am
cgm/trunk/geom/virtual/Makefile.am
cgm/trunk/test/Makefile.am
Log:
o Correctly specify library dependencies on exteran libs (e.g. ACIS or OCC libs)
o Specify inter-library dependencies for CGMA libs.
- fixes possible broken shared library build on some platforms (those
that require shared lib to have all symbols resolved)
- can simplify linking w/in CGMA (e.g. specifying libcubit_ACIS.la
automatically includes libcubit_util.la and libcubit_geom.la)
- libtool might be able to resolve link order better
- shared libraries have correct dependencies
o Specify rpath (-R) for tests.
- libtool seems to determine required rpaths automatically only for *.la
libraries (such as OpenCascade build with libtool.) Or maybe it
just doesn't like ACIS, but either way this fixes the problem.
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/configure.in 2008-02-21 19:20:44 UTC (rev 1612)
@@ -256,11 +256,13 @@
# Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
if test "x$occ_DIR" = "x"; then
OCC_INC_FLAG=
+ OCC_LIB_DIR=
OCC_LIB_FLAG=
else
uname=`uname`
OCC_INC_FLAG="-I${occ_DIR}/ros/inc"
- OCC_LIB_FLAG="-L${occ_DIR}/ros/${uname}/lib"
+ OCC_LIB_DIR="${occ_DIR}/ros/${uname}/lib"
+ OCC_LIB_FLAG='-L$(OCC_LIB_DIR)'
fi
# Check of OCC is present and working
@@ -269,7 +271,7 @@
old_CPPFLAGS="$CPPFLAGS"
old_LDFLAGS="$LDFLAGS"
CPPFLAGS="$CPPFLAGS ${OCC_INC_FLAG}"
- LDFLAGS="$LDFLAGS ${OCC_LIB_FLAG}"
+ LDFLAGS="$LDFLAGS -L$OCC_LIB_DIR"
# Check if 64-bit
AC_MSG_CHECKING([if platform is 64-bit (-D_OCC64)])
@@ -304,6 +306,7 @@
# Export these variables as variables in Makefiles
AC_SUBST(OCC_INC_FLAG)
+AC_SUBST(OCC_LIB_DIR)
AC_SUBST(OCC_LIB_FLAG)
AC_SUBST(OCC_LIBS)
AC_SUBST(CUBIT_OCC_LIB)
Modified: cgm/trunk/geom/ACIS_SRC/Makefile.am
--- cgm/trunk/geom/ACIS_SRC/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/ACIS_SRC/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -6,7 +6,6 @@
$(LITTLE_ENDIAN) $(ACIS_STEP_TRANSLATOR) $(ACIS_IGES_TRANSLATOR) \
-DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$(ACIS_VERSION) \
-D$(ACIS_PLATFORM) -DACIS_LOCAL_OPS -DACIS_VER=$(ACIS_VERSION)
-LIBS := -L$(ACIS_LIB_DIR) $(ACIS_LIBS) $(LIBS)
INCLUDES = -I$(top_srcdir)/util \
-I$(top_srcdir)/geom \
-I$(srcdir)/gtcAttrib/incl \
@@ -81,3 +80,6 @@
gtcAttrib/incl/attrib_name.h \
gtcAttrib/incl/gtcAttrib_exConst.h
+libcubit_ACIS_la_LIBADD = -L$(ACIS_LIB_DIR) $(ACIS_LIBS) \
+ ../libcubit_geom.la
Modified: cgm/trunk/geom/Cholla/Makefile.am
--- cgm/trunk/geom/Cholla/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/Cholla/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -11,6 +11,8 @@
lib_LTLIBRARIES += libcholla.la
endif
+libcholla_la_LIBADD = ../libcubit_geom.la
# The directory where headers will be installed
libcholla_la_includedir = $(includedir)
Modified: cgm/trunk/geom/Makefile.am
--- cgm/trunk/geom/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -4,7 +4,7 @@
# Subdirectories
# The values checked are defined in AM_CONDITIONAL statements
# in configure.in
-SUBDIRS = Cholla facet facetbool virtual
+SUBDIRS = . Cholla facetbool facet virtual
if build_ACIS
SUBDIRS += ACIS
endif
@@ -25,6 +25,8 @@
lib_LTLIBRARIES += libcubit_geom.la
endif
+libcubit_geom_la_LIBADD = ../util/libcubit_util.la
libcubit_geom_la_includedir = $(includedir)
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/OCC/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -4,7 +4,6 @@
# Override default defines with the ones we want from the configure script
DEFAULT_INCLUDES=-I.
DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN)
-LIBS := $(OCC_LIB_FLAG)
-I$(top_srcdir)/geom/Cholla \
@@ -22,6 +21,9 @@
lib_LTLIBRARIES += $(OCC_TARGET)
endif
+libcubit_OCC_la_LIBADD = $(OCC_LIB_FLAG) $(OCC_LIBS) \
libcubit_OCC_la_includedir = $(includedir)
Modified: cgm/trunk/geom/facet/Makefile.am
--- cgm/trunk/geom/facet/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/facet/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -14,6 +14,10 @@
lib_LTLIBRARIES += libcubit_facet.la
endif
+libcubit_facet_la_LIBADD = ../libcubit_geom.la \
+ ../facetbool/libcubit_facetbool.la \
+ ../Cholla/libcholla.la
libcubit_facet_la_includedir = $(includedir)
Modified: cgm/trunk/geom/facetbool/Makefile.am
--- cgm/trunk/geom/facetbool/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/facetbool/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -12,6 +12,8 @@
lib_LTLIBRARIES += libcubit_facetbool.la
endif
+libcubit_facetbool_la_LIBADD= ../libcubit_geom.la
libcubit_facetbool_la_includedir = $(includedir)
Modified: cgm/trunk/geom/parallel/Makefile.am
--- cgm/trunk/geom/parallel/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/parallel/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -8,8 +8,6 @@
-D$(ACIS_PLATFORM)
-I$(top_srcdir)/geom/ACIS \
@@ -22,6 +20,8 @@
lib_LTLIBRARIES += libcubit_parallel.la
endif
+libcubit_parallel_la_LIBADD = ../libcubit_geom.la ../ACIS/libcubit_ACIS.la
libcubit_parallel_la_includedir = $(includedir)
Modified: cgm/trunk/geom/virtual/Makefile.am
--- cgm/trunk/geom/virtual/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/geom/virtual/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -14,6 +14,8 @@
lib_LTLIBRARIES += libcubit_virtual.la
endif
+libcubit_virtual_la_LIBADD = ../libcubit_geom.la
libcubit_virtual_la_includedir = $(includedir)
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
+++ cgm/trunk/test/Makefile.am 2008-02-21 19:20:44 UTC (rev 1612)
@@ -9,37 +9,29 @@
-I$(top_srcdir)/geom/OCC \
-I$(srcdir) \
- $(OCC_INC_FLAG) \
- -I..\$(OCC_INC_FLAG)
+ $(OCC_INC_FLAG)
TESTS=
-if WITH_OCC
- TESTS += makept
-endif
if build_ACIS
TESTS += webcut
endif
+if WITH_OCC
+ TESTS += makept
+endif
CPPFLAGS += -DSRCDIR=@srcdir@
check_PROGRAMS = $(TESTS)
webcut_SOURCES = webcut.cpp
makept_SOURCES = makept.cpp
-opt_libs=
LDADD = ../geom/virtual/libcubit_virtual.la \
../geom/facetbool/libcubit_facetbool.la \
- $(opt_libs) \
../geom/Cholla/libcholla.la \
../geom/facet/libcubit_facet.la \
../geom/libcubit_geom.la \
+webcut_LDFLAGS = $(LDFLAGS) -R$(ACIS_LIB_DIR)
+webcut_LDADD = ../geom/ACIS/libcubit_ACIS.la $(LDADD)
+makept_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
+makept_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
-if build_ACIS
- opt_libs += ../geom/ACIS/libcubit_ACIS.la
-endif
-if WITH_OCC
- opt_libs += ../geom/OCC/libcubit_OCC.la $(OCC_LIB_FLAG) $(OCC_LIBS)
-endif
More information about the cgma-dev
