[cgma-dev] r1611 - cgm/trunk/test
kraftche at mcs.anl.gov
Thu Feb 21 11:38:11 CST 2008
Author: kraftche
Date: 2008-02-21 11:38:11 -0600 (Thu, 21 Feb 2008)
New Revision: 1611
Modified:
cgm/trunk/test/Makefile.am
cgm/trunk/test/webcut.cpp
Log:
look for input file in correct spot if separate build tree
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-02-21 17:33:39 UTC (rev 1610)
+++ cgm/trunk/test/Makefile.am 2008-02-21 17:38:11 UTC (rev 1611)
@@ -20,6 +20,7 @@
TESTS += webcut
endif
+CPPFLAGS += -DSRCDIR=@srcdir@
check_PROGRAMS = $(TESTS)
webcut_SOURCES = webcut.cpp
Modified: cgm/trunk/test/webcut.cpp
--- cgm/trunk/test/webcut.cpp 2008-02-21 17:33:39 UTC (rev 1610)
+++ cgm/trunk/test/webcut.cpp 2008-02-21 17:38:11 UTC (rev 1611)
@@ -32,6 +32,9 @@
#include "RefEntityFactory.hpp"
#include "RefEdge.hpp"
+#define STRINGIFY(S) XSTRINGIFY(S)
+#define XSTRINGIFY(S) #S
// forward declare some functions used and defined later
CubitStatus read_geometry(int, char **);
CubitStatus evaluate_overlaps();
@@ -133,7 +136,7 @@
GeometryModifyTool *gmti = GeometryModifyTool::instance();
// Read in the geometry from files specified on the command line
- char *argv = "./model2.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model2.sat";
CubitStatus status = read_geometry(1, &argv);
if (status == CUBIT_FAILURE) exit(1);
else if (gti->num_bodies() == 0) {
@@ -161,7 +164,7 @@
DLIList<RefEntity*> ref_entity_list;
int num_ents_exported=0;
const CubitString cubit_version="10.2";
- const char * filename = "webcut_with_brick.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_brick.sat";
const char * filetype = "ACIS_SAT";
rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
num_ents_exported, cubit_version);
@@ -188,7 +191,7 @@
@@ -212,7 +215,7 @@
- const char * filename = "webcut_with_cylinder.sat";
+ const char * filename = STRINGIFY(SRCDIR) "webcut_with_cylinder.sat";
@@ -239,7 +242,7 @@
@@ -265,7 +268,7 @@
- const char * filename = "webcut_with_sheet.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sheet.sat";
@@ -293,7 +296,7 @@
- char *argv = "./huge.sat";
+ char *argv = STRINGIFY(SRCDIR) "/huge.sat";
@@ -333,7 +336,7 @@
- const char * filename = "webcut_with_sweep_rotational.sat";
+ const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_rotational.sat";
@@ -359,7 +362,7 @@
- char *argv = "./model3.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model3.sat";
@@ -393,7 +396,7 @@
- const char * filename = "webcut_with_sweep_curves.sat";
+ const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_curves.sat";
@@ -419,7 +422,7 @@
@@ -464,7 +467,7 @@
- const char * filename = "webcut_with_sweep_along_curve.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_along_curve.sat";
@@ -490,7 +493,7 @@
- char *argv = "./model4.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model4.sat";
@@ -521,7 +524,7 @@
- const char * filename = "webcut_with_curve_loop.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_curve_loop.sat";
@@ -547,7 +550,7 @@
- char *argv = "./model5.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model5.sat";
@@ -574,7 +577,7 @@
- const char * filename = "webcut_with_extended_surf.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_extended_surf.sat";
@@ -594,7 +597,7 @@
- char *argv = "./model7.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model7.sat";
@@ -625,7 +628,7 @@
- const char * filename = "webcut_with_sweep_surfaces_rotated.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_rotated.sat";
@@ -645,7 +648,7 @@
- char *argv = "./model6.sat";
+ char *argv = STRINGIFY(SRCDIR) "/model6.sat";
@@ -675,7 +678,7 @@
- const char * filename = "webcut_with_sweep_surfaces.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces.sat";
@@ -695,7 +698,7 @@
@@ -735,7 +738,7 @@
- const char * filename = "webcut_with_sweep_surfaces_along_curve.sat";
+ const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_along_curve.sat";
@@ -755,7 +758,7 @@
More information about the cgma-dev
