[cgma-dev] r1601 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Feb 19 12:38:04 CST 2008
Author: janehu
Date: 2008-02-19 12:38:03 -0600 (Tue, 19 Feb 2008)
New Revision: 1601
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Changed make_Surface to create topologically and geometrically identical surfaces, passed test.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-02-18 22:41:20 UTC (rev 1600)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-02-19 18:38:03 UTC (rev 1601)
@@ -155,7 +155,7 @@
TopoDS_Face * face = mySheetSurface->get_TopoDS_Face();
aBRepTrsf.Perform(*face);
- OCCQueryEngine::update_entity_shape((GeometryEntity*)mySheetSurface, aBRepTrsf);
+ OCCQueryEngine::instance()->update_entity_shape(mySheetSurface, aBRepTrsf);
else
@@ -192,7 +192,7 @@
- OCCQueryEngine::update_entity_shape(mySheetSurface, aBRepTrsf);
else
@@ -223,7 +223,7 @@
else
@@ -274,7 +274,7 @@
else
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-18 22:41:20 UTC (rev 1600)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-19 18:38:03 UTC (rev 1601)
@@ -523,22 +523,6 @@
return (Surface *)NULL;
- //Testing for number of Vertices.
- DLIList<OCCCurve*> curve_list;
- DLIList<OCCPoint*> point_list;
- occ_surface->get_curves(curve_list);
- for (int i = 0; i < curve_list.size(); i++)
- curve_list.get_and_step()->get_points(point_list);
- point_list.uniquify_unordered();
- TopoDS_Face * Face = occ_surface->get_TopoDS_Face();
- TopExp_Explorer Ex;
- int count = 0;
- for (Ex.Init(*Face, TopAbs_VERTEX); Ex.More(); Ex.Next())
- count++;
//Start of the codes
double UMax, VMax, UMin, VMin;
occ_surface->get_param_range_U(UMin, UMax);
@@ -641,36 +625,6 @@
Surface *surface = OCCQueryEngine::instance()->populate_topology_bridge(
newFace, CUBIT_TRUE);
- //get new parameters
- asurface.Initialize(newFace);
- U1 = asurface.FirstUParameter();
- U2 = asurface.LastUParameter();
- V1 = asurface.FirstVParameter();
- V2 = asurface.LastVParameter();
- //populate the bridges from the body
- Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(newFace);
- TopoDS_Shell topo_shell;
- topo_shell = BRepBuilderAPI_MakeShell(HGeom_surface, U1, U2, V1, V2);
- TopoDS_Solid topo_solid = BRepBuilderAPI_MakeSolid(topo_shell);
- Lump *lump =
- OCCQueryEngine::instance()->populate_topology_bridge(topo_solid,
- CUBIT_TRUE);
- if (lump == NULL)
- PRINT_ERROR("In AcisModifyEngine::make_Surface\n"
- " Cannot make Surface object.\n");
- return (Surface *)NULL;
- DLIList<Surface*> surfs;
- lump->surfaces( surfs );
- Surface *surface = surfs.get();
return surface;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-18 22:41:20 UTC (rev 1600)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-19 18:38:03 UTC (rev 1601)
@@ -1199,9 +1199,9 @@
if(build_body)
- OCCShell* shell(NULL, surface);
- OCCLump* lump(NULL, surface);
- OCCBody* body(NULL, CUBIT_TRUE, surface);
+ OCCShell* shell = new OCCShell(NULL, surface);
+ OCCLump* lump = new OCCLump(NULL, surface);
+ OCCBody* body = new OCCBody(NULL, CUBIT_TRUE, surface);
surface->set_body(body);
surface->set_lump(lump);
surface->set_shell(shell);
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp 2008-02-18 22:41:20 UTC (rev 1600)
+++ cgm/trunk/geom/OCC/OCCShell.hpp 2008-02-19 18:38:03 UTC (rev 1601)
@@ -42,7 +42,7 @@
public:
- OCCShell(TopoDS_Shell *theShell, OCCSurface surface = NULL);
+ OCCShell(TopoDS_Shell *theShell, OCCSurface* surface = NULL);
virtual ~OCCShell() ;
//- Destructor.
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-02-18 22:41:20 UTC (rev 1600)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-02-19 18:38:03 UTC (rev 1601)
@@ -669,6 +669,12 @@
void OCCSurface::get_parents_virt( DLIList<TopologyBridge*>& parents )
+ if (myBody) //sheet body
+ parents.append(myBody);
+ return;
OCCQueryEngine* oqe = (OCCQueryEngine*) get_geometry_query_engine();
OCCBody * body = NULL;
DLIList <OCCBody* > *bodies = oqe->BodyList;
More information about the cgma-dev
