[cgma-dev] r1600 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Feb 18 16:41:21 CST 2008
Author: janehu
Date: 2008-02-18 16:41:20 -0600 (Mon, 18 Feb 2008)
New Revision: 1600
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCShell.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added for free surface update for all upper level entities.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -59,10 +59,12 @@
// Special Notes :
-OCCBody::OCCBody(TopoDS_CompSolid *theShape)
+OCCBody::OCCBody(TopoDS_CompSolid *theShape, CubitBoolean isSheetBody,
+ OCCSurface* surface)
myTopoDSShape = theShape;
+ IsSheetBody = isSheetBody;
+ mySheetSurface = surface;
update_bounding_box();
@@ -84,6 +86,7 @@
B.Add(Co, *solid);
myTopoDSShape = new TopoDS_CompSolid(Co);
+ IsSheetBody = CUBIT_FALSE;
@@ -146,10 +149,21 @@
gp_Trsf aTrsf;
aTrsf.SetTranslation(aVec);
- BRepBuilderAPI_Transform aBRepTrsf(*myTopoDSShape, aTrsf);
+ BRepBuilderAPI_Transform aBRepTrsf(aTrsf);
+ if(IsSheetBody)
+ TopoDS_Face * face = mySheetSurface->get_TopoDS_Face();
+ aBRepTrsf.Perform(*face);
+ OCCQueryEngine::update_entity_shape((GeometryEntity*)mySheetSurface, aBRepTrsf);
+ else
+ aBRepTrsf.Perform(*myTopoDSShape);
+ update_OCC_entity(aBRepTrsf);
// calculate for bounding box
- update_OCC_entity(aBRepTrsf);
return CUBIT_SUCCESS;
@@ -173,10 +187,20 @@
gp_Trsf aTrsf;
aTrsf.SetRotation(anAxis, angle);
+ if(IsSheetBody)
+ OCCQueryEngine::update_entity_shape(mySheetSurface, aBRepTrsf);
+ else
@@ -194,10 +218,20 @@
gp_Trsf aTrsf;
aTrsf.SetScaleFactor(scale_factor);
+ if(IsSheetBody)
+ else
@@ -235,11 +269,21 @@
gp_Trsf aTrsf;
aTrsf.SetMirror(anAx2);
+ if(IsSheetBody)
+ else
// update underlining OCC entities
+ update_bounding_box();
@@ -252,6 +296,9 @@
CubitStatus OCCBody::update_OCC_entity( BRepBuilderAPI_Transform &aBRepTrsf)
+ if(IsSheetBody)
+ return CUBIT_FAILURE;
TopoDS_Shape shape = aBRepTrsf.Shape();
TopoDS_CompSolid compsolid = TopoDS::CompSolid(shape);
@@ -297,7 +344,12 @@
void OCCBody::update_bounding_box()
Bnd_Box box;
- const TopoDS_Shape shape=*myTopoDSShape;
+ TopoDS_Shape shape;
+ if(IsSheetBody)
+ shape = *(mySheetSurface->get_TopoDS_Face());
+ else
+ shape=*myTopoDSShape;
//calculate the bounding box
BRepBndLib::Add(shape, box);
double min[3], max[3];
@@ -325,6 +377,12 @@
void OCCBody::get_children_virt( DLIList<TopologyBridge*>& lumps )
+ if (IsSheetBody)
+ lumps.append(mySheetSurface->my_lump());
+ return;
TopTools_IndexedMapOfShape M;
TopExp::MapShapes(*myTopoDSShape, TopAbs_SOLID, M);
int ii;
@@ -347,6 +405,8 @@
CubitStatus OCCBody::mass_properties( CubitVector& centroid,
double& volume )
+ if(IsSheetBody)
GProp_GProps myProps;
BRepGProp::VolumeProperties(*myTopoDSShape, myProps);
volume = myProps.Mass();
@@ -367,6 +427,9 @@
CubitPointContainment OCCBody::point_containment( const CubitVector &point )
+ if(IsSheetBody)
+ return CUBIT_PNT_UNKNOWN;
CubitPointContainment pc_value;
OCCLump *lump;
@@ -396,6 +459,11 @@
void OCCBody::get_all_surfaces(DLIList<OCCSurface*> &surfaces)
+ if(IsSheetBody)
+ surfaces.append(mySheetSurface);
+ return;
TopExp::MapShapes(*myTopoDSShape, TopAbs_FACE, M);
int ii;
@@ -419,8 +487,14 @@
void OCCBody::get_all_curves(DLIList<OCCCurve*> &curves)
+ if(IsSheetBody)
+ else
+ shape = *myTopoDSShape;
- TopExp::MapShapes(*myTopoDSShape, TopAbs_EDGE, M);
+ TopExp::MapShapes(shape, TopAbs_EDGE, M);
int ii;
for (ii=1; ii<=M.Extent(); ii++) {
TopologyBridge *curve = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
@@ -442,8 +516,14 @@
void OCCBody::get_all_points(DLIList<OCCPoint*> &points)
+ if(IsSheetBody)
+ else
- TopExp::MapShapes(*myTopoDSShape, TopAbs_VERTEX, M);
+ TopExp::MapShapes(shape, TopAbs_VERTEX, M);
int ii;
TopologyBridge *vertex = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -46,7 +46,9 @@
public:
- OCCBody(TopoDS_CompSolid *theShape);
+ OCCBody(TopoDS_CompSolid *theShape, CubitBoolean isSheetBody = CUBIT_FALSE,
+ OCCSurface* surface = NULL);
OCCBody(DLIList<Lump*>& my_lumps);
void lumps(DLIList<Lump*>& my_lumps); //add lump list to myLumps
DLIList<Lump*> lumps(){return myLumps;}
@@ -182,6 +184,10 @@
TopoDS_CompSolid *myTopoDSShape;
CubitBox boundingbox;
+ CubitBoolean IsSheetBody;
+ OCCSurface* mySheetSurface;
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -64,9 +64,10 @@
// Special Notes :
-OCCLump::OCCLump(TopoDS_Solid *theSolid)
+OCCLump::OCCLump(TopoDS_Solid *theSolid, OCCSurface* surface)
myTopoDSSolid = theSolid;
OCCLump::~OCCLump()
@@ -84,6 +85,9 @@
CubitStatus OCCLump::mass_properties( CubitVector& centroid,
double& volume )
+ if (mySheetSurface)
BRepGProp::VolumeProperties(*myTopoDSSolid, myProps);
@@ -170,7 +174,12 @@
CubitBox OCCLump::bounding_box() const
Bnd_Box box;
- const TopoDS_Shape shape=*myTopoDSSolid;
+ if(mySheetSurface)
+ else
+ shape =*myTopoDSSolid;
@@ -206,6 +215,8 @@
double OCCLump::measure()
+ return 0.0;
return myProps.Mass();
@@ -213,11 +224,19 @@
void OCCLump::get_parents_virt(DLIList<TopologyBridge*> &bodies)
- bodies.append(myBodyPtr);
+ bodies.append(mySheetSurface->my_body());
+ else
+ bodies.append(myBodyPtr);
void OCCLump::get_children_virt(DLIList<TopologyBridge*> &shellsms)
+ shellsms.append(mySheetSurface->my_shell());
+ return;
TopExp::MapShapes(*myTopoDSSolid, TopAbs_SHELL, M);
int ii;
@@ -231,6 +250,9 @@
CubitPointContainment OCCLump::point_containment( const CubitVector &point )
BOP_SolidClassifier ps;
TopoDS_Solid * solid = get_TopoDS_Solid();
gp_Pnt pnt(point.x(), point.y(), point.z());
@@ -261,6 +283,9 @@
CubitStatus OCCLump::update_OCC_entity( BRepBuilderAPI_Transform &aBRepTrsf)
TopoDS_Shape shape = aBRepTrsf.ModifiedShape(*get_TopoDS_Solid());
TopoDS_Solid solid = TopoDS::Solid(shape);
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -44,7 +44,7 @@
public:
- OCCLump(TopoDS_Solid *theSolid);
+ OCCLump(TopoDS_Solid *theSolid, OCCSurface* surface = NULL);
virtual ~OCCLump();
//- The destructor
@@ -159,6 +159,8 @@
OCCAttribSet attribSet;
//List of OCCAttrib*'s instead of CubitSimpleAttribs
+ OCCSurface *mySheetSurface;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -638,8 +638,10 @@
newFace = TopoDS::Face(newShape);
- Surface *temp_surface = OCCQueryEngine::instance()->populate_topology_bridge(
- newFace);
+ Surface *surface = OCCQueryEngine::instance()->populate_topology_bridge(
+ newFace, CUBIT_TRUE);
//get new parameters
asurface.Initialize(newFace);
U1 = asurface.FirstUParameter();
@@ -668,7 +670,7 @@
DLIList<Surface*> surfs;
lump->surfaces( surfs );
Surface *surface = surfs.get();
return surface;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -1199,45 +1199,20 @@
if(build_body)
- OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
- if (!occ_surface)
- PRINT_ERROR("Cannot populate an OCC surface from the given TopoDS_Face.\n");
- return (Surface *)NULL;
- double UMax, VMax, UMin, VMin;
- occ_surface->get_param_range_U(UMin, UMax);
- occ_surface->get_param_range_V(VMin, VMax);
- Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(aShape);
- TopoDS_Shell topo_shell =
- BRepBuilderAPI_MakeShell(HGeom_surface, UMin, UMax,VMin, VMax);
- TopoDS_Solid topo_solid = BRepBuilderAPI_MakeSolid(topo_shell);
- Lump *lump =
- OCCQueryEngine::instance()->populate_topology_bridge(topo_solid,
- CUBIT_TRUE);
- if (lump == NULL)
- PRINT_ERROR("In OCCQueryEngine::populate_topology_bridge\n"
- " Cannot make sheet body object.\n");
- DLIList<Surface*> surfs;
- lump->surfaces( surfs );
- delete surface;
- surface = CAST_TO(surfs.get(),OCCSurface);
+ OCCShell* shell(NULL, surface);
+ OCCLump* lump(NULL, surface);
+ OCCBody* body(NULL, CUBIT_TRUE, surface);
+ surface->set_body(body);
+ surface->set_lump(lump);
+ surface->set_shell(shell);
- else
- if(PRINT_RESULT)
- PRINT_INFO("Adding faces.\n");
- iTotalTBCreated++;
- OCCMap->Bind(*poface, iTotalTBCreated);
- OccToCGM->insert(valType(iTotalTBCreated,
- (TopologyBridge*)surface));
- SurfaceList->append(surface);
+ if(PRINT_RESULT)
+ PRINT_INFO("Adding faces.\n");
+ iTotalTBCreated++;
+ OCCMap->Bind(*poface, iTotalTBCreated);
+ OccToCGM->insert(valType(iTotalTBCreated,
+ (TopologyBridge*)surface));
+ SurfaceList->append(surface);
else
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -45,15 +45,17 @@
// ********** BEGIN PUBLIC FUNCTIONS **********
-// Purpose : A constructor with a pointer to a ACIS SHELL.
+// Purpose : A constructor with a pointer to an OCC SHELL.
// Special Notes :
-OCCShell::OCCShell(TopoDS_Shell *theShell)
+OCCShell::OCCShell(TopoDS_Shell *theShell, OCCSurface* surface)
myTopoDSShell = theShell;
@@ -106,6 +108,12 @@
void OCCShell::get_parents_virt( DLIList<TopologyBridge*>& parents )
+ parents.append(mySheetSurface->my_lump());
+ return;
OCCQueryEngine* oqe = (OCCQueryEngine*) get_geometry_query_engine();
OCCBody * body = NULL;
DLIList <OCCBody* > *bodies = oqe->BodyList;
@@ -136,6 +144,11 @@
void OCCShell::get_children_virt( DLIList<TopologyBridge*>& children )
+ children.append(mySheetSurface);
+ return;
TopExp::MapShapes(*myTopoDSShell, TopAbs_FACE, M);
int ii;
@@ -152,6 +165,9 @@
CubitStatus OCCShell::update_OCC_entity( BRepBuilderAPI_Transform &aBRepTrsf)
TopoDS_Shape shape = aBRepTrsf.ModifiedShape(*get_TopoDS_Shell());
TopoDS_Shell shell = TopoDS::Shell(shape);
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCShell.hpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -42,7 +42,7 @@
public:
- OCCShell(TopoDS_Shell *theShell);
+ OCCShell(TopoDS_Shell *theShell, OCCSurface surface = NULL);
virtual ~OCCShell() ;
//- Destructor.
@@ -106,6 +106,7 @@
private:
TopoDS_Shell *myTopoDSShell;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -83,6 +83,9 @@
OCCSurface::OCCSurface(TopoDS_Face *theFace)
myTopoDSFace = theFace;
+ myShell = NULL;
+ myLump = NULL;
+ myBody = NULL;
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp 2008-02-15 20:31:00 UTC (rev 1599)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp 2008-02-18 22:41:20 UTC (rev 1600)
@@ -300,6 +300,21 @@
void get_curves(DLIList<OCCCurve*>&);
+ void set_shell(OCCShell* shell)
+ { myShell = shell;}
+ void set_lump(OCCLump* lump)
+ { myLump = lump;}
+ void set_body(OCCBody* body)
+ { myBody = body;}
+ OCCShell* my_shell() {return myShell;}
+ OCCLump* my_lump() {return myLump;}
+ OCCBody* my_body() {return myBody;}
virtual CubitBoolean is_parametric();
//R CubitBoolean
//R- CUBIT_TRUE/CUBIT_FALSE
@@ -401,6 +416,11 @@
TopoDS_Face *myTopoDSFace;
+ //Following 3 members are only for sheeted body.
+ OCCShell* myShell;
+ OCCLump* myLump;
+ OCCBody* myBody;
More information about the cgma-dev
