[cgma-dev] r1602 - in cgm/trunk/geom: . OCC
janehu at mcs.anl.gov
Wed Feb 20 14:15:29 CST 2008
Author: janehu
Date: 2008-02-20 14:15:29 -0600 (Wed, 20 Feb 2008)
New Revision: 1602
Modified:
cgm/trunk/geom/GeometryModifyTool.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added make_BodySM for surface; Added make_Surface from curve_list.
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp 2008-02-19 18:38:03 UTC (rev 1601)
+++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-02-20 20:15:29 UTC (rev 1602)
@@ -1336,15 +1336,70 @@
if (ref_face_ptr)
old_surface_ptr = dynamic_cast<Surface*>(bridge_list.pop());
+ //perform edge checks
+ DLIList<RefEdge*> copied_ref_edges;
+ if( check_edges )
+ DLIList<RefEdge*> vtx_edges;
+ DLIList<RefVertex*> vtx_list;
+ for ( int i = ref_edge_list.size(); i > 0; i-- )
+ RefEdge *ref_edge = ref_edge_list.get();
+ CubitBoolean other_edge = CUBIT_FALSE;
+ ref_edge->ref_vertices(vtx_list);
+ while( vtx_list.size() )
+ vtx_edges.clean_out();
+ vtx_list.pop()->ref_edges( vtx_edges );
+ while( vtx_edges.size() )
+ if( ! ref_edge_list.is_in_list( vtx_edges.pop() ) )
+ other_edge = CUBIT_TRUE;
+ vtx_list.clean_out();
+ break;
+ if(other_edge)
+ break;
+ if ( other_edge || (ref_edge->get_parents() > 0) )
+ RefEdge *replacement_edge = GeometryModifyTool::instance()->make_RefEdge( ref_edge );
+ if (!replacement_edge)
+ PRINT_WARNING("Creation of Surface Unsuccessful\n");
+ return (RefFace *)NULL;
+ ref_edge_list.change_to( replacement_edge );
+ copied_ref_edges.append( replacement_edge );
+ ref_edge_list.step();
+ }//end 'for' loop
DLIList<Curve*> curve_list(ref_edge_list.size());
+ if (copied_ref_edges.size() > 0)
+ entity_list.clean_out();
+ bridge_list.clean_out();
+ CAST_LIST_TO_PARENT( ref_edge_list, entity_list );
+ GME_ptr =
+ common_modify_engine( entity_list, bridge_list );
CAST_LIST( bridge_list, curve_list, Curve );
// Use the Curves to create a Surface
Surface* surface_ptr = GME_ptr->make_Surface(ref_face_type, curve_list,
- old_surface_ptr, check_edges) ;
+ old_surface_ptr, CUBIT_FALSE) ;
if (surface_ptr == NULL) {
PRINT_ERROR("Couldn't make new RefFace.\n");
+ for(i=copied_ref_edges.size(); i--; )
+ GeometryQueryTool::instance()->delete_RefEdge( copied_ref_edges.get_and_step() );
return NULL;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-19 18:38:03 UTC (rev 1601)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-20 20:15:29 UTC (rev 1602)
@@ -632,6 +632,8 @@
// Function : make_Surface
// Member Type: PUBLIC
// Description: make a surface of type surface_type, given the list of curves.
+// check edges option is down in GeometryModifyTool level, so
+// disregard this option.
// Author : Jane Hu
// Date : 02/08
@@ -640,8 +642,43 @@
Surface * old_surface_ptr,
bool check_edges) const
+ //Create TopoDS_Edge list to make a surface.
+ DLIList<TopoDS_Edge*> topo_edges;
+ curve_list.reset() ;
+ Curve const* curve_ptr = NULL ;
+ OCCCurve* occ_curve = NULL;
+ TopoDS_Edge* topo_edge = NULL;
+ for ( i = 0 ; i < curve_list.size() ; i++ )
+ curve_ptr = curve_list.get_and_step() ;
+ occ_curve = CAST_TO(const_cast<Curve*>(curve_ptr), OCCCurve);
+ if(occ_curve == NULL)
+ PRINT_ERROR("In OCCModifyEngine::make_Surface\n"
+ " Got a NULL pointer to OCCCurve\n") ;
+ return (Surface*) NULL;
+ topo_edge = occ_curve->get_TopoDS_Edge();
+ topo_edges.append(topo_edge);
- return (Surface*) NULL;
+ // Use the topo_edges to make a topo_face
+ TopoDS_Face* topo_face = this->make_TopoDS_Face(surface_type,
+ topo_edges, old_surface_ptr) ;
+ if(topo_face == NULL)
+ " Cannot make Surface object.\n");
+ return (Surface *)NULL;
+ // make the topology bridges for the face
+ Surface *surface = OCCQueryEngine::instance()->populate_topology_bridge(
+ *topo_face, CUBIT_TRUE);
+ return surface ;
@@ -664,9 +701,28 @@
// Author : John Fowler
// Date : 10/02
-BodySM* OCCModifyEngine::make_BodySM( Surface * ) const
- {return NULL ;}
+BodySM* OCCModifyEngine::make_BodySM( Surface *surface ) const
+ OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
+ if(!occ_surface)
+ PRINT_ERROR("Cannot create an OCC body from the given surface.\n"
+ "Possible incompatible geometry engines.\n");
+ return (BodySM *)NULL;
+ OCCBody* occ_body = occ_surface->my_body();
+ if(occ_body)
+ return occ_body;
+ TopoDS_Face* face = occ_surface->get_TopoDS_Face();
+ surface = OCCQueryEngine::instance()->populate_topology_bridge(*face, CUBIT_TRUE);
+ return CAST_TO(surface, OCCSurface)->my_body();
// Function : make_BodySM
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-19 18:38:03 UTC (rev 1601)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-20 20:15:29 UTC (rev 1602)
@@ -1197,15 +1197,6 @@
surface = new OCCSurface(poface);
- if(build_body)
- OCCShell* shell = new OCCShell(NULL, surface);
- OCCLump* lump = new OCCLump(NULL, surface);
- OCCBody* body = new OCCBody(NULL, CUBIT_TRUE, surface);
- surface->set_body(body);
- surface->set_lump(lump);
- surface->set_shell(shell);
if(PRINT_RESULT)
PRINT_INFO("Adding faces.\n");
iTotalTBCreated++;
@@ -1219,6 +1210,17 @@
int k = OCCMap->Find(*poface);
surface = (OCCSurface*)(OccToCGM->find(k))->second;
+ if(build_body)
+ OCCShell* shell = new OCCShell(NULL, surface);
+ OCCLump* lump = new OCCLump(NULL, surface);
+ OCCBody* body = new OCCBody(NULL, CUBIT_TRUE, surface);
+ surface->set_body(body);
+ surface->set_lump(lump);
+ surface->set_shell(shell);
TopExp_Explorer Ex;
for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
populate_topology_bridge(TopoDS::Wire(Ex.Current()));
More information about the cgma-dev
