[cgma-dev] r1599 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Fri Feb 15 14:31:07 CST 2008
Author: janehu
Date: 2008-02-15 14:31:00 -0600 (Fri, 15 Feb 2008)
New Revision: 1599
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
corrected to populate_topology_bridge for stand-along surface. The Sheet body generated currently has less vertices than the original one, because OCC's MakeShell code uses the surface of a TopoDS_Face to create shell instead of directly using TopoDS_Face, apparently it's not designed for making sheet body. So we have to look for other ways to walk around this senario.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-14 20:58:45 UTC (rev 1598)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-15 20:31:00 UTC (rev 1599)
@@ -46,6 +46,7 @@
#include "TopologyBridge.hpp"
#include "Handle_Geom_TrimmedCurve.hxx"
#include "Handle_Geom_RectangularTrimmedSurface.hxx"
+#include "TopExp_Explorer.hxx"
#include "OCCModifyEngine.hpp"
#include "OCCQueryEngine.hpp"
#include "CubitMessage.hpp"
@@ -522,6 +523,23 @@
return (Surface *)NULL;
+ //Testing for number of Vertices.
+ DLIList<OCCCurve*> curve_list;
+ DLIList<OCCPoint*> point_list;
+ occ_surface->get_curves(curve_list);
+ for (int i = 0; i < curve_list.size(); i++)
+ curve_list.get_and_step()->get_points(point_list);
+ point_list.uniquify_unordered();
+ TopoDS_Face * Face = occ_surface->get_TopoDS_Face();
+ TopExp_Explorer Ex;
+ int count = 0;
+ for (Ex.Init(*Face, TopAbs_VERTEX); Ex.More(); Ex.Next())
+ count++;
+ //Start of the codes
double UMax, VMax, UMin, VMin;
occ_surface->get_param_range_U(UMin, UMax);
occ_surface->get_param_range_V(VMin, VMax);
@@ -592,8 +610,6 @@
trimmed_cyl = GC_MakeTrimmedCylinder(axis, radius, height);
newFace = BRepBuilderAPI_MakeFace(trimmed_cyl);
- U2 = 2 * CUBIT_PI;
- U1 = 0;
else if(type == SPHERE_SURFACE_TYPE)
@@ -622,6 +638,8 @@
newFace = TopoDS::Face(newShape);
+ Surface *temp_surface = OCCQueryEngine::instance()->populate_topology_bridge(
+ newFace);
//get new parameters
asurface.Initialize(newFace);
U1 = asurface.FirstUParameter();
@@ -633,11 +651,7 @@
Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(newFace);
TopoDS_Shell topo_shell;
- if (extended_from == CUBIT_FALSE)
- topo_shell = BRepBuilderAPI_MakeShell(HGeom_surface, UMin, UMax,
- VMin, VMax);
- else
- topo_shell = BRepBuilderAPI_MakeShell(HGeom_surface, U1, U2, V1, V2);
+ topo_shell = BRepBuilderAPI_MakeShell(HGeom_surface, U1, U2, V1, V2);
TopoDS_Solid topo_solid = BRepBuilderAPI_MakeSolid(topo_shell);
Lump *lump =
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-14 20:58:45 UTC (rev 1598)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-02-15 20:31:00 UTC (rev 1599)
@@ -1195,15 +1195,8 @@
OCCSurface *surface;
if (!OCCMap->IsBound(*poface))
- if(PRINT_RESULT)
- PRINT_INFO("Adding faces.\n");
- iTotalTBCreated++;
surface = new OCCSurface(poface);
- OCCMap->Bind(*poface, iTotalTBCreated);
- OccToCGM->insert(valType(iTotalTBCreated,
- (TopologyBridge*)surface));
- SurfaceList->append(surface);
if(build_body)
OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
@@ -1230,7 +1223,21 @@
" Cannot make sheet body object.\n");
+ DLIList<Surface*> surfs;
+ lump->surfaces( surfs );
+ delete surface;
+ surface = CAST_TO(surfs.get(),OCCSurface);
+ else
+ if(PRINT_RESULT)
+ PRINT_INFO("Adding faces.\n");
+ iTotalTBCreated++;
+ OCCMap->Bind(*poface, iTotalTBCreated);
+ OccToCGM->insert(valType(iTotalTBCreated,
+ (TopologyBridge*)surface));
+ SurfaceList->append(surface);
else
More information about the cgma-dev
