[cgma-dev] r2474 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Dec 8 14:25:04 CST 2008
Author: janehu
Date: 2008-12-08 14:25:04 -0600 (Mon, 08 Dec 2008)
New Revision: 2474
Modified:
cgm/trunk/geom/OCC/OCCDrawTool.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Found a bug in OCCDrawTool in where Occsurface is wrongly deleted, hence later export operation will crash. Fixed it.
Modified: cgm/trunk/geom/OCC/OCCDrawTool.cpp
--- cgm/trunk/geom/OCC/OCCDrawTool.cpp 2008-12-08 19:57:06 UTC (rev 2473)
+++ cgm/trunk/geom/OCC/OCCDrawTool.cpp 2008-12-08 20:25:04 UTC (rev 2474)
@@ -215,7 +215,6 @@
CubitStatus stat;
stat = draw_surface(surf_ptr, color, tessellate, flush);
- OQE->delete_solid_model_entities( surf_ptr );
return stat;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-08 19:57:06 UTC (rev 2473)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-08 20:25:04 UTC (rev 2474)
@@ -25,6 +25,8 @@
#include "BRepBuilderAPI_MakeSolid.hxx"
#include "OCCShapeAttributeSet.hpp"
#include "BRepBuilderAPI_MakeShell.hxx"
+#include "GProp_GProps.hxx"
+#include "BRepGProp.hxx"
#include "BRepTools_WireExplorer.hxx"
#include "TColgp_Array1OfPnt.hxx"
#include "Poly_Array1OfTriangle.hxx"
@@ -1368,19 +1370,19 @@
CubitBoolean build_body)
OCCSurface *surface = NULL;
+ GProp_GProps myProps;
+ BRepGProp::SurfaceProperties(aShape, myProps);
+ double area = myProps.Mass();
+ double tol = get_sme_resabs_tolerance();
+ if(area < tol * tol)
+ return (Surface*) NULL;
if (!OCCMap->IsBound(aShape))
TopoDS_Face *poface = new TopoDS_Face;
*poface = aShape;
surface = new OCCSurface(poface);
- double tol = get_sme_resabs_tolerance();
- if(surface->measure() < tol * tol)
- delete surface;
- return (Surface*) NULL;
iTotalTBCreated++;
OCCMap->Bind(*poface, iTotalTBCreated);
OccToCGM->insert(valType(iTotalTBCreated,
@@ -1531,17 +1533,19 @@
Curve* OCCQueryEngine::populate_topology_bridge(const TopoDS_Edge& aShape)
Curve *curve;
+ BRepGProp::LinearProperties(aShape, myProps);
+ double length = myProps.Mass();
+ if(length < get_sme_resabs_tolerance())
+ return (Curve*) NULL;
TopoDS_Edge *poedge = new TopoDS_Edge;
*poedge = aShape;
iTotalTBCreated++;
curve = new OCCCurve(poedge);
- if(curve->measure() < get_sme_resabs_tolerance())
- delete curve;
- return (Curve*) NULL;
OCCMap->Bind(*poedge, iTotalTBCreated);
(TopologyBridge*)curve));
More information about the cgma-dev
