[cgma-dev] r2473 - cgm/trunk
janehu at mcs.anl.gov
Mon Dec 8 13:57:06 CST 2008
Author: janehu
Date: 2008-12-08 13:57:06 -0600 (Mon, 08 Dec 2008)
New Revision: 2473
Added:
cgm/trunk/README.OCC
Log:
First version for read me for CGM on OCC.
Added: cgm/trunk/README.OCC
--- cgm/trunk/README.OCC (rev 0)
+++ cgm/trunk/README.OCC 2008-12-08 19:57:06 UTC (rev 2473)
@@ -0,0 +1,80 @@
+Read Me for CGM on OCC
+CGM can be built upon the ACIS solid modeling engine or OCC solid
+modeling engine, but also includes geometry capability developed
+beside and on top of them.
+CGM is supported on Sun Solaris, SGI, HP, Linux and Windows NT
+platforms. CGM also includes support for loading OCC
+models on parallel computers.
+CGM is being released into the public domain under an LGPL license;
+the OCC-based engine is available from Opencascade open source downloads.
+Build OCC-based engine
+Go to http://www.opencascade.org/getocc/download/loadocc/ and get
+desired source files.
+Untar the files, then under OpenCASCADE6.3.0/ros directory, to
+autoreconf -fi
+./configure (Add --prefix=dir for your install directory)
+make
+make install
+Dependencies
+CGM can be built using the CMake utility, which is "an extensible,
+open-source system that manages the build process in an operating
+system and compiler independent manner", or (on *NIX) using a
+configure-make system. Cmake is available under an open source
+license, and can be downloaded in binary or source formats; see
+http://www.cmake.org for details.
+Compiling
+1. Unpack the source code in some directory CGM_DIR, and change
+directory into CGM_DIR.
+2a. Run cmake in that directory, using either the non-interactive
+("cmake .") or interactive ("ccmake .") version, OR
+2b. Run "./configure" in that directory, optionally specifying where
+ACIS libraries are located and other options (run "./configure -h" for
+a list of options).
+3. Make the CGM libraries by typing "make".
+4. Install the CGM libraries by typing "make install" (this installs
+the libraries to the location specified by the --prefix option to
+configure, or to /usr/local by default).
+5. Test the installation using "make test".
+Documentation, Testing, Example Applications
+Documentation for CGM is available from the CGM web page,
+http://cubit.sandia.gov/CGM.
+Example applications are included with the CGM distribution in the
+"test" subdirectory. Examples include importing and querying solid
+model-based geometry, and constructing OCC-based geometry. If you
+are interested in contributing examples to be included with CGM, we
+would welcome submissions; please send them to the email address
+below.
+Bugs, Correspondence, Contributing
+CGM on OCC code is now in alpha testing stage, we encourage users to
+submit bug reports (and, if desired, fixes) to cgma-dev at mcs.anl.gov .
+Updates
+This is the first version of the file
More information about the cgma-dev
