[cgma-dev] r2475 - cgm/trunk/test
janehu at mcs.anl.gov
Wed Dec 10 10:07:06 CST 2008
Author: janehu
Date: 2008-12-10 10:07:06 -0600 (Wed, 10 Dec 2008)
New Revision: 2475
Modified:
cgm/trunk/test/makept.cpp
Log:
Solved the problem of crashing after Draw command.
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-12-08 20:25:04 UTC (rev 2474)
+++ cgm/trunk/test/makept.cpp 2008-12-10 16:07:06 UTC (rev 2475)
@@ -125,6 +125,8 @@
tmpBd->ref_vertices(vertices);
DLIList<RefEdge*> ref_edges;
tmpBd->ref_edges(ref_edges);
+ DLIList<RefFace*> sphere_faces;
+ tmpBd->ref_faces(sphere_faces);
for(int i = 0; i < ref_edges.size(); i++)
vertices.clean_out();
@@ -135,15 +137,6 @@
objOCC = ( (OCCBody*) tmpBdSM )->get_TopoDS_Shape(); //Opencascade Object
OCCDrawTool::instance()->draw_TopoDS_Shape(objOCC, 200);
- DLIList<Body*> bodies;
- DLIList<RefEntity*> free_entities;
- gti->bodies(bodies);
- //delete all entities
- gti->delete_Body(bodies);
- gti->get_free_ref_entities(free_entities);
- assert(free_entities.size() == 0);
// Read in the geometry from files specified on the command line
const char *argv = "66_shaver3.brep";
CubitStatus status = read_geometry(1, &argv);
@@ -182,7 +175,7 @@
CubitVector vector1(10,10,10);
CubitVector vector2(-10,-10,10);
CubitVector vector3(10, -10, 10);
- free_entities.clean_out();
+ DLIList<RefEntity*> free_entities;
// Make two vertices.
gmti->make_RefVertex(vector1,5);
@@ -201,7 +194,7 @@
num_ents_exported, cubit_version);
//check for vertex
- bodies.clean_out();
+ DLIList<Body*> bodies;
free_entities.clean_out();// get_free_ref_entities directly append
//without checking for duplicates, so clean_out first.
@@ -271,8 +264,8 @@
DLIList<RefFace*> ref_faces;
gti->ref_faces(ref_faces);
- //RefFace* ref_face = ref_faces.step_and_get();
- RefFace* ref_face = ref_faces.get();
+ RefFace* ref_face = ref_faces.step_and_get();
+ //RefFace* ref_face = ref_faces.get();
//make a new refface out of existing refface.
CubitBoolean extended_from = CUBIT_TRUE;
More information about the cgma-dev
