[cgma-dev] r2472 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Fri Dec 5 15:00:12 CST 2008
Author: janehu
Date: 2008-12-05 15:00:12 -0600 (Fri, 05 Dec 2008)
New Revision: 2472
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp
Log:
Minor changes for memory clean up.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-04 19:47:25 UTC (rev 2471)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-05 21:00:12 UTC (rev 2472)
@@ -4312,7 +4312,7 @@
result_body_list.append(bodysm);
continue;
- delete acurve;
+ OCCQueryEngine::instance()->delete_solid_model_entities(acurve);
return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp
--- cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp 2008-12-04 19:47:25 UTC (rev 2471)
+++ cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp 2008-12-05 21:00:12 UTC (rev 2472)
@@ -67,6 +67,8 @@
OCCShapeAttributeSet(const BRep_Builder& B);
+~OCCShapeAttributeSet(){Clear();} ;
//! Stores the goemetry of <S>. <br>
void AddGeometry(const TopoDS_Shape& S) ;
@@ -132,6 +134,7 @@
void ReadTriangulation(Standard_IStream& IS);
+//! Clears the content of the set.
void Clear();
void Check(const TopAbs_ShapeEnum T,TopoDS_Shape& S);
More information about the cgma-dev
